Stuck a Quad-5D XPL HI into my grey D4 last night.
It’s bright, but something doesn’t seem quite right. The 5D emitters that came with my cyan D4 and Titanium D4 are both considerably brighter on turbo mode and heat up considerably faster. I suspect my grey is outputting about 1000 lumens less on a fresh VTC5A. Not sure what’s causing the loss of output, but I don’t think it’s the emitters as I had the same issue with a previous set of XPL HI emitters in my grey.
First I tried it on my regular 6x Tail boards with conventional 6 Balance resistors and a 1kOhm Bleeder
Main Problem was that with low battery voltage the higher voltage LEds (Blue, White, pink, ice blue) get dimmer tan the low voltage ones (red, yellow, green)
I came up to enhance this idea with a voltage regulator, but had to do some steps to make it work
first get the voltage and resistor value for each LED at the same brightness
Then I made some calculation to get fixed current draw versions
It is also possible to use this with side switch lights like Convoy L6, as I can get the parasitic drain for the 18kOhm bleeder down to 0.4mA when the tail board has 0.15mA for the LEDs
Now the first 4 Prototypes
I did quite some measurements and tests to even out the brighteness of them
Firt L6/L2 prototypes are build and successfully tested on my bench, modding the lights will follow
One tme i skipped the very current hungry Emerald green for a warm white
The tail board itself uses a voltage regulator so the brightness is constant down to 3V cell voltage and can be fitted with 1S or 2S voltage regulator
The 2S Voltage regulator has a 0.1mA higher drain
I haver also ordered fitting 3x3mm trimmers so that the brightness of the board can be adjusted for 2V and 2.5V LEds in 2 groups
On the other hand I can also build em with a current draw from 0.15-1mA with the balance resistors without trimmers
The rainbow LED boards have one drawback which are the inefficient Emerald green and yellow LEDs,
so their brightness is lower than green or white LEDs at the same current
Convoy M1 with Luxeon MZ 3V 5700K 90CRI led on mosDTP powered by 12Amp LD-B4:
Ceiling lumen show around 2200lm LED lumens which matches Koef3 test. Tint is very unusual because of combination of high CRI and hight CCT. Beam uniformity is best I've seen, just pure white light without color deviations. It looks like there is small donut hole in center of beam, but it's not very noticeable,in any case much less annoying than CREE XHP50.2 purple spot and greeny/yellow corona.
That looks really good. So you have to fiddle a bit with the center piece to make it fit, then this led will work very well in any flashlight with a decent OP-reflector.
Are you planning to sell the led as well? (MZ90CRI 5700K)
Gasket is stock rotated XM-L, it works good enough, maybe focus point is not perfect, but actual amount of throw is impressive for Convoy M1 with op reflector, reason for that is lumen output and domeless design of course.
I was trying to get T bin of LMZ7-QW50 ,lumen output should be 30% higher, but I'm not sure if it's available anymore.
Immaculate and beautiful work again CRX, not completely sure what happened in every picture but those are some nice flashlights!
My mod today is not that lot of work but it was a special led in a special light.
I had this Olight M10 Maverick (EDC-size with 16340 battery) in my to-mod box for a year now, from a GB clearance sale, and I was looking for a host to check out one of the Nichia E21A 6500K R9080 leds that I bought from Clemence. The about 1A constant that this light is driven at on max, should be great for this led on my non-DTP 119-board. The tricky part was the reflowing, it took a while to get the led centered and there is a bit of flux-residu on the side of the phosfor, but on the bright side the board fitted snugly in the flashlight so that centering did not depend on the center piece. I still used a XP-centerpiece (not doing much centering because the hole is too large), that I sanded really thin, to seat the reflecor at the correct focus and insulate it from the solder pads.
Not perfectly centered.
But the beam looks really good: if you look for it a slight bit of brown in the center of the hotspot, not too much tint shift over the beam and in this host this led is quite throwy even.
The output is pretty good: a steady 265 lumen (the stock XM-L2 gives 350lm according to the manual).
The trees are at 25 meter. Don’t mind the tint in this picture, it is much nicer than it seems here.
So the mod was very succesful, and I hope that the dirty phosfor layer holds up over time.
But what about the goal of this mod, what does 6500K R9080 look like?: in short, amazingly good! On a white wall you see nothing special: a well balanced cold white tint, a well-chosen Cree led could look like that. But once you start illuminating things this is completely different: great colour contrast, red is very red and blue is very blue etc., and everything shows the correct colour including natural stuff like food, wood and skin. I checked with a Convoy S9 with 6500K XM-L2, the E21A sw65 R9080 blows it completely away in light quality. If you like cold white tints (I don’t, really ) and care about accurate colours, these leds are little gems!
Just like you, this 6500K E21A have made me like CW again. Nice host Jos.
Note: clean your LED in a hot IPA bath and brush it with smooth toothbrush, it will look like new again.
some mention CW give you eye strain when using CW at night, so even if these are HCRI at 9080 could this still be the case, or would it be easier on the eyes with the colour rendition, or something else?.
thanks.
No, no matter how high the CRI, cool white CCT will always strain most normal eyes more than warm white CCT. Many researches proved human eyes are more sensitive to blue and green spectrum. This will make your pupils smaller and less sensitive to the dark surroundings (tunnel effect). Warm lighting with less blue green spectrum perceived as being less intense by the eyes, so the pupils will open wider. This is why candle lit dinner is so romantic. Your partner face will looks more inviting with reddish tone and larger pupils and redder lips. Aroused, human will show slightly swollen red lips. This also why (the origin) women wear lipstick.
Now imagine how a tactical combat flashlight with high CRI and warm white CCT perceived by the enemies. :laughing:
I only have two cool-white high-CRI emitters, and they’re 5700K (a 219B and a 144A). I do notice less eye strain with these than with other cool white emitters, but 5700K is a little less cool than than most, so that might help too.
