ALL THINGS BUDGET KNIVES
A 9103 arrived last week. It’s super difficult to open compared to my 910+. Probably just a bad specimen.
I much prefer the grippier 910+ regardless. The slightly thicker handle doesn’t bother me.
The 9103/9104 feels much slimmer compared to the 910+ (handle thickness 10.4 mm vs. 13.2 mm).
Remove the pocket clip then bend the lock-bar slightly outwards. That solved the problem for me.
The 9103/4 is a bit more difficult to open, esp. for non knife people as the fingers tend to lay on the lockbar while trying to flick the knife.
If you position your fingers on the clip instead it’s working same well as the 910+
For me the G10 scales could be slightly thinner, like 1/4th of the actual thickness, then they’d be perfect and not that bulky in my jeans pocket.
I have 9103/4 and 910+
I prefer 9103/4 … it is slimmer, heavier and thus has a more dense ‘solid’ feel, which I like. Much nicer ‘thunk’ sound when it opens also.
For sure the G10 of 910+ gives a little bit more grip (esp in the wet).
The series overall are very good value for money so buy both ! I am hoping Gearbest can stock the titanium version
While this is definitely true, the 910x also have some slight variations in their lockbar tension.
I received both the 9103 and 9104 at the same time.
The 9104 was fine, but on the 9103 I had to slightly bend the lockbar outwards like Isti mentioned in order to be able to thumb roll the blade, the tension was a bit high from the factory in order to be able to do that.
And I am a knife people :slight_smile:
As from Xatu’s comment about the 910+ and 910x being essentially the same knives, yes, the length dimensions are the same but the thickness of the 910+ due to the G10 scales makes it for a much wider and hand filling knife. While I personally prefer the 910x for being classier, thinner and slightly heavier, I can see how someone with L or XL hands would prefer the 910+ for comfort.
On a side note, it looks like CBSA’s revision of their own knife import rules has allowed them to take yet another knife from me, a Loscha clone.
The tracking shows that the knife arrived in Canada 3 weeks ago, yet I haven’t got it.
I’m expecting to receive a letter from CBSA any day now, what a bunch of BS……
I can’t thumb either of them open as it is now. Need both thumb and wrist flick. I’ll see if I can adjust the lock a bit.
It’s very easy, you don’t even need to take the knife apart. As Isti mention, just remove the pocket clip and bend the lockbar just a little at the time until you get the desire tension.
Just make sure to not bend too much at once.
Interesting my 9104 was also fine but I had to adjust all of my 9103s.
Did you order the alu integral version of the “Loscha”?
Yep, but unfortunately it doesn’t look like I’ll be getting it :frowning:
Guys, recommend me please nice quality, budget butterfly knife please.
Mike
Have a look at the MT Tachyon II clones on DHGate. I have the tanto version with satin finish and it`s pretty smooth. It also comes with a spring loaded latch.
It’s not the first time I hear that. The retention ball or hole where the 9103/4 fits is different from the 910, which is more difficult to open (9103/4). There’s some trick out there to leave them just like the 910.
I just took apart my workmate’s 9104 and my 910+ and installed my carbon fiber front scale and the cf clip.
The blade and the other hardware are interchangeable and my workmate said, he’d like a dual scaled black cf version with a black blade, maybe I’ll try how that’s looking.
Side not. I didn’t speak about lockbar tension when I said it’s a bit trickier to open it but most people have their middle finger on the lockbar when the try to open the knife.
The tension on this 9104 is good but soon I’ll have to carbidize the lock, it’s way over 80% already, even though it’s centered and has no wiggle or scratching from the ball bearing when I slightly push away the lockbar to check the pivot screw’s tightness.
Btw, I like that little rubber washer under the pivot screw on the 9104, much better solution than (red) loctite.
The only screw that needed some heat to break the loctite was the clip screw.
Hello guys, i could use some help.
I have a Ganzo G704 (440 steel) and its getting due for a sharpening. I bought a Lansky sharpener Amazon.com
I tried to sharpen the knife but seems im making it more dull. Im swiping the knife as upright as i can, full length of the blade, first on the coarse rod, then on the less coarse.
What angle do these knifes come stock, 22.5? The options on the lansky is either 20 or 25. By now ive been swiping probably 50 times on each set of rods but my knife is far from sharp. Seems it was sharper before i started.
Your blade must be really dull? Or maybe you got a bad knife, it could happen.
Personally I like to use the Lansky Blade Medic when a blade is really dull. Use the carbide first with a controlled pressure (because it will remove metal quite a bit if too much pressure) to recreate a V-edge.
Otherwise I have good results with the Lansky 2 rod system like yours.
I use the 40 degree (2x20) settings on my Spyderco Sharpmaker for sharpening my Ganzo folders. So the 20 option should work at the Lansky too.
Do you keep the blade perpendicular to the base of the sharpener during sharpening? That’s the key of these V systems.
You should avoid adding too much pressure on the blade during the process.
Marking the edge with a sharpie (permanent marker) is also a good trick for checking the progress of sharpening and the angle. You must remove all of the permanent marker at the edge during sharpening before moving to the fine stone.
I agree, use the sharpie trick mentioned above and you most likely see that you’re not keeping your angle right and instead of sharpening, you’re dulling the blade, it happened to me the first time I used the sharpmaker.
These do take some time and practice to get the hang of it.
Thank you, very good pointers. I will try that.
Does anyone still sell the little Sanrenmu 605?
