I found mine (previous version with fuller and Shirogorov logo on the blade).
My measurements are almost the same:
Full length: 221 mm
Blade length: 96 mm
Handle length: 128 mm
So what is AliExpress trying to achieve by not showing things like locking mechanisms, fullers, etc? It’s like they want to sell the products based on fake pictures of the item.
Just got my 910+ that I ordered 10 days ago. I made right choice by buying 910+ instead of 9103/4. With my big hands, 910+ fits perfect, couldn’t be happier, can’t stop playing with it
I’ve been told 910+ is ‘bulkier’ because of G10 grips, don’t know how much is that true. 9103/4 is frame lock which makes it slimmer? I’ll order 9103 for my dad and will see the difference.
While this is definitely true, the 910x also have some slight variations in their lockbar tension.
I received both the 9103 and 9104 at the same time.
The 9104 was fine, but on the 9103 I had to slightly bend the lockbar outwards like Isti mentioned in order to be able to thumb roll the blade, the tension was a bit high from the factory in order to be able to do that.
And I am a knife people
As from Xatu’s comment about the 910+ and 910x being essentially the same knives, yes, the length dimensions are the same but the thickness of the 910+ due to the G10 scales makes it for a much wider and hand filling knife. While I personally prefer the 910x for being classier, thinner and slightly heavier, I can see how someone with L or XL hands would prefer the 910+ for comfort.
On a side note, it looks like CBSA’s revision of their own knife import rules has allowed them to take yet another knife from me, a Loscha clone.
The tracking shows that the knife arrived in Canada 3 weeks ago, yet I haven’t got it.
I’m expecting to receive a letter from CBSA any day now, what a bunch of BS……
It’s very easy, you don’t even need to take the knife apart. As Isti mention, just remove the pocket clip and bend the lockbar just a little at the time until you get the desire tension.
Just make sure to not bend too much at once.
