The issue with the q8 temperature sensors is they are not zero’d in the factory. They are accurate in only a proportional way. In other words, the actual starting temperature may not be correct but if starts a certain point and the light gets 20degrees c higher. That twenty degree increase is correct. If one q8 starts at 25degrees and the other one 35 degrees, if they get 20 degrees warmer then the first will show 45 degrees c and the second will show 55 degrees c. I’m on my phone so it’s hard to be too long winded but hopefully this helps.
Just received the Q8 latest batch. Really liking it.couple questions. I checked the version blink and it only blinked once and kept repeating. That means V. 1.0? Also i can never get past police strobe. Is it really that hard to go through the strobes?
Strobes are not that hard. If your in the second strobe, the alternating rate one, just press and hold the button until it drops back to the first strobe, then quickly cycle up.
Which blinky do you want? The 4th one? Dbl clk, pause, dbl clk then 1, 2, 3 clicks. You should be at 2 second beacon.
i can’t find this one in the thread/manual or with search option. Searched:/ bug/shortcut
I’m in mode operation.
wanted to do a batterycheck, click once and press and hold. But i did the press and hold to short (til the mainleds got on) and let the sideswitsch loos, this turns of the side led. Viceversa and it get on again.
In mode set. I can lock and unlock the light from Of with 4 quick clicks. How about your light. I got mine Q8 wednesday.
And i discovered something else.
In mode set. wen i do a batterycheck it doesnt work, instead of batterycheck i get the strobe mode with a click and hold. I played a time and i think its al about timing…
Does anyone know if the tail PCB is available as a service item? I think I overheated the springs when I did a wire bypass a few weeks ago and the springs are sagging. Either that or new springs would probably work.
So I reached out to chendongling@banggood.com and was told to contact someone else, linjie@banggood.com. However, that email address didn’t resolve (I got back failed delivery emails). @The Miller or anyone else, who else can I contact to see about getting a replacement switch assembly?
Ramping. Switch acted like contacts were dirty or maybe had some condensation making an intermittent contact/stutter.
But the problem cleared up after going through a few cycles of use.
I made a fatal mistake today.
I was discharging 4 18650GA batteries for storage with my Q8.
I took one out to measure the voltage (I could have used Q8 measurements…didn’t think about it).
Then put it back in reverse and screwed the light together.
Nothing happened. The back didn’t make contact with the driver ring. Phew!
