Again, my technical expertise on the Electrical Engineering side is lacking. I thought that linear regulators like 7135s were good to keep the light output Regulated, and compared to just a current limiting resistor they would be considered efficient. But don’t they still produce a fair amount of heat at the chip itself (energy being burnt off as heat = energy lost). Or am I incorrect on that?
Here what I understand / know, correct me if I’m wrong.
Vf is the LED forward voltage, this relates to the current going through the LED. Higher current, higher Vf. This relation is non-linear though. It rises fast on the very low currents and then levels out a bit until you get to the really high currents (weird things happen).
A linear regulator “burns off” extra voltage as heat. Thus a fully charged cell sitting at 4.2V driving a low Vf LED at 1A having a Vf of 2.9V (219C approx) will burn off 1.3V at 1A. Thus you would waste 1.3W of power in the driver.
The upside is that the battery voltage can drop to something like 3.2V or so before the linear regulator does not have enough overhead voltage to keep regulation. A higher Vf needs a higher Vbatt to maintain that margin.
And here is where a well designed buck regulator will win, it will not “burn off” the excess power, instead it will use less current from the cell when the voltage is higher than Vf. Of course, some power is lost in the buck converter, but it will be no where near the loss of a linear driver. (If well designed.)
Yeah, for low Vf LED, efficiency is lost with Li-Ion full-charge voltage. Better to use a LiFePO4 or Li-Po cell for those, since those chemistries have lower full-charge voltage. Maybe even better, if designing the entire thing from scratch, to use a high quality AA boost driver with Eneloop and low Vf emitter?
So I guess we are deep enough in at this point that I should give the purpose for this project…
I’m trying to design an ultralight system for lighting a group (4-6 people) campsite when backpacking for up to 10 days. Every gram counts, and the reason that efficiency counts is because it enables me to carry less battery weight (by extracting more runtime).
The first idea I tried was four 12inch lengths of 12V LED strip lighting (with lengths of hook-up wire between them so they could be spaced around the campsite), powered by 4x18650 and a DC-DC cc/cv buck convertor like such:
The runtime was somewhat disappointing, the overall weight was high, and having all the lights wired to a single battery made light placement restrictive.
My idea for version 2.0 was single LED, with single battery and driver. This would eliminate wires, increase light placement options, and potentially reduce weight too.
I was interested in DavidEF’s comment about AA cells and boost drivers, especially from a weight perspective. Lithium primaries would work better in cold also.
Not so much. You can check many led tests made by djozz and Texac_Ace and find how much power (current for 7135) is necessary for your target (100lm). Big multi-die leds can have enormous efficiency at tiny current rates, like 200lm/w. For several leds (4) you can take you target (100lm), divide by led quantity (100/4=25) to get each led target (power for buck or boost and current for 7135) and check how total power looks in comparation with single 100lm led config.
I dont now how to make a build with this parts but probably 2x rcr cells with 30mm L6 driver (was tested by Jensen567) powering xhp70.2 (probably target output can be limited by res mod) will give you best hour/weight ratio from parts that can be easily found.
The 7135 will saturate at 0.1V, so if at the rated current (each chip’s share being 350mA), if the Vf of the LED is 2.9V, then it’ll stay in regulation until the cell drops to 3.0V. But right out of the charger when the cell’s at 4.2V, it’ll be dissipating 350mA•1.3V. So that can be quite a bit.
Thing is, buck drivers have their own losses, especially if designed to deliver multiple amps (lower currents being PWMed high-current spikes). So there are copper losses in the wiring (even in the inductor), iron losses (magnetic hysteresis), silicon losses (all the circuitry involved), current through sense resistors, in the feedback loop, etc.
So for higher currents, always running in “turbo” (100%), the buck driver will be more efficient, as wasting 1W of power when dumping 10W, 15W, or more into the LED isn’t all that much. But at lower currents, it’s like using a 600hp Corvette engine in a riding lawnmower. Yeah, it’ll work, but it’ll hardly be efficient.
Now, if you design a buck regulator to be as power-stingy as possible, knowing you won’t be dumping 15W into the load but only 1W or so, scaling down the inductor, “tuning” everything to be as efficient as possible, no added baggage like a µC to do dozens of modes, etc., you can make the buck reg pretty efficient. That brings down the tradeoff point.
But even so, by the time the cell drops to, say, 3.5V, the linear reg will still be more efficient. By 3.2V or so, no contest, the linear reg will always always always be more efficient.
So you gotta figure efficiency (and the tradeoff point) over the whole battery discharge curve, not just the worse-case condition (biggest voltage difference).
LFP (LiFePO4) cell, crowbarred right across a higher-Vf LED.
Get a nice NW XP-G/-G2 LED and a bunch of LFP cells. Your “regulator” is the power switch. Maybe a small value resistor to slightly limit the current (“low mode”).
Those solar garden-lights use that. Simple, stoopit, and it just works.
Ah, yes I see now. I did know that LEDs were more efficient at lower currents. So for example (fake numbers) four dies could produce 100lm at 0.04A/ea (0.16A total) and is more efficient than one die at 0.2A making the same 100lm. Makes sense. I had not considered XHP70.2, good idea (although more expensive, but it seems higher performance/lighter weight always is more expensive, lol.)
Is the L6 driver known to be efficient, or is it just the first one to come to mind? Would it even work with two CR123a primaries (6.0V)?
The higher electrical efficiency of using LiFePO4 cells will be entirely offset by their lower energy density, if runtime is what you are after. They have about 1/3 the energy density of good Li ion cells.
As others have said using multiple LEDs will be more efficient. I think a quality buck driver will be more efficient than a linear driver in this case. For example the XHP70.2 produces 418 lumens at .3A and 5.35V. If we say
the battery voltage is 8V then the efficiency is only about 67% with a linear driver, while a quality buck driver can be greater than 90% efficient.
But as lightbringer explained as the battery voltage drops the linear driver efficiency increases, so overall the efficiency difference between linear and buck won’t be that high.
I know it doesn’t answer your question directly but here’s my answer. I was in USMC infantry for years multiple deployments. I know weight counts trust me getting shot at in mountains with 100+ lbs on your back is not fun. But in all reality. You already probably have a small 18650 light that has a low mode that will run 15-20 hours check the specs and do a runtime test yourself. If you can get close to 17-20 hours per battery you’d only need the light and a 4 pack case of batteries. I’d choose 3400/3500 variety.one 100 gram flashlight and 250 grams in batteries. Is under a pound and won’t make much difference in your load in all seriousness.
But I don’t know your physical conditioning or what not. But I know what it’s like to hike in your own food and water for a week or so and ammunition, body armor with 110+ degree temps. Under a pound for your lightening needs is great and easily doable with what you have now. Even you carried our or two more batteries would still be under or around a pound. But my thinking if you can get close to 20 hours. A couple hours before the sun comes up you have light coming in you can start to see inbetween night and morning like 5 am it’s dark but not nighttime dark. So even if a battery lasted 17 18 hours it would still work 2 days per battery. One in the flashlight w 4 case or 2 2cases with ncr GA or ncr and your covered. Even a extra battery for peace of mind is under a pound still. 10 days would be covered. Just my 2 cents on it alot of lights have a low mode around 100ish lumens. Your original plan was to carry your device and 4 18650s anyway. Same weight as a flashlight and 4 batteries.
Yeah, Li-Ion seems to be the most advanced (highest energy density) for sure.
The potential efficiency of a buck driver would have to be weighed against the impact of needing a second cell - more weight. Could use smaller cells like 2x18350,but Wh/gram is lower than 18650 cells.
But now maybe I see where Lithium Primary cr123a might work - at low currents (0.3A) the xhp70.2 Vf is 5.35v per TA’s test, so with 2xcr123a the battery voltage and Vf would be very closely matched. Is that thinking correct?
Speed4goal, I’m drunk on the UltraLight backpacking kool-aid - I used to brag about how much my pack weighs, now I “brag” about how little it weighs (“brag” in quotes because it’s not that light compared to many.) (and I understand that in the military you don’t get a lot of choice to carry a lighter pack)
My current base weight is about 11.5lbs, and I’m attempting to get closer to actual “ultralight” at 10lbs, so 1lb is a lot. I’m in good shape and could lug around a 50lb pack, but the UL mindset and reduced pack weight allows me to cover more ground when hiking, and more importantly I ENJOY the hike, rather than suffer through it as a necessary evil to get to the campsite.
