UV triple using Sofirn C8F
Even postage stamps have UV stripes now.
The SST-10 has a very high forward voltage, on DD you can get to about 1,3A before you run out of battery voltage
to push to 2A you need more than 4.2V
Cool build and well done on finding and fitting the filter!
Yes, in this host with the excellent DTP ledboard it is probably (what this led does longterm on higher-than-specs current is unknown of course) no problem at al driving the SST-10’s at direct drive.
I did not realise that it peaked back then. In fact there’s better and easier emitters now, there is good reason to make some awesome UV lights right now, like your C8F.
I have tested another couple of 365nm leds, including your LZ1, some do not disappoint, will post the tests soon!
I really enjoyed your build and the story behind it. Thanks for sharing, I have never approached a UV build before because I am still learning about UV emitters. This post really helped.
I originally thought of doing this before with one of my hosts, but after realizing the potential eye damage and all the hazards that go with it, I scrapped the project. With today’s new breed of 365nm UV LEDs from Luminus, LG, Nichia, LITE-ON, Seoul Voisys, etc., a single UV LED is more than enough for counterfeit currency detection and for most of our needs. Unless, you’re a geologist or you’re doing specialized work, a C8F with triple UV LED is an overkill and makes little sense.
Thanks for the comments guys. I guess you are telling me I should not be afraid of running it on Turbo. I will let you know if I have problems.
In general I agree. I probably would not have thought of trying this except for the BLF people who always want to try something new and different.
That is an excellent motivation to build it! :smiley: :beer:
For bragging rights, sure…but tell me that when you accidentally bounce the UV light right to your own eyes and you’re not wearing your protection googles. It is easy to talk about precaution on the internet but it is also easy to make a mistake and shoot yourself in the foot.
If you accidentally forget your protection glasses and some or more light bounces back into your eyes, you do not immediately have a problem. In my case at least my retina’s start hurting violently which is warning enough, I have not noticed any short- or longterm effects of that happening every once in a while. Just do not make it a habit.
Anyone ever measure how much the come-with front glass eats the UV content if you’re not using a ZWB filter?
Imagine it ain’t quartz, but generic Mystery Glass.
It would be about the same loss as visible light, so a few percent, say 5. The cut-off wavelength of glass is much lower than 365nm, about 300.
Up to now I only own a single UV light (S2+) and I’m still afraid of hurting my and my families eyes, read something about long term macula degeneration, bought safety glasses therefore. So I’m not sure whether it’s a good idea to use filters, since without them it’s easier to detect if the light is on.
@Scientist
I like your avatar, would also fit me pretty well … :smiley:
I am interested in building a high power C band source. My intent is sterilization (not mine).
From research it appears that there are various sources of broad band emitters in this band. For killing bacteria and fungus, this area seems to be the sweet spot. The more power the better.
It needs to be reasonably hand held. But I am looking at the idea of a “whole room” sterilization.
The impetus for this are multi-fold.
People have fungus problems in the house. This could deal with the infestation if set in an area with said fungal infection. Having a contractor in to fix it - $$$$.
This range of the spectrum also kills a wide range of really nasty bacterial material. Some are quite resistant to antibiotics. We are fairly frequently exposed to these bacteria. They are responsible for diseases that can not be cured with normal biological techniques.
A reasonably designed device could prevent a lot of otherwise near immune to everything disease propagation. I would like to make some hand sterilizer stations for the house and a directed beam for using on skin.
I do understand the issues of UV exposure to the eyes. And, long term, exposure to the skin.
I am going to start a new post on this subject. I am posting here to get attention from the people that may already looking at this.
You might then just want to get a “germicidal bulb”, basically a small fluorescent tube but without the phosphor coating.
I used to use mine to ozonate the whole room. Also helps when you get bronchitis (O3 was the only thing that could stop the incessant coughing).
There were a few articles a few months ago about the benefits of using portable 254nm lights to irradiate hospital rooms to prevent or at least reduce iatrogenic infections.
@Flashy Mike, yes I’ve set my share of things on fire.
@alternety Take a look at this open access article on using far UVC (207-222nm) for germicidal use Far-UVC light: A new tool to control the spread of airborne-mediated microbial diseases . You would think it would be more dangerous than the longer wavelengths but apparently it is absorbed so quickly in the outer skin layers it is less dangerous for humans than say 365nm. Apparently they are already building small handheld devices for places like operating rooms. Don’t think we will see it in flashlights any time soon. This article led me to a few more that really emphasize that 365nm is not good at all for humans. Between generating melanoma in your skin or cataracts in your eyes, it is something to be avoided. Fortunately I plan on using my flashlight in only short bursts with good eye protection. But being out in the sun is really bad for you unless you are covered up.
Yes, every risk assesment of UV flashlights must be set against what sun exposure does to you, to put the risk in perspective to every day risks that are out there and considered as normal. That said, these high powered 365nm lights combined with wide open eye pupils in the dark, for short periods probably gets well above the every day risk.
Scientist, I have spent the last couple of days poking for all sorts of info on C band UV. The link you gave me on the 207nm - 222nm is extremely interesting.
Aside getting extremely annoyed by the number of products that match 2xxnm on a search (frequently by just deleting it from my search parameters) but when you look the actual material runs from 400nm to the emissions of a burning match. Oddly, these offers all seem to include Chinese text.
As best as I can tell at this point, diodes in the target optimal frequencies. There are some in the upper 200s. Most are quite expensive. Some of the larger wavelengths can impact the pathogens, but lack the benefit at 207 of being stupid proof. That would make it practical to sell a device in the drug store. Big bucks there.
I saw a brief bit that talked about being able spread the spectrum of an led and stretch it across the region of interest. They were talking, I think, about some sort of a filter array that could alter the emerging light from the narrow band input. But I have no idea how that could work. And I may have gotten a completely incorrect information by not understanding.
Very nice Scientist! Thanks for sharing the great info, sweet build, and interesting site. I would love your light in the woods at night! So many interesting things can be found with my S2+uv that I never even knew about, like big millipedes fat as a pencil and two or three inches long. I think the danger of using these lights outside in a natural setting are way lower than inside, where there are more reflective surfaces. Still, it’s a good idea to be wearing glasses, especially with that awesome triple. As to not needing a bright uv light, you don’t, until you get a decent one, that is. Then it’s flashaholism as usual.
Cool :+1:
