Which from my point of view can be the problem of the actaully delivered XHP35-Version with the output at 3.500 lm and not at the specified 7.500 lm (or actually corrected 7.000 lm).
It seems like there is something in the driver that consumes the power instead of bringing it to the LEDs…
Nope, the IMALENT was running on unprotected LG HG2 - which in this case also do not have a problem with the current. And if you ask yourself regarding the DT70: it’s one of my last ones which has spring contacts in the tube - the actual versions run on protected AND unprotected cells…
Official GB shipped directly by Haikelite closed two weeks ago on 31/01/2018. See GB thread here.
Terry who now represents Haikelite in US and Canada may still have a couple of lights available for sales, but he only ships within US and Canada. If you are in US/Canada, you can order from his website, He Said She Said Sales.
Well I got two sets of 30Q charging; one set in the Zanflare C4, and the other in the VP4. Tracking says that my lights will arrive tomorrow, woot! :sunglasses:
There is an odd bug on both my green and khaki 70 versions. I think (hope) it’s just a minor error in the battery indicator section of the programming firmware.
When batteries are depleting and battery indicator starts blinking blue, which means voltage is about 3.6V~3.7V, then the battery indicator blinks on level 1 till level 4, but on turbo the battery indicator remains solid. It behaves like this until batteries are depleted until ~3.0V and battery indicator turns to blinking red for all levels from moonlight to turbo.
Anyone with the same phenomenon on their 70?
I will double check but I'm pretty sure about this.
Turbo is set up so that anytime it steps down you are able to kick it right back into turbo regardless of heat. Basically if you make it the light will bypass the heat and power output that goes with keeping it in turbo even after step down.
This is not a step down from turbo related phenomenon. It’s about what the battery indicator does as a function of cell voltage, and on what level of output you are. The battery indicator should be blinking blue below a certain voltage, but remains solid when in turbo. It’s supposed to be blinking too.
If you are in Turbo at cell levels low enough to already be giving a warning, then chances are you are also kicking it back into turbo past the 55 degree C stop down. (Not saying you are just that there is a good chance of it with most) It will allow you to bypass that feature including any power requirements needed. That I am aware of it will not flash at all in turbo. If the cells are already low enough begin flashing, then you are below any level that should be attempting to hit 15 to 16 thousand lumens.
So when I said it will allow you to keep kicking it into turbo until you either can’t stand the heat or you kill your cells I meant that literally. It was designed to use turbo ay anytime… And if you are getting a blue flash you are between 50 and 9 percent. Why try to go to turbo once that warns you that you could possibly be as low as 9 percent already.. This would mean it is time to stop and charge or change the cells.
The instructions even tell you that it will not ready correctly in turbo.
