That is not taking into account the effect of the cross on throw from a reflector. The cross between the dies always takes up some area in the reflector, reducing the effective luminance. Though the XHP70.2 is better in that respect than the first generation. Texas_ace measured the sliced XHP70.2 at 6A (12V) in the BLF GT at around 65 CD/mm^2. I present you with Giggles, the most hardcore BLF thrower in the World. - #101 by Texas_Ace
I agree the CFT90 is in another league of brightness and output.
The cross doesn’t affect anything, all the light from the dies goes to every point on the reflector.
There is no “taking up part of the reflector”.
The result is simply that the lux in the center of the hotspot is not as high as the lux slightly to the side diagonally, where one of the square dies would be projected.
This is only for short distances though, far enough away the four beams from each individual die will have diverged enough that all the points in the hotspot have the same intensity.
65cd/mm^2 at 6A definitely suggests over 100cd/mm^2 at close to 20A.
When I look into the beam of a C8 with sliced XHP50 from 7m away there is always some area of the reflector filled with the dark cross, in the beam center and anywhere in the beam. What you say about going slightly to the diagonal makes sense, but have you observed this? In my experience with the four die LEDs it is always like I describe above.
Oh I see, so 12A 6v.
I haven’t tested my XHP70.2 in a reflector yet, but from the modded GT beamshots there is pretty much no cross visible.
Anyway, I’m just concerned about lux, not how visible the cross is.
Since the light will still hit the entire reflector the lux will be the same if you measure it where the die projection is.
As you can probably imagine, if you just take a single die LED and move it a bit to the side you will still get the same lux because the LED has the same surface brightness and the reflector has the same area.
It’s just that the spot with the highest lux will be slightly over to the side off centre.
The original LED chosen for this flashlight was a Osram Synios P2720 KW DMLQ31.SG, hence the name of the flashlight. Unfortunately a flaw in the testing method made this LED appear very high eprforcming, despite it not actually being that great. For this reason, the Osram Oslon Black Flat is still the highest intensity LED available currently at ~260cd/mm^2. Tests of this LED can be found here: LED Test The price of one LED is $4 CAD.
The driver that will be used to power the LED is a 27.5mm MTN-MAX 1A-6A Buck Driver from Mountain Electronics. This driver can take 5V-18V making it perfect for the use of 3S lithium batteries. It will also be configured to output 6A just like the OptoFire which is about the maximum that the Black Flat LED can take. The driver costs $26 CAD.
The reflector is the most expensive part of this flashlight. It is made out of electroformed nickel plated in aluminum, a very large and high precision optic. There were several options for this reflector, such as 1 or 2 inch bottom hole and 11 or 13” diameter. In order to maximize the available area, the option with a 1” hole was chosen. Even though the 13” option would also increase the area, the LED only emits light in a 180 degree hemisphere so anything over the 12” mark would be unused area. A $100 USD fee could be paid to have the 13” reflector cut down to 12”, or an almost identical reflector could be purchased from Optiforms, the P76. The P76 is 12” diameter, and has an even smaller center hole at only .75”, however this reflector costs almost double what the Phoenix reflector costs, so for price/performance purposes it will not be purchased. The $100 option to cut down the Phoenix reflector will also not be taken in order to fit the reflector more easily inside the aluminum tube.
Overall, the 11” reflector will still perform extremely well and collect almost all of the light (96.5%) and the price is very reasonable compared to the competition. One reflector costs $402 CAD.
No radiators or fans will be used in the cooling of this flashlight, thanks to the aluminum body design. In order to transfer the heat efficiently from the LED in the middle of the reflector to the sides of the searchlight, liquid cooling will be used. Copper tubing will be used to transfer the heat from the fluid to the aluminum body. 25 feet of 3/16” copper tubing cost $42 CAD.
To move the fluid through the loop, a compact self-priming pump will be used. The pump has a flow rate of 1.3L/min and a pressure of 0.3MPa which should be enough for this small loop. The pump costs $16 CAD.
Flexible FKM tubing will be used to connect all the cooling components such as the LED block, pump, and copper coil. This tubing has a 1/4” outer diameter which will fit perfectly below the aluminum arms holding the LED block. A 3m length will be more than enough for this project as well as future projects. The tubing costs $31 CAD.
Small tubing barbs will be used to connect the tubing to the LED cooling block. The barbs have an outer diameter of 5mm which will fit tightly inside the tubing. The set of 10 barbs will cost $6 CAD.
The thermal compound used between the LED MCPCB and cooling block will be liquid metal. The three best options are Coolaboratory Liquid Pro, Coolaboratory Liquid Ultra, and Thermal Grizzly Conductonaut. Liquid Pro has better thermal conductivity than Liquid Ultra, however Liquid Ultra was made specifically because the Pro was very difficult to apply. Conductonaut on the other hand, has almost identical thermal conductivity as Liquid Pro, but is as easy to apply as Liquid Ultra. For this reason, Thermal Grizzly Conductonaut is the best of the three options. This liquid metal paste also has a higher thermal conductivity than most solders, and makes it much easier to assemble and replace the LED in the future. One gram of liquid metal costs $22 CAD.
To protect the reflector, a custom diameter acrylic lens will be used. The lens is 3mm thick and will be slightly below 12” in diameter. This ultra-clear AR coated acrylic has a light transmission above 97%. The custom size lens will cost $54 CAD.
The large LiPO batteries used in some of my other projects will unfortunately not fit inside this compact searchlight. In order to keep this a portable “flashlight” it will still require an internal battery. The Shockly 5500mAh 26650 cells are extremely popular for their very high capacity, more than the rated 5.5Ah, and discharge rate. Six of these batteries will be used in a 3S2P configuration for a total of $60 CAD.
To make the batteries easy to remove for replacement, shipping, or using external power, six 26650 battery holders will be used. The battery holders are sold individually, so six will cost $9 CAD.
A custom cooling block for the LED will need to be machined by CNC. The piece will be made outof solid copper for the best heat transmission. The CNC job costs $133 CAD.
The body of the searchlight will be made out of a 6061 aluminum extruded tube. A 12” outer diameter witha .25” wall will be very rigid to protect the reflector, and will allow 1/4” of space around the reflector for protection. This space will also be used for tubing and wires to pass from behind to the front of the reflector where the LED is. The tube will be custom cut to 4” long and will cost $192 CAD.
1/4” thick 6061 aluminum sheets will be used for both the bottom of the searchlight as well as the ‘arms’ that will hold the LED and cooling block. The 1ft x 2ft aluminum plate will cost $72 CAD.
A blue LED voltage display will be used to monitor the battery’s voltage, even though the LED driver also has low-voltage protection. It is always useful to know how much battery there is left, and if it is getting close to finished. The voltmeter costs $10 CAD.
A blue LED temperature display will match the voltage display and also give information about the LED’s temperature. The temperature meter costs $17 CAD.
A compact black handle will be attached to the outside of the searchlight for easy portability. This rubber handle folds flat to take up less space when being transported, such as in a backpack. The handle costs $4 CAD.
The sheets of metal will be cut using a waterjet due to the complex 2d shapes and accuracy needed. The waterjet time costs $18 CAD.
For the highest durability, Type 3 hard anodizing will be used on the flashlight body. This is the most durable and scratch resistant coating, and will give the flashlight a nice dark grey appearance. The anodizing costs $150 CAD.
Some small objects such as wire, solder, connectors, and switches have been omitted. Cost of shipping and taxes were not included into the budget. USD prices were converted to CAD on the date of writing. Current prices may differ. Certain products such as the copper block machining had a discounted rate for me as a member of the university. A rough estimate of the total cost including all small components, taxes, and shipping is $2000 CAD.
No, this is actually not the case. Optimizing the XY-focus of my Project Excalibur light increased the luminous intensity. I think it depends on how small the LED is compared to the reflector.
Cool, I haven’t seen any of those laser lights yet in videos or IRL.
Nice to see companies exploring technologies other than LED
Maybe for a forward-facing reflector is is not, since the distance of the reflecting surface from the LED varies between very close and very far.
If you measure the lux in the spot created by an aspheric flashlight (the projected square) the lux is the same at all points, it is not higher in the middle.
So this suggests that light does not need to be coming directly from the center of the focal point.
A recoil reflector is somewhere in between a lens and a forward-facing reflector, in terms of distance form the LED and die projection sharpness.
Maybe you are correct in that case.
Revision 1 was designed using a 12” diameter 4” tall cake pan as the chassis. The low cost of the cake pan would have made this project a lot more affordable. However, this design was ultimately scrapped due to the lack of rigidity of the steel used in the pan, which would not protect the expensive mirror very well.
Revision 2 was changed to use 1/4” thick aluminum for both the body tube and the bottom, and was an intermediate stage in the design. In this design the reflector was held in by aluminum rings. To make the rings, two large 12”x12” aluminum sheets would have to be used, which was not very cost effective and would give difficulty in mounting the reflector rigidly while not damaging it.
Revision 3 was the runner-up to the chosen design, and uses a flat carbon fiber sheet to hold the LED in the center. This sheet would have similar rigidity to 1/4” thick aluminum while having less thickness and weight, since the original goal was to make the device only 4” thick. This design was not made due to the extra cost for the carbon fiber, which would cost approximately twice as much as aluminum. Carbon fiber would also increase the complexity of mounting it to the chassis, since holes cannot be drilled into the side due to delamination.
Revision 4 is the design that was chosen to build, and more renders can be found in the following section. This design also focuses the light by adjusting the position of the reflector, rather than the LED block. Due to it’s use of 1/4” aluminum instead of carbon fiber, the total height had to be increased from 4” to 4.25”.
Revision 5 was design to move the LED block up and down for focusing, rather than the reflector. The down side was that the glass would have to be removed every time the light needed to be focused. Mounting the LED cooling block within the arms and securing it also posed additional complications.
This design was made to fit a Turnigy 3S 65C 6000mAh LiPO battery pack, which I own several of and are used for other projects. Having a universal battery I could use for all my projects was appealing, however for this light, the goal was to keep it at around 4” thick, and using this battery added 1” of thickness. Another down side was that it complicated mounting of other internal components such as the reflector, but it also had the benefit that it allowed for a second cooling coil.
The final 7th revision was designed to fit many extra features, such as a built in LiPO charger, AC/DC converter for continuous operation, variable current power supply, and multi-pole switch. Not only would all these features added several hundred dollars to the design, but the thickness would need to increase to 6” which would no longer fit in a backpack for portability. Potential future prototypes will include features like these, however the first prototype will be much more basic.
Almost all of them are 2d exported images from sketchup (free)
The last one is a real render done in solidworks.
I made a solidworks model after sketchup because I needed a way to make the drawings for the waterjetting and assembling the components more accurately.
Way too complex to do, also not necessary for such low power LEDs.
Making microfins in there would probably make the blocks cost like $1000 rather than $100.
It might have helped if I decide to put a CFT90 in there later, but the project was already nearly 1.5-2x more expensive than I wanted it to be.
I could have probably gone with aluminum instead of copper to lower cost and still get decent performance, but what’s done is done
