Is there something like Moore’s law with LED emitters?
I’ve refreshed many old lights with newer emitters and the increased output is amazing.
Will I look back on today’s emitters 10 years from now and laugh at how weak they are or has this technology been nearly pushed to its limit?
Not asking for crystal ball answers, just wondering if anyone has deep knowledge of how far this can go.
......I think I have a lot of those prerequisites. Photos to soon follow of blurry images of something that really is just a blurry image and to others a sign of big foot.
If the led is soldered onto a alumnium non-DTP board (this is what the Ultrafire C8 likely came with), yes probably it will cook. If the led is soldered onto a copper DTP-board (such as a Sinkpad, Noctigon or KD-DTP board) and is clamped down with some hermal compound in between, it will be fine.
With led technology, there is a theoretical limit of about 300 lumen/W for white leds (a bit more for green leds). We are now at over 200 lumen/W so for led efficiency at least Moore’s law certainly does not apply. But we may be able to stuff more and more power in a little volume and make ever so brighter leds, but they require ever more powerful batteries (and regarding Moore’s law and batteries: regardless of the chemistry you can only stuff so much energy in a volume before you are litterally producing bombs) . And with laser pumped phosfor light sources that are just now on the market that power/volume is rising again.
Overall I see exciting improvements ahead but also too many theoretical limits to believe that Moore’s law will apply on leds.
what is an alternative way to keep a 17mm driver in place? i have a cheap 18650 zoomable host and it keeps popping out. i have tried soldering it to the pill but no luck. it used to fit tight but not anymore.
