Thanks Dale. I have a tendency to over simplify things to make it easier to understand. I’m like a elementary school teacher and your like a high school teacher. Lol
Ring was tight but you were close! Had to get out my magnifying glass and I see the spring bypass wire has dislodged. This is the L6 I posted a long time ago was causing on and off problems, but now we got it.
I'm not the best at soldering, but I'll give it a try. Looks tight in there! Any tips are more than welcome.
Well, goes to show you how much I know. Maybe the driver is fried or something, but I never smelled anything when I used it in the beginning to test it.
I don't see that the wire touched ground anywhere. It was hanging loose in the middle.
Now that I think about it, wire could have touched ground when the batteries were in and the spring compressed. Are there any tests I can do to determine for sure if the driver is fried?
This usually happens when batteries are too long and the springs bottom out, breaking the bypass, like I said usually. could be a weak solder joint ,who knows?
The IC or Buck is pretty tough, some are, they can take a bit of abuse to a point, depending how long or how HOT is got during the ground short. IF this is what happened? Can you pop the driver out and take a pic of the other side?
Well the saving grace is by the looks of your pic, the bypass is still contained within the spring, so lets hope for the best! Not knowing the history of what has been done or tried to the light to get it to work?
It could have popped in and out of the spring during the attempts to get the light working?
It could be just a bad switch wire? I’m looking for the stock driver in the meantime, should have a bunch of them some where? :person_facepalming:
I didn't do much to get it work, just today a few minutes switching battery tubes and tail caps that's all. I also have another driver sitting in my box that I ordered from Simon for the L6 so if all fails, I can try that. Tonight some time I will have it all apart first and see how it all looks. Maybe it is just a bad switch wire in the head.
Cool check your switch wires! I found a couple of the L6 stock drivers. And going by memory and what I see on the stock driver is the Black lead going to the LED is really close to the ground ring. Now if the driver cavity pocket is oversize and the retainer ring is a bit sloppy, IT could be Possible that the Black lead going to the LED might be grounded out and the driver is not seeing the signal? A possibility….
That could explain why sometimes it would work and sometimes not possibly. I never used that particular L6 more than just testing it a few times if it would work. All of a sudden in the past it did and I thought everything was fine. I do remember someone helping me out before as I had the wrong end of the battery tube screwed into the head and they noticed it from the pic I posted.
It also could explain why the driver spring bypass is broken, bottoming out the springs puts force on the driver pcb, could have moved the driver/retaining ring over while twisting everything together. I don’t really know until I have the light in my hands, and I could test it, but I have heard of, done/seen some pretty strange/un-explainable things and shit happens!
You got me thinking there so I whipped out my digital calipers and the tail end inner ridge to the end of the threads is 11.50mm and the head end of the tube measures 12mm, so there would not have been any extra pressure on the driver, just a little less and when I insert the batteries with the tube switched, they still protrude the same amount past the tail end.
There is no parts list, I will sell those for a fair price
I spend a lot time to make it work that way and designing the boards
I will make them with a max current and option for 2 potentiometers that can tune about 30-100%
The boards are the easy part, tuning the LEDs was quite time consuming
Biggest thing is you literally need for each LED and each max current of the bord different values
I measured this to find the right values that took a lot time
The LEDs are from various chineese shops and likely not all the same
of course if you do not get the same LEDs the resistor values wont match
First I tried it on my regular 6x tail boards with conventional 6 Balance resistors and a 1kOhm Bleeder
Main Problem was that with low battery voltage the higher voltage LEds (Blue, White, pink, ice blue) get dimmer tan the low voltage ones (red, yellow, green)
I came up to enhance this idea with a voltage regulator, but had to do some steps to make it work
first get the voltage and resistor value for each LED at the same brightness
Then I made some calculation to get fixed current draw versions
But when I made the prototypes I saw that this is pointing in the right direction
but a lot manual changes were needed to equal them out on different board currents
It is also possible to use this with side switch lights like Convoy L6, as I can get the parasitic drain for the 18kOhm bleeder down to 0.4mA when the tail board has 0.15mA for the LEDs
Now the first 4 Prototypes
I did quite some measurements and tests to even out the brighteness of them
Firt L6/L2 prototypes are build and successfully tested on my bench, modding the lights will follow
One tme i skipped the very current hungry Emerald green for a warm white
The tail board itself uses a voltage regulator so the brightness is constant down to 3V cell voltage and can be fitted with 1S or 2S voltage regulator
The 2S Voltage regulator has a 0.1mA higher drain
I haver also ordered fitting 3x3mm trimmers so that the brightness of the board can be adjusted for 2V and 2.5V LEds in 2 groups
On the other hand I can also build em with a current draw from 0.15-1mA with the balance resistors without trimmers
The rainbow LED boards have one drawback which are the inefficient Emerald green and yellow LEDs,
so their brightness is lower than green or white LEDs at the same current
The LEDs are all measured by me and trimmed to equal brightness
The thing is adding the tail cap cover I also saw some colors do not get equally through it, so again minor changes were needed
Lexel, after reading your post, I think I can confirm that I am still in the dark ages when it comes to electronics. You sure put a lot of research and work into this project to make it work, hats off to you.
