Boruit Headlamp Review D10 (aka. EHL0628) - King of the Budget Headlamps?
So if you’re using it on level 1 out of 5, the lowest level, and you have to turn it off, it won’t turn back on at the same low setting?
So basically, it has no memory.
That’s it JasonWW :wink: It will always turn ON on Medium!
Its too bad some of these lights are getting little complicated for the everyday wife/younger person/regular weekend camper.
I can see them remembering the functionality if they use it for a long time and if this is the only light they have, to avoid muscle memory confusion.
IMO so many of these newer flashlights arent made for the everyday person due to UI,
What size mcpcb does it use?
i have got some spare MPCB’s from S2+ mod’s, it might be nice to swap in one of those
:wink:
Thank you Mascaratum, but is it 16 or 20 mm?
It’s 20mm :wink: Sorry, I forgot to indicate the measures! :person_facepalming:
With this light you can do one click on and one click off. So even if you don’t remember how to control it, it is still functional.
All you have to remember is try dbl click, try press and hold and see what happens. True for any light.
I have the Acebeam H10, and it is as simple as it gets, but it is not a cheap headlight though: press and hold to ON/OFF and it will turn ON in the last used mode (from 5 modes: ML-L-M-H-T). No blinkies, nothing to get in the way.
This headlight being reviewed here is not complicated, but I do understand what you mean. However, there are always other options to fit one’s necessity and “capability” to operate the light :wink:
which light you have on the left in the second picture?
20 mm. But 16 will be OK. You just need to extend one of the wires.
You must be talking to me (2nd pic in the O.P.). It’s the BLF Edition SA-22 Starry Light 4xAA, XM-L2 3C.
-Garry
Yeah, the UI can be a little difficult for one person to describe and another to understand. It basically has 3 mode groups: the “Medium & High” that a single click enters, the “Stepped Ramping” which is entered from EITHER the first mode group’s Medium or High, and then the blinky modes entered by a quick Double-click at anytime. From the “Stepped Ramping” mode group, one click brings you back to the first mode group (whichever level you were in prior to entering mode group 2), and then another click to go OFF.
-Garry
One think that may be important to make some decisions about this light (for those who may be interested):
Weight and dimensions:
Just filed a pebbled TIR - the upper lateral edges - and it fits perfectly!
It completely eliminates the hotspot tint shift that the headlamp had originally!
Thanks for the tips on this! :wink:
Sounds like a decent enough light, but I agree, what an absolutely hideous UI.
I’d look into completely stripping the guts from it, using a micro powerbank charging board to keep internal charging, then replace the driver with something decent. If the switch is momentary, maybe pilfer the driver from an e-switch light.
And as long as it wouldn’t mung anything else, bore out the emitter area to fit a real 20mm TIR, vs having to shave down every one I’d want to try/use.
I don’t understand why the UI is so hideous! I mean, do you always need instant access to every possible output? This isn’t a light I would want coming on with a very low level. The average “muggle” can give it one click, have a nice usable output, then click again to turn off.
-Garry
It has a very simple and logical interface. Its charger is assembled at 4057, why and for what to change it?
Yes, he has a fet-driver. Simple and reliable. He does his job well. But if you can make for it an inexpensive driver with stabilization, minimum leakage currents and with a programmable interface, then we will be very happy. Yes, a cool driver for a flashlight for ten bucks :wink:
And yes, switch is momentary.
Who said anything about “instant access to every possible mode”?
I don’t understand why a headlamp would need strobe, beacon(!), other blinkies. Long-clicks, double-clicks, short-clicks, click-from-on, click-from-off, click-from-strobe… good God, talk about convoluted! It’s like 30 people designed the UI, each with his own unique idea of what it “should be like”.
Have either steps or ramping, and just have the damned thing remember its last-used mode. Simple on/off with a click, and whatever machinations to increase/decrease brightness. That’s a UI for a headlamp.
Anyone who puts blinkies into a headlamp should be dragged into an alley and beaten with sticks.
Lightbringer, like you, I don’t like blinkies! And I will not defend this “cheap, bugdet, it’s-good-but-it’s-not-the-ultimate-headlight-in-the-world”!
BUT, the blinkies are all hidden through a “real”, “intentional” double click to activate those modes!
Also, you will always know in which mode the light will turn ON, and that’s on Medium, because that is the only mode that has been memorized in this light!
More than that: if you just want to use the light with 1 mode, you can: single click for ON (turns ON on Medium) > wait more than 2 seconds > single click for OFF. Simple! :wink:
If you want a higher output: single click for ON (turns ON on Medium) > single click for High > Single click for OFF. Simple! :wink:
This is as simple as it can be regarding to that!
For ramping, just press and hold from any regular mode!!
Yes, I would like to ramp up, but this ramps down till the lowest and then goes back to the highest mode. And then goes down again. 5>4>3>2>1>5>4>3>2>1……
And no blinkies in the middle. Just if you want! And if you want, you can select them: double click for Strobe > double click for SOS > double click for Beacon > single click for OFF or double click for Strobe > and when on Strobe, single click for the last used mode! If when on Strobe will make a long press, when you release it, the light will turn OFF :wink:
So, I guess this is not perfect! But it is not a headache to make this work! And you and I know we’ve seen and taste worst UIs than this one :smiling_imp:
