Test/review of Keeppower 18650 3000mAh P1830R (Black) 2017
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 6 min ago
DSC_2613
Official specifications:
  • Part No.: P1830R
  • Protected 18650 Li-ion Rechargeable Battery
  • Minimum Capacity: 2900mAh
  • Typical Capacity: 3000mAh
  • Normal Voltage: 3.7V
  • Maximum Continuous Charging Current: 5A
  • Maximum Continuous Discharging Current: 15A
  • In Built Safety Circuitry
  • Protection Circuit (Against over charge, over discharge, over current and short-circuit.)
  • 4.20V maximum voltage and 2.50V cut-off voltage
  • Over 500 charge-discharge cycles
Keeppower%2018650%203000mAh%20P1830R%20(Black)%202017-info
This is a high current protected 18650 cell from Keeppower
DSC_2611
DSC_2614DSC_2615
DSC_2616
DSC_2617
Keeppower%2018650%203000mAh%20P1830R%20(Black)%202017-Capacity
Very good tracking in the discharge curves.
Keeppower%2018650%203000mAh%20P1830R%20(Black)%202017-Temp-10.0
Keeppower%2018650%203000mAh%20P1830R%20(Black)%202017-Temp-15.0
The cell gets rater hot at 15A
Keeppower%2018650%203000mAh%20P1830R%20(Black)%202017-Temp-20.0
At 20A I stopped the test due to temperature.
Keeppower%2018650%203000mAh%20P1830R%20(Black)%202017-CapacityTimeHours
Keeppower%2018650%203000mAh%20P1830R%20(Black)%202017-Energy
Keeppower%2018650%203000mAh%20P1830R%20(Black)%202017-PowerLoadTime
Keeppower%2018650%203000mAh%20P1830R%20(Black)%202017-TripCurrent
This test only goes to 15A and did not trip the build in protection.
Protection will usual trip on 3 conditions: Over current, over charge and over discharge.
Keeppower%2018650%203000mAh%20P1830R%20(Black)%202017-Charge
Conclusion
This is a good cell, but the build in protection do not trip on overload (It will probably trip on higher currents).
Notes and links
The battery was supplied by Keeppower for review.
Compare to 18650 and other batteries
tabetha
Last seen: 1 year 1 month ago
Thanks, a godsend to me as looking for some of this size
stephenk
stephenk's picture
Last seen: 1 week 6 days ago
Thanks for the review. Looks like a good option for lights that require longer button top batteries.
hIKARInoob
hIKARInoob's picture
Last seen: 12 min 21 sec ago
Awesome!
Results are pretty much identical to Enerpower’s VC+3000 cell (low voltage sag PCB).
Interestingly, there is one difference though. At 20A, the Keepower did not trip, and test was aborted due to heat. The Enerpower did trip before getting hot.
This cell is available at NKON for only 8.25 Euro by the way: https://www.nkon.nl/rechargeable/18650-size/keeppower-18650-3000mah-prot...
Thanks for the review HKJ! Cool
light-wolff
Last seen: 1 week 4 days ago
I can tell you the Keeppower won’t even trip at 30A (the limit of my equipment).
Barkuti
Barkuti's picture
Last seen: 1 hour 17 sec ago
stephenk, or better don't buy lights which force you to use button tops, they're probably hiding some design deficiency (like lack of reverse polarity protection) or plainly wanting to rip you off. This is of course an opinion, not a rule.
Cheers Smile
P.S.: this KeepPower rewrap is likely Samsung 30Q based. The battery assembly slightly overheats at 15A continuous, this extra heat arises from the protection circuitry MOSFETs.
