Hello guys, i could use some help.
I have a Ganzo G704 (440 steel) and its getting due for a sharpening. I bought a Lansky sharpener Amazon.com
I tried to sharpen the knife but seems im making it more dull. Im swiping the knife as upright as i can, full length of the blade, first on the coarse rod, then on the less coarse.
What angle do these knifes come stock, 22.5? The options on the lansky is either 20 or 25. By now ive been swiping probably 50 times on each set of rods but my knife is far from sharp. Seems it was sharper before i started.
Your blade must be really dull? Or maybe you got a bad knife, it could happen.
Personally I like to use the Lansky Blade Medic when a blade is really dull. Use the carbide first with a controlled pressure (because it will remove metal quite a bit if too much pressure) to recreate a V-edge.
Otherwise I have good results with the Lansky 2 rod system like yours.
I use the 40 degree (2x20) settings on my Spyderco Sharpmaker for sharpening my Ganzo folders. So the 20 option should work at the Lansky too.
Do you keep the blade perpendicular to the base of the sharpener during sharpening? That’s the key of these V systems.
You should avoid adding too much pressure on the blade during the process.
Marking the edge with a sharpie (permanent marker) is also a good trick for checking the progress of sharpening and the angle. You must remove all of the permanent marker at the edge during sharpening before moving to the fine stone.
I agree, use the sharpie trick mentioned above and you most likely see that you’re not keeping your angle right and instead of sharpening, you’re dulling the blade, it happened to me the first time I used the sharpmaker.
These do take some time and practice to get the hang of it.
Best depends on what kind of knife you want and what you’ll be doing with it.
If by best, you mean good quality and smooth, then for regular EDC tasks, I would say that the Ganzo FB760x and the Y-Start JIN02 are probably some of the best axis locks under $20.
They are both well built and both are very smooth thanks to their bearings.
It’s nice for sure but I wouldn’t consider it the best.
Plus, with a knife this size, I actually find using the axis lock kind of awkward.
I have both the axis and liner lock versions of the 7063 and I actually prefer the liner lock on this one.
I also prefer the liner lock of 7063 but only because I really like its orange color :partying_face: Of all Chinese knives I used, SanRenMu 7063 has most razor like, thin blade, extremely good slicer.
