[♛ FreemeGB] ASTROLUX MF04S (XHP70.2) & MF04 (XHP35 HI) - Official Group Buy Thread - 【 $150 】
1120 posts / 0 new
freeme
freeme's picture
Last seen: 10 hours 12 min ago
1) ASTROLUX MF04S CREE XHP70.2 6000lm 1549m Searchlight Group Buy
✪ Official Group Buy Thread
Group Buy Price: $1X9 ( $239 )
Coupon:  CONTACT US
Flash Deal Price:
$XXX ( $239 )
©freeme
Beam shots
Specifications
Features:
1. Compare with Astrolux MF04 about illumination:
    1). MF04 utilize XHP35-HI LED without jelly to be a long-range concentrator
    2). MF04S works with XHP70.2 LED but not a "HI" lamp bead, reach stronger flooding effect
    3). MF04 mains long range with 2416 Meters 2700 Lumens
    4). MF04S mains professional floodling effect with 1549 Meters high lumens up to 6000 Lumens!!
2. Compare with Astrolux MF04, the driver and circuit design is more mature and stable
     1). MF04 has only 4 brightness files
     2). MF04S has 4 brightness files and 3 special modes
3. High efficiency constant current circuit and Integration optical lens
4. Large-diameter reflector cups make the light gathering ability stronger, and the light intensity is greatly improved
5. Memory function in brightness mode. When the flashlight is turned on again, the mode will stay in the mode which was last turned off
6. Intelligent temperature control design, automatically reduce lumen output when temperature is higher than 55℃ in turbo knurling design
7. Breathing switch function: Monitor working process of battery capacity and voltage
8. Added a PTZ screw hole on the head to fix standard 1/4 inch Tripod mount
9. Head fin adjustment and design to speed up heat emission
10. Configure a strap to make your trip more convenient
11. Handle, switch button and gravity control, is more ergonomic to facilitate your operation
12. Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish
13. IPX-7 standard waterproof, can be used in rainstrorms
Operation:
1. Light on/off: Press the side switch to turn the light on/off
2. High mode: Normal mode clicks three times
3. Lockout mode: When the flashlight is off, long press to turn off the breathing light and lock out
    Under the lockout mode, long press to unlock it
4. Click twice in Light off or Normal mode, to enter TURBO and clicks three times to enter TACTICAL STROBE
5. Normal mode will be memorized
Notes:
1. Battery Configurations: Sumsung 30Q 3000mAh 20A Battery Recommended
   (If the battery is not enough current, it won't drive the flashlight up or the light will be weaker)
2. Do not disassemble the lamp head, otherwise it is easy to destroy the bulb
3. In order to reduce weight, the original battery holder is made of aluminum alloy.(But it is common with the brassiness battery holder of MF01 MF0.)
Package included:
1 x Astrolux MF04S XHP70.2 Flooding Flashlight
2 x Spare waterproof O-rings
1 x Lanyard
1 x Strap
1 x User manual
Edited by: freeme on 02/21/2019 - 08:13
freeme
freeme's picture
2) ASTROLUX MF04 CREE XHP35 HI 2700lm 2416m Searchlight Group Buy
©freemex1thedeals.com
Group Buy Price: $1X9 ( $219 )
Coupon:  CONTACT US
Flash Deal Price:
$150 ( $219 )
©freeme
Astrolux MF04 LED Flashlight Head Lens Protective Holster Protecting Flashlight Bag
Price: $8.69 $12.50 )
Coupon:   FMF4B
Break open views.
ASTROLUX MF04 - Business End
MF04 Prototype uses aluminium contact plates on both ends for it battery carrier design, and and tamper proof security screws to secure all five rods. I was told that center column (for anode) was made of pure copper.
Comparison of battery carrier designs for MF01 (Left), MF04 (center) and MF02 (right). Please note that all three models are prototype but they are near production grade.
Note: actual retail design might differ a little.
Most frequent asked question: Will it fit?
I did manage to squeeze in a pair of 69.6mm long protected 18650 into the carrier. Unprotected flat top 18650 is also supported, just ensure you load them according to its polarity indicated on the PCB board.
Package comes with 2x spare waterproof O-rings, 1x lanyard, 1x shoulder strap, 1x mounting screw 1/4", and user manual.
You can mount the light to a tripod or light stand to allow handsfree operation. Please take note that there might not be enough clearance at the neck, if you are using a big size mounting plate.
MF04 being strap on - I used cable shrink tubes on the clips to prevent anodized coating from wearing off.
Silicon button is now at 10mm diameter. 2mm bigger in size, feels more comfortable to press, and protrude less than MF02 and MF01.
Expect same 2S2P 8.4V configuration as MF02 and MF01.
New addition to ASTROLUX MF series
Combined weight of ASTROLUX MF04 with 4 pieces of unprotected 18650 batteries.
Modest collection high lumens throwers.
Inner diameter value (widest end) of each reflector. MF02 retail version has upgraded its ID to 72mm.
BEAMSHOTS
Initial test result for ASTROLUX MF04 Runtime in TURBO mode at 29°C/ 84.2°F ambient temperature. Mini usb box fan was used to provide light breeze for the light at 30cm distance.
Temperature was about 43°C/ 109°F at about 5.5min mark. There is definitely room to sustain the high output longer.
Did a runtime test for MF04 (prototype) with four pieces of SONY US18650VTC6 3000mAh 3.7V 18650s. MF04 output dropped to 63% from 100% after 8mins, and stayed plateau for another 110mins or so before shutting down itself. Total runtime in TUBRO mode was about 2 solid hrs (126mins) based on 4x 3000mAh rated cells.
Runtime for other levels will be included in soon.
T1) Attempt to re-trigger TURBO after about one minute from first automatic stepdown.
T2) TURBO re-triggered for the second time.
Event A) Discovered that my cooling fan was blowing off axis because the cable got caught with the door when closed. That could probably explain why first stepdown occurred few seconds earlier. Output increased by 5% (peak) after cooling was restored.
T3) Has slightly shorter TURBO duration compared to T1 and T2. Could be due to temperate controller restricting the output.
T4) TURBO re-triggered for the fourth time after 3min interval from previous stepdown. TURBO is able to sustain for approximately 2mins when it was given more time to cool down.
-- ASTROLUX PRODUCTS --
Express Your Interest Below
ASTROLUX projects that we have assisted in the past:
(2018) ASTROLUX MF04s 21700 - June 2018
(2018) ASTROLUX MF04 completed
(2017) ASTROLUX MF02 XHP35 HI 3,000lm completed
(2017) ASTROLUX MF01 18* NICHIA 219C / XPG-3 12,000lm completed
(2016) ASTROLUX S41S 4* NICHIA 219C/ XP-G3/ XP-G2 Stainless steel completed
freeme
freeme's picture
Early BIRDs will enjoy the lowest price (now).
 ALERT : Price is scheduled increase after 100pcs!!!
Interest List:
MF04S (70.2)
MF04 (35HI)
  1. Freeme
  1. RT--
  2. southland
  3. Agro
  4. Charga
  5. yasenf
  6. Pöbel
  7. Mr.Beam
  8. g_sintornillos
  9. LEDtec
  10. AlexGT
  11. hunter1
  12. 777
  13. Phantom1
  14. M78
  15. Itsme
  16. Sukoi
  17. Athlon2350
  18. CASHESVALLEY
  19. CJ Avlis
  20. Glov
  21. Flying Luminosity
  22. ramptosd
  23. adsum
  24. warzi1975
  25. FlashIight
  26. netprince
  27. vagelis17
  28. firstcipher
  29. Blazer296
  30. pustelnik
  31. Petroleum Lantern Guy
  32. ohbreeeezy
  33. GozonM
  34. Tender
  35. Bill_tong
  36. BT100
  37. BorisBar
  38. wstrachan
  39. RobertB
  40. Bruno28
  41. Nicolicous
  42. djypo
  43. Marcello
  44. Bam35
  45. lcortez321
  46. troisanh
  47. shirnask
  48. rizky_p
  49. DENGOH
  50. Silent_Star
  51. Mstevens113
  52. Jtm94
  53. TuKamilCZ
  54. yclongthrow
  55. tommydadog
  56. pooptoast
  57. contigo
  58. sledge0816
  59. fireblade893
  60. bjs55
  61. Nicolaas
  62. arficus
  63. lcortez321
  64. Bhevo47
  65. pirate joe 22
  66. dmprice79
  67. sportlampa
  68. Fatlight
  69. crazylite
  70. jmbow24
  71. camelight
  72. firedome
  73. shan6oob
  74. Glenn7
  75. mmalive
  76. mmalive
  77. Rylee900
  78. Rylee900
  79. hippotomato
  80. StumpFarm
  81. sherman2k
  82. eigenmeat
  83. lcortez321
  84. slow2go
  85. slow2go
  86. cheffernan
  87. zoysiamo
  88. Hardusvd70
  89. Clarence222
  90. opbigdave
  91. Nev
  92. td1042k
  93. Newdaddy46052
  94. nottawhackjob
  95. suratyu
  96. turkey
  97. octav
  98. ErrolRS
  99. blueb8llz
  100. panagis
  101. Hollywood
  102. chakrawal
  103. Grigs68
  104. Jiffy
  105. ryanferg
  106. Natopsi
  107. TerryK
  108. Bungle88
  109. Th558
  110. torchmanSp1111
  111. akoposilester
  112. jimmy23
  113. Muto
  114. aors10
  115. WelshDan
  116. Tredd
  117. mrheosuper
  118. kodachrome
  119. mikey1299
  120. Mattfox27
  121. phant65
  122. Subiext73
  123. JEK
  124. LichtAn
  125. Redlyne22
  126. stfc69
  127. Bungle88
  128. Kysumi
  129. avani733
  130. LichtAn
  131. Rusty Joe
  132. bibin
  133. Sebastianzon
  134. surasakkongtha
  135. mgmint
  136. thebaum
  137. 808Hi
  138. LenZ
  139. Soldier
  140. BobTB
  141. Mord_Fustang
  142. lawrnk
  143. mgracia85
  144. racnigel
  145. jturn480
  146. Hezekiel
  147. solRNY
  148. Ilmatic
  149. sienna
  150. Tim S.
  151. td1042k
  152. Micmania
  153. Narwhals
  154. Speed4goal
  155. ERDOS
  156. Tjhosan
  157. a_idoux
  158. franktv
  159. Xenovora
  160. gabby85
  161. Plat
  162. bdogsp
  163. lawallac
  164. GoMeR
  165. FlashTom
  166. pcmunson
  167. Bigtruckin78
  168. Tombird83
  169. WhitedragonBC
  170. Duke
  171. signas
  172. T18
  173. LenZ
  174. BOMBAY
  175. wiley07
  176. pustelnik
  177. JordanZHP
  178. Caleb-v
  179. Macka17
  180. Rusty Joe
  181. TheAuditor
  182. bucky
  183. Smokecutter
  184. kommessy
  185. MRsDNF
  186. TheAuditor
  187. KawiBoy1428
  188. alejandrov
  189. albaby
  190. gorb507
  191. JayLumen
  192. cannonball1000 #372
  193. kiany1212
  194. rafalklis
  195. klrman
  196. Rylee900
  197. dodo
  198. Jkevind11
  199. Newlumen
  200. krammer
  201. danallen
  202. southland
  203. cloggy
  204. Maverick1947
  205. tmx009
  206. cannonball1000
  207. Spacegrass
  208. vik267777
  209. FlashPilot
  210. noboneshotdog
  211. richnpc
  212. jazzyone1212
  213. DB Custom
  214. JLAu
  215. Tdh66
  216. Gofer
  217. alevana
  218. firedome #451
  219. nofearek9
  220. manu
  221. blinks
  222. Will_636
  223. koti
  224. wiley07
  225. franktv
  226. Kratomas33
  227. wheremydonky
  228. prilo
  229. shayne21
  230. timsandtoms #537
  231. casi29061965
  232. atbglenn
RT--
Last seen: 2 weeks 5 days ago
Interested!
southland
southland's picture
Last seen: 11 hours 59 min ago
I’m in for a couple or four but it all depends on price.
Agro
Last seen: 2 hours 53 min ago
In, depending on price and specs review results.
Charga
Charga's picture
Last seen: 5 hours 3 min ago
In!
' Lumen est omen '
Hope is no option!
yasenf
Last seen: 2 days 22 hours ago
In
Pöbel
Pöbel's picture
Last seen: 4 hours 53 min ago
bring it on Smile
Mr.Beam
Mr.Beam's picture
Last seen: 1 month 1 week ago
interested in 2 Smile
g_sintornillos
g_sintornillos's picture
Last seen: 7 months 1 week ago
I am interested depending on final price
If the final price is good the final decision will depend on some reviews
Sorry for my bad English (gogole transtorla)
LEDtec
Last seen: 2 days 17 hours ago
interested
AlexGT
AlexGT's picture
Last seen: 1 hour 50 min ago
Interested
hunter1
hunter1's picture
Last seen: 4 days 1 hour ago
Interested, depending on price and specifications.
777
Last seen: 10 months 1 week ago
Interested
Phantom1
Last seen: 1 month 6 days ago
Interested
M78
Last seen: 1 day 15 hours ago
Interested
Itsme
Last seen: 1 day 9 hours ago
Interested
Sukoi
Last seen: 1 month 4 weeks ago
Interested
Athlon2350
Last seen: 2 hours 25 min ago
Interested.
CASHESVALLEY
Interested…
CJ Avlis
Last seen: 1 day 2 hours ago
Interested
Glov
Last seen: 4 hours 26 min ago
Flying Luminosity
Flying Luminosity's picture
Last seen: 1 week 1 day ago
Interested
ramptosd
Last seen: 4 hours 7 min ago
Interested, thanks!
adsum
adsum's picture
Last seen: 2 hours 24 min ago
Interested
warzi1975
Last seen: 2 hours 52 sec ago
I´m in for two lights.
Thx
Robert
FlashIight
FlashIight's picture
Interested.
netprince
Last seen: 1 hour 41 min ago
I’m interested in price and specs…
vagelis17
Last seen: 1 month 5 days ago
Interested dependent on price.
firstcipher
Last seen: 4 hours 21 min ago
Interested depending on the price.
