So any idea when will the new Jaxman E3 be released?
Suggestion for the UI: Sofirn SF36W UI is the best rear clicky flashlight UI I have ever seen.
“click” to turn on or turn off; half “click” to cycle LL (10Lm)→Low(70 Lm)→Medium(353Lm)→High(1000Lm).The flashlight is set with Modes memory function within 2 seconds excluding Strobe.
hatman, have you received our flashlight already?
If so, is there any possibility to measure the head diameter and height (from the shelf to the threads) internally, please?
Thank you in advance!! :+1:
As Jaded said, and I agree, I am very interested in this host but I would need to get some measures first! I don’t mind getting the whole light and then use what I need, but it would be nice to get the host as a “separate” sell
BTW, I guess the version being sold currently is not the “final” version as the driver is only 2 modes (according to the product description) and they intend to sell it 3 modes.
This seems a pretty nice host indeed, robust and well made
For AA EDC light, I think it is important to have warm white 4000k hi CRI and moonlight mode less than 0.5 lumens. Don’t want to wake up your kids or wife/husband when you turn it on in the middle of the night.
I think many chinese manufacturers aren’t too fund of moonlight modes. I can understand why, though. In my personal experience moonlight modes can be a bit alienating in the normal rotation for most users because they are so low.
I wouldn’t mind if they don’t include a moonlight mode for a simpler operation, but they should at least have them well spaced out. If they want only three modes something like 10 => 40 => ~200 lumen would be nice, I guess.
The Thrunite T10 is a similar light and has around 0.3 => 10 => 250 lumen, but the jump from 10 to >200 lumen is a bit too high in my opinion. I think the T10’s settings are good for enthusiasts who know what to expect from a light with those modes, but without some setting between 10 and >200 lumen you probably won’t satisfy most needs. Something around ~50 lumen is good enough for a quick walk around the house or dimly lit streets.
With only three modes some compromises have to be made, but I think if in doubt I’d optimize for muggle usage with a light like this. See the popularity of the BLF 348. One of the most popular lights despite its simple operation. I think there’s definitely some demand for a high CRI light with a simple UI.
This looks like a nice light but I wish it offered more light output like the Manner E11,UT-01 and EDC05. I would have jumped on this if that was the case.
Today I received an E3 that I bought for my grandmother (219C 4000K), and took the opportunity to disassemble it a bit and take a look at the insides. Here are my findings:
- the build quality is as good as I’ve come to expect from jaxman
- the driver is 17mm and it looks like any 17mm driver would work in it without issues
- the switch and its washer are a bit smaller than my X6’s, but anything that fits in an X6 or an S41 tailcap can probably be made to fit with a little sanding
- tailcap button is ~12mm
the ledboard is 16mm and it’s glued in :person_facepalming:
I’m really disappointed by the glue, if a host version was made I feel this would be a good candidate for a 14500 build with a 3A LD-A4 and an ILC-0, but I’m sure my grandma will like it as it is
I don’t have an accurate way to measure the inside of the head but it looks to me like the mcpcb space is around 18mm and the rest of the inside is 19mm wide, here is a pic to get an idea:
