Have you been drinking something guys? :laughing:
Yeah, only light beer, haha. :laughing:
Locally produced “pale” ale :partying_face:
I’ll shine a light on my beautiful bottle of Imperia Vodka any day, coupled with Kahlua it’s the perfect Black Russian.
Did a lighted Convoy black button mod today, some how I missed this topic, so here it goes, more information here:
And I got a black metal lighted tail cap, there was alcohol involved with it, and it wasn’t me consuming it I was sure I had some clear 3mm fiber laying around but I couldn’t find it, so for testings sake I used a clear 3mm led and I whis I never sold my lathe I missed it a lot today Drilled a 3mm hole in the button, since it is aluminium I had to cool it with alcohol, but since the vice on Proxxon bench drill can’t be locked and I need one hand for the injector with …
Hello from the Netherlands - #83 by SpAwN
That’s pretty sweet. I imagine it would look amazing if someone could make (3d print?) the center piece of the switch out of a clear material.
I love lit tailswitches and the metal switches, but have never been satisfied with just using the clear gasket on the metal switches. It just doesn’t let enough light through.
Not really modding, but did some polishing
What have you used to achieve this effect?
I have used an old cotton T-shirt together with Brasso
The finish of this flashlight is not 100% smooth, as you can see on the image
It came that way actually, but it is not very well visible on the first picture with the patina on it.
DQG Spy SS Nichia 219B SW45K 9080 & GITD.
Convoy S6 XM-L2 3C & Lighted switch.
MBI HF-R Copper Nichia 219B repair.
FourSevens Mini Turbo Mk II XP-L HI 5A3
That MBI HF-R Copper is sweet , i haven’t seen one before .
Yeah quite rare, isn’t mine unfortunately, just needed fixed.
Xiaomi 10000mAh Powerbank II hack.
Built in short micro usb lead and 3W warm white cob LED with reverse clicky switch, acrylic window.
I usually do the lead mod with my powerbanks but noticed there was maybe just enough space for the cob and a switch, so why not ;)
The MBI HF was among the first custom direct drive lights, these from Japan and running on custom made high discharge Li-ion cells. I was very into the MBI products when The-Guy-With-No-Name was first getting started, have several HF’s, a Torpedo and an aspheric head for a Ti HF. They’re very compact and tweak all the output possible from a small cell.
As the story goes, the inventor worked for a large Japanese company that dis-allowed the employees to have a public face, hence, the-guy-with-no-name. His packaging is incredible, especially with the Torpedo, really way over the top…
Stuck a Quad-5D XPL HI into my grey D4 last night.
It’s bright, but something doesn’t seem quite right. The 5D emitters that came with my cyan D4 and Titanium D4 are both considerably brighter on turbo mode and heat up considerably faster. I suspect my grey is outputting about 1000 lumens less on a fresh VTC5A. Not sure what’s causing the loss of output, but I don’t think it’s the emitters as I had the same issue with a previous set of XPL HI emitters in my grey.
ArmyTek Wizard Pro XM-L2
Nichia E21A 6500K R9080 & 5000K R9080
Next mod on the right……
That’s a sweet mod. Good job!
could be just the VF. As soon as bat Voltage under load falls below VF you will lose output.
