How does the step down work in ramping mode? If it’s at its full brightness, does it still step down after a couple of minutes? And to what level does it step down?
Thanks for posting that. It only mentions Turbo and High being reduced; I don’t see anything about what happens in ramping mode. Can I assume that when it is ramped up to those levels, it will also be reduced automatically?
When ramping high is about 1000 lumens and low is Moonlight mode which is about 1 lumen. After three minutes it looks like medium mode. Double click for turbo. After three minutes it goes down to medium mode but stays at 900 lumens for about a minute. Does this answer your question?
Thanks, 264. That does help. Since medium is 160 lumens, that’s what I’d have to work with most of the time. My Coast polysteel 250 will serve me better.
After 4 clicks my flashlight blinks twice signifying flashlight is locked out. Everytime you press the button the flashlight blinks twice till you repeat the 4 fast clicks to unlock the light.
Hum, d_t_a was mentioning to activate lockout while the strobe is ON!
When the light is OFF, mine behaves like you described
But when the strobe is ON, if the lockout is activated, it remains like that, the light gets locked and then you cant turn Strobe OFF.
Unless with 4 clicks to lock-out or unscrewing the threads !
Hum, that may be a bug of all of them!
Maybe some other users can give input on this to see if it is a “random” bug of a “unexpected” bug!
Thanks for confirming 264
