Super saiyan powers.
sigh……. i wanted god powers
What is the advantage of the BLF GigaThrower Treiber XHP70.2 or Oslon Black Flat up to 8A over a modified GT driver with resistor mod?
What we really need are DTP copper MCPCB’s in XHP-70.2 format! :heart_eyes:
If I were to swap the current driver of the Q8 to one of these Lexel drivers, what would I gain?
The Buck driver would support XHP35s, but also the tail board has to be modded to a fixed position as well the tube secured on the head
The Q8 driver is good, it is still possible to get the one with 16AMCs for regulated output up to 5.6A, the MOSFET I use is a bit better than the original, but mst gain comes from taul spring bypass
Nice lexel… you are adding more new driver…
Can you guys tell me estimate lumen and lux for thr blf gt? Xhp70.2 and oslon black … jason, we need you!
Excellent work Lexel. :+1:
Amazing amount of effort and contribution for BLF! :+1:
Good Job!
Hi Lexel, do you have any Eta on the 22mm buck driver?
I will order first prototype boards this weekend
I make them 4 layer for better heat dissipation, but this also makes the order in china expensive and I just odered a bunch of 4 layer 2 weeks ago, so I need to fill the 10x10cm with more boards before i do a new order
20mm Buck driver added
for Convoy L2
for Convoy L2
How many Lumen/Kcd can we expect for L2 with XPL hi with 1/2 LK50 ?
That Buck driver is targeted to drive XHP50.2 basically in that light
for throw you will have to wait for the Boost driver for XHP35 at 2-2.5A
this Buck should do fine up to 7A output but is limited to 2S input
Nice one Lexel,
how much are the buck drivers for the L2 / Xhp50.2 ??
Can Bistro be used with these drivers?
sure it is designed on Attiny25/85 based footprints
first driver that was requested for special 48A Output on good efficiency
