How do i explain this lol.
They are good? Cut well so no grinding or mismatching on mine and smooth i did lube them.
At the same time they are thin but there are so many threads it shouldn’t be an issue.
It takes 13 turns to undo the tail cap compared to 4 turns on a C8 lol i guess the battery tube is twice as big.
Damned fine host, easy to mod.
The F13 is a nice light, takes a 26650, is nice and beefy, could run some decent power and still stay relatively cool. The UI, though, was rather annoying. H/M/L plus blinkies… yecch. Dis-co-nnect!
So, rather than suffering in silence, I figure I’d share my modding misery.
Anyway, I was doing this already, didn’t want to stop (inertia, and all that), so just grabbed some Truly Crappy cellphone pix while I was already in-progress.
Start with a standard F13 ( http://www.gearbest.com/le…
Beefy enough to handle some decent heat, too.
eas
(eas)
February 4, 2018, 9:10pm
9
I don’t have an A8, but from the listings I’ve looked at, the “Yupard” version looks like they cut some corners.
I’m interested to hear what other people suggest.
vinte77
(vinte77)
February 5, 2018, 5:29am
10
F13 are well priced and easy to mod. Here’s mine
I got my some of my lights back from getting them cerakoted by n10sivern. Here’s the Ultrafire F13 in sniper grey, triple xpl-hi 5000k v2 70cri, 22mm bistro otsm driver (thanks Lexel), kiriba-ru copper triple spacer, kaidomain triple reflector and orange/yellow tail light switch.
![image]
![image]
![image]
XD9
(XD9)
February 5, 2018, 6:03am
11
I am on the road to do something like this
Well at least I hope so
My F13 should be here this week…
Thanks for your post, It gives me ideas… And all others too!
Funner
(Funner)
February 5, 2018, 9:30am
12
For the price I will probably pick up the A8, B06, and (2) F13’s (one left stock and one to mod with a xhp35).
Thanks for all the Advice and comments.
kramer5150
(kramer5150)
February 9, 2018, 4:56am
13
I might pick up an F13… seems like a great affordable light.
I love the F13… as a host.
Out of the box, it kinda stinks. Cheap minimally regulated driver, crappy annoying UI, probably an undersized LB emitter. New driver and new emitter, and it’ll kick arse.
Funner
(Funner)
February 9, 2018, 6:18am
15
Using the F13 as a host for a beginner, what would be the ideal and exact parts that the F13 could handle in say a XHP35.2(35) or 50.2(50) or better, like from Kaidomain. As little work as possible the better.
LED on star, and wires on board. So pull the old, add paste, solder, push star down stuff wires in and solder board in. Correct?
This would be my first flashlight mod.
Thanks.
beam0
(beam0)
February 9, 2018, 6:46am
17
Funner:
I like the size, look, rear button, and battery of the Ultrafire F13. Are there any other manufactures with that body/copy or similar? $20-$35
I am looking for a rear button, 26650 battery, clean edc style, bright and affordable. I like the Kaidomain K5s specs all around, but I would have a slimmer head like the same size as the tube.
Or recommendations
Thanks
It doesn’t sound like you want this for a modding host, how important is the tail switch?
This one looks like it meets your other requirements besides the tail switch, including the price ($23.71)
https://www.aliexpress.com/store/product/Sofirn-SP33-LED-Flashlight-18650-Cree-XPL-High-Power-Lamp-Torch-Light-Powerful-Flashlight-26650-Waterproof/2933049_32825400637.html?spm=2114.12010608.0.0.5e665280N1IHgw
EDIT: (TBone already suggested above, but here’s a nice photo anyway!)
beam0
(beam0)
February 9, 2018, 6:50am
18
Funner:
Thanks.
OK I must have missed this post. This host might be interesting.
http://www.kaidomain.com/p/S025386.KL-S26-26650-LED-Flashlight-Host-145mm-L-x-32_5mm-D-for-Cree-XM-L-Black-1-set
Funner
(Funner)
February 9, 2018, 6:59am
19
Right now I am not able to reply to individual posts so.
Beam0, I do need the rear tail button since the light will be in my pocket exc and it will be less chance of turning on accidentally. The pic you link looks like the Trustfire A8 but with the side switch. I ordered the Trustfire A8 yesterday.
Thanks Beam0
Funner
(Funner)
February 9, 2018, 7:05am
20
Beam0, thanks for the KL-S26 link.
Thanks Again.
Funner
(Funner)
February 9, 2018, 7:16am
21
I will stick with the Ultrfire F13 as my host. I believe it has a great look and battery I am looking for. Now to mod it to put out some light.
beam0
(beam0)
February 13, 2018, 3:36am
22
I also ordered an F13 for mod host yesterday.
Thought this looked pretty nice though,
Similar to KD K5S but with knurling and no stainless bezel:
Manta Ray C8.2
XHP-50.2, 4-mode, no blinkies, 3A High mode…$33.49
https://www.aliexpress.com/item/Self-Defense-Manta-Ray-C8-2-CREE-XHP50-2
SST-40 Version, 3-mode, no blinkies, 5A High…$29.50
https://www.aliexpress.com/item/High-Bright-C8-2-Luminus-SST-40-LED
HOST AVAILABLE…choice of OP or SMO reflector…$21.65
https://www.aliexpress.com/item/Manta-ray-C8-2-black-flashlight-host
Nice fins!:
I really like this!
Funner
(Funner)
February 9, 2018, 3:13pm
23
beam0
(beam0)
February 9, 2018, 4:02pm
24
