Does it use stock C8 reflector or a larger one ?
Cute-3/4
Ohh , nice ! I can’t wait to see it’s awesome cooling fins :sunglasses:
Now for the million Ruble question. Did you source a copper MCPCB compatible with cute-4?
No. Only aluminium.
PM Sent for a Copper spacer Ultrafire F13 for Ledil Cute-3 triple
P60 solid Cu 18350 neck+S2+ Cu pill
What exactly is this? Thought at first a complete head, but closer look it is not…
This is P60 compatible neck with S2+ threads inside that can accomodate 18350 cell itself. I.e. if you take L2m (short tube) and change stock neck with this one, you will get 18650 cell place (few cm shorter than regular neck + long tube).
With included pill you can build quad with carclo optics, but if you have shorter pill you can make a single led config with some reflector or optics. Threads inside allows you to adjust pill at right height.
Just WOW, please keep us posted Kirill !
Interested.
OK, so basically the head will screw on to it, and if you wanted you could just put a tail cap on it and it would be a 18350 light?
Right.
If I buy:
1x P60 solid Cu 18350 neck S2 Cu pill
1x P60 Surefire copper quad shelf – new version
Would you toss in 1x Discounted S2-S8 spacers with some burs?
Today arrived, super packed… :sunglasses:
I`m in for a Convoy m2 quad kit
Me too, in copper.
Put me down for the m2 quad, i counted with mosled mpcb… Probably go with a triple.
One question Kiriba, what its the exact size of hole in your spacers, in the c8 spacer for example?
It varies. Last year I tried to make it 4.0…4.2mm
Thank you, so i will drill the hole in 3,5 - 4.0mm.
Convoy m2 quad kit please
I’d be interested, sadly I don’t have a C8 around, but I do have an M8, are the head-side tube threads compatible?
What size should the 2mm glass be?
