The SYNIOSBEAM - CFT90 recoil thrower
429 posts / 0 new
yclongthrow
Very interesting
Enderman
Enderman's picture
Last seen: 1 day 8 hours ago
MRsDNF wrote:
Bit lost for words. Beer
Big Smile
drood wrote:
Wow, I found it. Party It was elsewhere … Facepalm White Laser 20km Searchlight-WL-200W
Cool, I haven’t seen any of those laser lights yet in videos or IRL.
Nice to see companies exploring technologies other than LED Smile
The_Driver wrote:
No, this is actually not the case. Optimizing the XY-focus of my Project Excalibur light increased the luminous intensity. I think it depends on how small the LEad is compared to the reflector.
Maybe for a forward-facing reflector is is not, since the distance of the reflecting surface from the LED varies between very close and very far.
If you measure the lux in the spot created by an aspheric flashlight (the projected square) the lux is the same at all points, it is not higher in the middle.
So this suggests that light does not need to be coming directly from the center of the focal point.
A recoil reflector is somewhere in between a lens and a forward-facing reflector, in terms of distance form the LED and die projection sharpness.
Maybe you are correct in that case.
yclongthrow wrote:
Very interesting
Renders coming tonight! Smile
Enderman
Enderman's picture
PROTOTYPE REVISIONS
Revision 1 was designed using a 12” diameter 4” tall cake pan as the chassis. The low cost of the cake pan would have made this project a lot more affordable. However, this design was ultimately scrapped due to the lack of rigidity of the steel used in the pan, which would not protect the expensive mirror very well.
Revision 2 was changed to use 1/4” thick aluminum for both the body tube and the bottom, and was an intermediate stage in the design. In this design the reflector was held in by aluminum rings. To make the rings, two large 12”×12” aluminum sheets would have to be used, which was not very cost effective and would give difficulty in mounting the reflector rigidly while not damaging it.
Revision 3 was the runner-up to the chosen design, and uses a flat carbon fiber sheet to hold the LED in the center. This sheet would have similar rigidity to 1/4” thick aluminum while having less thickness and weight, since the original goal was to make the device only 4” thick. This design was not made due to the extra cost for the carbon fiber, which would cost approximately twice as much as aluminum. Carbon fiber would also increase the complexity of mounting it to the chassis, since holes cannot be drilled into the side due to delamination.
Revision 4 is the design that was chosen to build, and more renders can be found in the following section. This design also focuses the light by adjusting the position of the reflector, rather than the LED block. Due to it’s use of 1/4” aluminum instead of carbon fiber, the total height had to be increased from 4” to 4.25”.
Revision 5 was design to move the LED block up and down for focusing, rather than the reflector. The down side was that the glass would have to be removed every time the light needed to be focused. Mounting the LED cooling block within the arms and securing it also posed additional complications.
This design was made to fit a Turnigy 3S 65C 6000mAh LiPO battery pack, which I own several of and are used for other projects. Having a universal battery I could use for all my projects was appealing, however for this light, the goal was to keep it at around 4” thick, and using this battery added 1” of thickness. Another down side was that it complicated mounting of other internal components such as the reflector, but it also had the benefit that it allowed for a second cooling coil.
The final 7th revision was designed to fit many extra features, such as a built in LiPO charger, AC/DC converter for continuous operation, variable current power supply, and multi-pole switch. Not only would all these features added several hundred dollars to the design, but the thickness would need to increase to 6” which would no longer fit in a backpack for portability. Potential future prototypes will include features like these, however the first prototype will be much more basic.
Enderman
Enderman's picture
RENDERS
Virisenox_
Virisenox_'s picture
Last seen: 1 week 3 days ago
What are these rendered in?
Reviewer for ThorFire, Olight, Sofirn, and others.
More active on Reddit: /u/Virisenox_
"I go hard."
- Zeroair
"Don't quote me on that."
- Zeroair
Enderman
Enderman's picture
Almost all of them are 2d exported images from sketchup (free)
The last one is a real render done in solidworks.
I made a solidworks model after sketchup because I needed a way to make the drawings for the waterjetting and assembling the components more accurately.
Agro
Agro's picture
Last seen: 3 min 4 sec ago
No fins inside the water block?
Enderman
Enderman's picture
Way too complex to do, also not necessary for such low power LEDs.
Making microfins in there would probably make the blocks cost like $1000 rather than $100.
It might have helped if I decide to put a CFT90 in there later, but the project was already nearly 1.5-2x more expensive than I wanted it to be.
I could have probably gone with aluminum instead of copper to lower cost and still get decent performance, but what’s done is done Smile
Agro
Agro's picture
You don’t need microfins. I remember people were cutting them in CPU blocks with a hacksaw. Finer ones would work better here, but it’s not something very complex to make…
yclongthrow
Why does the reflector need a hole?
drood
drood's picture
Last seen: 1 week 6 days ago
He does not need it, but the manufacturer delivers it.
Pöbel
Pöbel's picture
While microfins or channels do reduce temps by some degrees, they are not needed. especially not if you are cooling just 10-15W.
I know that in the beginning of PC Watercooling we were cooling heavily overclocked CPUs which were also over volted to oblivion with simple aluminum blocks with just a round S-channel.
@Enderman
There is no reservoir visible in you CAD pictures. While bleeding is surely possible without one, it makes this task so much easier.
The_Driver
The_Driver's picture
Last seen: 1 week 1 hour ago
So awesome!
What about a handle or a tripod?
pscal
Last seen: 1 week 1 day ago
I like the space optimization, especially the copper pipe wound dissipation surface. Do you plan to secure the batteries in the carriers (i.e. velcro strap) to ensure they do not pop out if they encounter a sudden jolt?
Enderman
Enderman's picture
The block is 1” diameter. That channel is only 1/8” wide.
Any fins that fit in there would be called microfins IMO.
The smaller the details, the more expensive the machining cost gets Sad
It’s part of the manufacturing process, can’t get rid of it.
It also doesn’t matter since that part of the reflector is blocked by the LED MCPCB and cooling block anyway, so it would be unused even if there was no hole.
Correct Smile
@Enderman
Yeah I wanted the light to be usable in any orientation so I skipped a res (which could introduce bubbles) and will just fill/bleed it using an external container, then close the loop.
I’m not sure how much of an issue evaporation is going to be, but I guess we’ll find out with this prototype Silly
The_Driver wrote:
So awesome!
Thanks!
It will have a handle on the side as well as two 1/4” tripod mounts, one on the side and one on the bottom for vertical or horizontal use Smile
That’s something I will need to consider, it would be bad if one fell out and hit the reflector.
I just checked and the batteries fit extremely tightly inside the carriers, so I don’t think there’s any risk of them falling out, but for any long plane or road trips I think I would recommend removing batteries.
The battery carriers do have a small slot on the side that seems like it would fit a zip tie though, so maybe a small design modification by adding small washers between the carriers and the base plate will allow a zip tie to go around the carrier and make sure the battery is 100% secure Smile
EasyB
Last seen: 3 hours 18 min ago
With a reflector you have some axial averaging going on. If you put a pinhole in front of the reflector, like the method you used to focus your lens, you will see that the projected image of the LED rotates as you move the pinhole around the reflector. So at every point in the beam there are some areas of the reflector that are reflecting the dark cross (in four-die LEDs). This is what causes the beam intensity to be reduced, even outside of the donut hole. Also, I think for most LEDs the die luminance is a bit less near the edges, and averaging these areas will further reduce the beam intensity. On the other hand, with a single die in a reflector the center of the beam consists of images of the center of the die so you get high beam intensity.
Enderman
Enderman's picture
The projected image of the LED does not rotate.
It gets skewed/stretched depending on what angle the reflector “sees” it from, but it does not rotate.
With a lens, all the points are almost perfectly in front of the LED which is why you get a clear die projection, all the squares remain square.
EasyB
Enderman wrote:
The projected image of the LED does not rotate. It gets skewed/stretched depending on what angle the reflector “sees” it from, but it does not rotate. With a lens, all the points are almost perfectly in front of the LED which is why you get a clear die projection, all the squares remain square.
I just tried it and it does rotate.
Edit: as you move in a circle around the LED.
ImA4Wheelr
Last seen: 1 month 2 days ago
I like your style Enderman.  Very exciting project.  I probably missed it, but are you having the reflector custom made?  If yes, maybe they can quote a price for say 5 or 10 units.  Maybe it would be low enough for some members to want to by their own reflector so that they could make their own version of this monster thrower.  Of course you would want the manufacture to ship the individual units straight to the purchasers.
If someone wanted to go with a laser and remote phosphor, that center hole would be a wanted feature.  Powerful blue (445nm) lasers are cheap, but they don't emit a pinpoint of light.  Violet (405nm) would emit a nice pinpoint, but last I checked there are not any cheap high power versions of those available.
Lightbringer
Lightbringer's picture
Last seen: 55 min 50 sec ago
The_Driver wrote:
Enderman wrote:
Worst case scenario I will mod it with an XHP70.2 and see how it performs Smile
Also, Lexel recently developed a 20A driver. You could ask him if it’s possible to make a 30A one or combine two of them.
If you’re going to be using an XHP70.2, don’t forget that all 4 pins are brought out on the chip, +/- A and +/- B.
So you can have one driver power the A LEDs and another driver power the B LEDs.
Lightbringer
Was gonna suggest…
If you want a nice stiff and fairly lightweight frame for the reflector, you can go back to the cake-pan, but use what’s called “gorilla hair” and epoxy resin, and make your own fiberglass casing for it.
I know people who are into car audio, and instead of using ¾” thick wood slabs for speaker-enclosures, would use thin plywood, then GH+ER to build-up the wood and make it rock-hard, no vibrations.
Messy as Hell, though. Staple/Glue the sheet(s) of GH to the wood (depending how thick you want it), then get it sopping wet with ER, and let it all dry.
Dunno if you have anything close to you that can supply it, but something like this:
https://www.clausenautobody.com/proddetail.php?prod=claw-glas-mat
https://www.clausenautobody.com/proddetail.php?prod=gorilla-hair
And the resin, hardener, anything else you might need.
If you want the outside to still look nice and slick, apply the stuff to the inside of the pan.
Enderman
Enderman's picture
I’m not sure if I understand what you mean? As you move a point around the optic the LED always remains right side up:
If it rotated there would always be a flat side towards the center and the result would be a round spot when they all overlap.
As you know, the spot isn’t round but actually square.
If you put a quad-die LED behind a lens you get 4 individual die projections.
If someone wanted to go with a laser and remote phosphor, that center hole would be a wanted feature.  Powerful blue (445nm) lasers are cheap, but they don’t emit a pinpoint of light.  Violet (405nm) would emit a nice pinpoint, but last I checked there are not any cheap high power versions of those available.
It’s a stock option from Phoenix Electroforms, but they didn’t have any in stock so they did need to produce a batch for me.
Even for 10 units I doubt you would get a deal below $250 USD each, especially since they need to add some sort of mount to it.
With remote phosphor there are two configurations, through and reflected.
With the ‘reflected’ option, the laser would be behind the reflector and shine through the hole.
With the ‘through’ option, the laser would be in front of the reflector shining through the phosphor.
According to Crytur the ‘through’ option yields higher intensity, but I have not yet found any test data for laser-phosphor intensity.
You’re right Smile
Would be great if the CFT90 had that feature huh…
Lightbringer wrote:
Was gonna suggest…
Composites are a good idea, but I think the choice to go with aluminum was good because mounting things inside is far easier when you can simply drill and tap a hole for a screw anywhere.
In the prototype revisions I considered carbon fiber for the front spider but decided against it because it would just be added complication to cut and mount.
EasyB
Yes, but I thought we were talking about reflectors. I would think your recoil reflector will behave similarly to my C8 reflector in that it will average the dies and dark cross. Just trying to save you some time and energy because you will be disappointed with the lux of a four die led in a reflector if you are expecting 100+ effective cd/mm^2.
Agro
Agro's picture
How about mounting the water block directly to the lens, leaving just 1 arm with colling/power connections to reduce the blocked surface?
Lightbringer
That was my point, that you could even keep the (flimsy) cake-pan as the inside or outside, and just coat the outside or inside with the ad hoc fiberglass.
But a nice thick coating of fiberglass is hard without being too brittle, so you can absolutely drill holes in it just fine. (That’s how they mount crossovers, spring-terminals, etc., on the speaker boxes.)
Enderman
Enderman's picture
Well ok, I know the XHP70.2 isn’t good for throw but it would give a nice bright beam Smile
Anyway, that’s just worst case scenario, ideally it will be a CFT90.
A good idea, however I decided against it because I needed to run two cables, two tubing lines, and a temperature probe.
This much stuff will block a lot of light unless I stack them together, in which case I would need about 1/2” arm going to the middle.
At the time the closest I found that was still affordable was a hollow rectangular tube of .75”×1” carbon fiber.
This would take up the same space as 3× .25” arms and just make centering and mounting it more difficult, so I decided to just use a single piece of aluminum and 3× .25” arms Smile
Also, another problem with stacking the tubing and wires is that I only have ~1/2”-3/4” of space between the glass and edge of the reflector so if I stacked all of them I would need to make the entire light thicker.
Lightbringer wrote:
That was my point, that you could even keep the (flimsy) cake-pan as the inside or outside, and just coat the outside or inside with the ad hoc fiberglass. But a nice thick coating of fiberglass is hard without being too brittle, so you can absolutely drill holes in it just fine. (That’s how they mount crossovers, spring-terminals, etc., on the speaker boxes.)
I don’t think you can tap holes into carbon fiber or fiberglass though.
ImA4Wheelr
Enderman wrote:
It's a stock option from Phoenix Electroforms, but they didn't have any in stock so they did need to produce a batch for me. Even for 10 units I doubt you would get a deal below $250 USD each, especially since they need to add some sort of mount to it.
With remote phosphor there are two configurations, through and reflected. With the 'reflected' option, the laser would be behind the reflector and shine through the hole. With the 'through' option, the laser would be in front of the reflector shining through the phosphor. According to Crytur the 'through' option yields higher intensity, but I have not yet found any test data for laser-phosphor intensity.
Thanks for the info Enderman.  Best wishes on your build.
Enderman
Enderman's picture
You’re welcome, and thanks Smile
Phoenix was a pleasure to work with btw, very affordable too.
Lightbringer
T-nuts.
Enderman
Enderman's picture
Lightbringer wrote:
T-nuts.
Ah good idea.
Another thing I forgot to mention is that I wanted it to be metal because that’s what cools the fluid, copper pipes running on the inside of the body.
This may not always be the case for future builds though.
