I just got two of them in. I ordered two of what is described as the yellow tint on product description page. Shipping took 3-4 weeks Both showed up bubble wrapped in a manila envelope with accessories. Battery, lanyard, O-rings, spare lens, charging cord.
I have some appointments but I will try and post a few pics at least until I can make vid showing UI since there looks like may be some confusion.
The JAXMNVE M3 is on left, followed by an OnTheRoad U16, and The New Wubenlight TO10Ron the right.
All three have usb charging, 16340 cells, magnetic bases, but all have very different UI’s and emitters.
I am working up some reviews, but it will be this coming weekend at earliest.
So far I like the little JAXMNVE M3 clone, but it does have a few things that could be improved upon. But at this price point, it’s really very very nice. More soon.
That’s just a place holder. They do that when they are out of stock. Check back later and it will be $13 again. (Or $26, depending if its on sale or not)
I did try that originally too and forgot to add it in my comment. But now that you asked I tried it again and after about 7-8 tries I finally double clicked it just right (from ON) to enter ramp. It seems to be a rapid double click and RELEASE…
(I thought you would have to hold in the button for ramping, that’s how my other ramping lights work)
…with this light to start in ramping you don’t hold the button down, when you release it ramps on its own (without pressing / holding the switch) Then a single click to stop and hold the level, another single click re-starts ramping again.
A double click during ramping toggles back to 3-mode.
A double click from the level that you stopped ramping at also toggles back to 3-mode
Ramping is smooth and quick, there’s no flashes or stops at highest or lowest levels.
Ramping memory: If you turn it off during ramping (long press) next time on will start in ramping again.
Nice video. I think this new UI is a big improvement over the first one. I often have trouble remembering on is a fast click and off is a long click. I get it mixed up sometimes. Lol.
I totally agree, I hate when they do that, (are you listening Olight?) it’s so confusing, especially when you have a bunch of different lights. Make it the same for on and off !
Although I prefer the other way around: Single click for on and off, long press to scroll the levels. I love it when you can just click the damn thing on and off, so simple, it just feels right, like an old maglite. I think that’s my favorite UI, it’s what the Thrunite TC20 has.
Note: Not sure if Olight has changed that, my S15 / S20 / S30 are pretty old, but they all have that crappy UI.
Thanks for the video Dirty_Pierre! It helped to solidify beam0 posts above about the UI! Much better than the light I have, that has the “old” UI!
The ramping seems “Crescendo”, as it doesn’t stop on bottom or top and it is not controlable by the user, although Crescendo has “blinks” to let one know it has reached the top or bottom!
I wish I was able to mod this light’s driver, it is pretty nice…
Thanks for the demonstration!
Hum, I have the S1R Baton (16340), and I like 2 things on its UI: you can jump to the Turbo 1 (600lm) with double click from OFF, and can enter Moonlight with press and hold. That way, despite you may have forgotten the last used mode, you can always start on the lowest mode
Actually, I wish other lights had the same UI! (direct access to ML and Turbo are a very big plus for me)
Your welcome, glad the video helps clarify the UI a little.
Yes, it is like crescendo, but a blink would be nice. The only control over the ramping is a single click to stop it, and it is a little hard to stop it exactly where you want it. A lower level low would be great too and shortcuts like olight, but for the $$ I’m not complaining.
The S1R has single click for ON and it will get ON on the last used mode.
When ON press and hold to cycle throught L>M>H.
To access ML its press and hold from OFF.
To access Turbo 1 (600lm) it’s a double click from ON or OFF and to access Turbo 2 (900lm) it is another double click when already on Turbo 1.
To get back from T2 to T1 its a double click.
To get to the regular modes, from T1 or T2, it’s just a press and hold, and it will cycle again through L>M>H
To lock the light, it’s a long press and hold (the light will turn ON in ML, and then shuts OFF. The switch will become red everytime it is pressed while locked!)
Despite I preferred to always start on Low, the possibility to start on ML is a very big plus.
