UI might not be as abysmal as I thought at first impression, but it’s still a faux-simple. RampingUI is just as “simple” when you think of it, but it actually quite elaborate enough to make people stop and wonder how they’ll get to the mode they want
Well I’ll agree on the fact that the blinkies don’t belong in a headlamp at all; I guess I’m not bothered because they are so well hidden (heck, I didn’t even realize there was SOS and Beacon). No sense continuing to argue on whether or not this UI is perfect or not as many will have their own ideas of what the perfect headlamp UI is.
I’m too afraid to ruin a good light to pull the driver out. I would bet the output could be modded with changing/adding current sense resistors, but honestly I wouldn’t want any more current than it already draws (1.87A on high).
-Garry
For anyone wondering why a headlamp would have any blinking modes, you have to remember all the different uses for a headlamp. Some people, like myself, only use them for close-up work such as out to 5 or maybe 10ft. Other people may use them for walking through the woods or jogging on the street. For a jogger, the strobe or beacon may be considered a safety feature to keep them from being hit by a car.
We now have headlamps with xhp70.2 and 3,000 lumen. What is that for? Who needs it? Lol
And that’s why I do my absolute best to avoid them…
Are people hatin on the boruit? Don’t do that. This is like the best bargain headlight on the market. If somebody wants to hate, they can go hate on all the the truly crappy headlights out there.
I’m not hating by any means (well, I hate the UI, but not the product as as whole), it’s even on my aliexpress cart right now, just waiting for me to choose what batteries I’ll try to get from Elfeland since they showed up with free shipping to Brazil (odd, probably won’t ship and I’ll have to ask for a refund, but why not try it?), so I’ll be ordering either this light or the RJ-02 by tomorrow
Well, after making peace with xp-l emitters following a nichia spree, guess I’m a UI snob now
You kidding? I recently changed my name to RJ02. I just despise the sound of this particular UI.
Does it seem like a non - e-switch driver could be swapped into it? Although the usb charging feature might be lost? It looks like a decent host to handle some heat within normal current limits and for shorter periods of time. Having crescendo or some kind of ramping firmware could be useful. I'm looking for a moderate thrower with some useful spill. Other than swapping the mcpcb, does anyone see this light as a host with other potential for mods? or just a good value as it stands? That depends on the intended end product, but I'm thinking at least a dedomed xm-l2 with 2.5-3ish output on high for maybe 90 seconds max if possible. I haven't modded too many headlamps, so that might be more current than necessary though. My goal is something like 100yards of visibility or more and a non-pencil beam. Does anyone think it could handle an xhp50 or xhp35 with the right driver and wattage, or is that pushing the limits for your every-day modder (without a lathe, tons of experience, and the ability to mold copper to your will)? This is BLF, but are you better off spending more if upping the output and throw is the end game? I mean, crazier things have been done before, and I applaud that:
Thank you
Does it seem like a non - e-switch driver could be swapped into it? Although the usb charging feature might be lost? It looks like a decent host to handle some heat within normal current limits and for shorter periods of time. Having crescendo or some kind of ramping firmware could be useful. I’m looking for a moderate thrower with some useful spill. Other than swapping the mcpcb, does anyone see this light as a host with other potential for mods? or just a good value as it stands? That depends on the intended end product, but I’m thinking at least a dedomed xm-l2 with 2.5-3ish output on high for maybe 90 seconds max if possible. I haven’t modded too many headlamps, so that might be more current than necessary though. My goal is something like 100yards of visibility or more and a non-pencil beam. Does anyone think it could handle an xhp50 or xhp35 with the right driver and wattage, or is that pushing the limits for your every-day modder (without a lathe, tons of experience, and the ability to mold copper to your will)? This is BLF, but are you better off spending more if upping the output and throw is the end game? I mean, crazier things have been done before, and I applaud that.
If you don’t mind losing the usb charging, the Crelant CH10 that I got seems to be a good candidate for modding. It’s uses an e-switch so you can run a pretty conventional driver. A FET with NarsilM for instance. They can be had with a variety of genuine cree emitters in different tints. You would probably need to swap it to a top of the line DTP mcpcb, though. Overall, it’s a pretty beefy aluminum design so it can handle the heat well.
This new Boruit looks a bit tricky to mod due the switch being on the driver. Maybe it’s got another pcb behind the first one that is the actual driver? Maybe. If so, then it might make a good host.
Lexel will be coming out with his own boost drivers soon that will run NarsilM. It should be able to do up to 3A at 12v or 6A at 6v.
So if your thinking about using an xhp35/50/70 I’d wait to see how big his drivers are, then choose a host it will fit in.
I am certainly not hating on Boruit, they make “good enough” lights for the normal flashoholic. However, even if the blinkies are hidden, a non-flashoholic can easily get flustered by accidentally getting to them. If this light was for my use, i would be fine with the hidden modes….but its not for my use.
My wife or my 11 yr old wont remember what the different clicks, rates of clicking, long clicks etc are.
The regular non flashlight interested person just go by simple clicks……and ever time you click it gets brighter, in a round robin kind of way without blinkies coming in the way.
All im saying is that some lights dont have a simple fool proof UI, even if its simple to most or all of you. Not hating on boruit, just an opinion.
Thanks for the review garrybunk! Looks like a good budget headlamp. Does it have low voltage protection?
Yes, low voltage indication (blinks) and auto-off.
Whoops! I have it in my notes, just forgot to post. According to my testing (and trying to pull the cell to measure voltage quickly) it seems to trigger 3 slow flashes at 3.00v but keeps running at regular ouput (no stepdown) and I don’t believe it flashes again - just shuts down when it reaches about 2.70v. That shut-off level might be a little low for some cells.
-Garry
P.S. - I’ll add this to the O.P.
Yesterday I used this light intensively (almost 7hours, with some interruptions) and I must say I am really pleased with it! I used it with a protected 18650 and mostly on medium mode (sometimes used the “high medium” and “turbo”).
The best part for me is to know that when switching ON it will always start on the same level and that with a fast click I can raise the output to the Highest mode.
Also, the simple “click” to ON is very pleasant!
Only once I accidentally turned the Strobe ON when making a fast click. The stock headband feels good on the forehead and despite this is not the lightest flashlight, it doesn’t feel heavy.
The tint with a pebbled TIR lens is indeed more pleasant and it worked well when used against non-white objects.
I now love lights without memory meaning I know exactly what mode a light will come on in. You see, the problem is that my memory isn’t as good as the driver’s memory - I can’t remember what the last mode I used was when I turn it on again!
-Garry
I got mine in today. Ordered on Feb 5th and go it 10 days later. Really fast!
It is quite nice. Not heavy at all. It’s surprisingly light and doesn’t really need the 3rd strap over the top.
I’m pretty sure it’s less blue tinted than the RJ02. I don’t have it handy to compare them. It’s a nice white, though.
The UI is great. No problems at all using it.
I had to install the 60° tir from MTN Electronics. The stock reflector is 18.8mm wide as mentioned before and about 10.5mm tall. The tir is about 19.7mm wide and 11.8 tall. So I filed it down some to make it fit. I filed the edges and the narrow bottom. I removed the plastic centering ring. The tir sits on top of the white emitter package, not the mcpcb. This seems okay.
I got the optional Boruit 4,000mah battery as well. It’s only 67mm long which is pretty short for a “protected” cell. Maybe it is protected, maybe it isn’t. I can’t say for sure.
Here it is next to a Evva protected Panasonic NCR18650B at 69.5mm.
I’ll be testing it’s capacity soon.
I ran the Boruit battery down until the light turned off. That should be 2.70 volts, but when I measured it, it was 2.78v. Then several minutes later it showed 3.2v.
I put it in the Miboxer C4-12 charger at 3.2v and it very quickly started charging. Internal resistance showed 98 ohm. Capacity ended up being 1570mah. I was hoping for at least 2200 or so. Oh well, it was only about $2 extra.
Glad to hear you like the light!
-Garry
