Help me pick my next light (cheap 1x18650 throwy)
The convoy c8 with xpl hi got a really nice beam
free image hosting
I know you said you didn’t like the look of the C8, but it really is the best budget choice. The silver Convoy C8 is a good choice (don’t get the other colors of Convoys, because their UI isn’t very good). For a few dollars more, there’s the Astrolux C8 which has higher output and throw. I reviewed it and compared it with the Convoy here:
https://budgetlightforum.com/t/-/48738
how can you not have BLF A6 or Astrolux S1?
wle
Id say that, and theres good deals going down on them here on the forum
$28.99. I would go with the 5000k tint. Its probably my favorite tint I have right now in all of my flashlights
The UI is good on it, but I would love to have the same UI as the GT on this light
I just bought the EE X6 from GB with a coupon from bilakos
From reviews i read, the EE quality is better then the Astrolux
I’d like to know some more about your UF13 mods.
Have you also changed the emitter in your UF F13 w/22mm 1-mode?
Crappy pix, but yeah:
Everything’s a variation of a theme, nothing terribly different if swapping for a 3D, 5A, etc.
Only the driver was a little tricky, that the wires had to be “unlooped” to not bang on the shelf above it. Plus, I used one of those PET insulating discs to further insulate it from the shelf, just in case.
Other than that, it’s a straightforward mod, nice’n’easy.
The 3D is (to me) a bit on the cool side, rally should’ve tried the 5A/5D first. Well, that’ll learn me…
Thanks, interesting light, almost bought one about a year ago.
I was thinking an XHP35 and one of these:
http://www.kaidomain.com/p/S026504.H2-C-22mm-1_5A-1-or-2-cell-5-Mode-Boost-Driver-Circuit-Board-for-Cree-XHP35-XHP50-12V
~~http://www.kaidomain.com/p/S025124.FX35-22mm-1A-1-Cell-3-Mode-Boost-Driver-Circuit-Board-for-Cree-XHP35~~
What are your thoughts on that?
EDIT: Don’t like the modes on that 2nd one.
I did my research a while ago, ruled out all those multimodes as annoying.
If you can deal with them, hey, go crazy, but not for me.
In particular, I don’t like that “150” mode. No such thing. Call it 100 that steps down to 67% if you have to.
Well at least the H2-C has hidden strobes, so basically a 4-mode ML-L-M-H, but I could do without the ML (0.01%)
Too bad no one makes one of these with firmware like the Dr. Jones Guppydrv, I have a few 17mm FET drivers with Rev1, they can be set to various groups, including single mode 100%, for an emergency light.
The thing is I can’t seem to find any other “off the shelf” single cell 12v boost drivers for XHP35, this is the only one I know of, do you know of any?
Not offhand. Got some from FT for a MT-G2, but didn’t try it yet.
MT-G2 was another one I was thinking about for that F13. If I see it come up on a flashsale or coupon deal I’ll probably grab one to mod.
C8 for sure likely best cheap thrower.
Also if you want a Nichia in that H03 just put one in, its not hard. I put a Nichia 219c 4000k 90+ CRI in one of my H03’s last week.
Just remove the 4 screws, pull off the retaining ring, the o ring, then the optics(mine had the TIR optics) then there is a 16mm MCPCB with the LED on it just sitting there with a little thermal compound(not adhesive). Just replace the stock MCPCB with a replacement with whichever LED you prefer. The wires are a little short so you will have to make the final soldering connection with the soldering iron inside the head of the light but its not really a big deal, took me about 5 mins start to finish.
I’ll throw in my $.02 and tell you that for the price, I was really impressed with the throw on my Thorfire VG10s.
1 rechargeable 18650 goes a long way, and it’s given me a lot of walk time with my dog on the medium setting at night.
I think it was Free Field Training on YT who posted a video on how surprised he was with how it could throw compared to his duty light.
Probably the most ignored, budget thrower that I have ever come across- and I’d dare bet it might out throw any of the options listed so far- is the UniqueFire HS-802 (or any re-branded version) This thing has an intense hotspot and a DEEEP reflector. Put off by the fact that it’s only about 350 lumens? Just remember that the Jacob A60 was only 310 lumens and out-threw everything for years. It is a true pencil beam, spot thrower. With a hopped up driver and LED, this thing would SCREAM. Just my opinion. And you cant beat the price. (about $20)
https://www.aliexpress.com/item/HS-802-1Mode-350Lumen-250-Yard-Long-Range-Throwing-LED-Coyote-Hog-CREE-RED-Green-Blue/32796080288.html?ws_ab_test=searchweb0_0,searchweb201602_3_10065_10344_10130_10068_10324_10547_10342_10325_10546_10343_10340_10548_10341_10545_10084_10083_10618_10307_10313_10059_10534_100031_10103_441_10624_442_10623_10622_10621_10620_10142,searchweb201603_2,ppcSwitch_4&algo_expid=0879cfde-4eff-4c18-9f6f-44d2f2b4f41d-7&algo_pvid=0879cfde-4eff-4c18-9f6f-44d2f2b4f41d&priceBeautifyAB=0
Thanks for sharing, wow that does seem to have a very deep reflector:
I also like that you can order it with a stainless steel bezel ring for around $2 extra (“C” package)
I wish-listed it for future reference/purchase.
EDIT: I see now they do offer it with XP-L HI 1000lm 1-mode: Page Not Found - Aliexpress.com
Plus they offer three different tint choices:
  • CREE XPL HI V3-1A Cool white: 6500K
  • CREE XPL HI U6-3C Neutral white: 4750K~5000K
  • CREE XPL HI V3-7A Warm white: 3000K
Plus it looks like it has a nice brass pill.
Not much experience but seems like like sofirn c8t seems hard to beat on a bang for the buck basis.
The HS-802 was the best thrower you could get under 20 bucks back in the day. I have one I may just mod with a XPL hi, curious to see what it will do. It as Badger4715 describe. The beam is almost laser like with the XR-E R2. I tried a xpg once and didn’t really like it (spread the beam with out much lumen increase) so I switched it back. The XPL HI might spread the beam a little but at 1000 lumens I could see it still being a good thrower.
Yeah it’s sort of coming back to me, I think I remember reading about this one many years ago, the reflector comparison photo even looks vaguely familiar, totally forgot about it and didn’t know it was still around.
The reflector is really deep for it’s size. Its about as deep as a 18650 25r.
That’s about where the led sits in the head once the light is together. I tried to take a pic down in the reflector but there’s
noway I can capture the depth of it.
