Replace switch.
MIke
Looking at the pictures I don’t see a signal from e-switch to the driver. So it operates by cutting power. Right?
The Copper Tool with electronic switch has arrived at Massdrop
I really like the Copper Eswitch option
Stock Massdrop CuTool in middle, the other two have LED swaps
I don’t mind the green tint in actual use, unless I compare side by side while whitewall hunting…
My brain quickly adapts its white balance to the environment, our eyes are not as sensitive as my phone camera, to flicker, tint, color, brightness…
And, I can swap the other lights copper heads onto the Eswitch Tool too.
Its fun to have a silent switch… the regular tool clicks really loud, enough to wake a baby
although, Im still loyal to my Maratac… actually… Ive been carrying more than one FlashToy lately
Note the 219C is 24% brighter than the 219B in the worm
E-SWITCH mod done on a Tool vn. No more burning holes in my pants. This turned out nice for what tools I was working with. Angle grinder, files, 100, and 150 grit sand paper, polish.
Congrats on your switch mod
fwiw, the ESwitch won’t give 3 modes with a fully charged LiIon, when using the stock Tool driver
Only high mode works until voltage drops below 3.8v (and yes, I realize the stock tool does not officially support LiIon, but I also know people who do it anyway)
maybe your toolVN does not have mode loss problem, since it may have a non stock driver that is LiIon only
Does your ESwitch work to give multiple modes w your Tool VN? Or do you run it single mode anyway?
I have full access to the UI of driver VN2. I run my ToolVN on 1% 30% 100% No memory. At 850 lumens turn on i cannot suffice with only 1 mode. I just had to reprogram the driver after installing the switch. I had a hard time reaching the programming mode and almost thought it wasn’t going to work. Then after 30min I finally got it to the mode group I wanted.
The TI tail spring seems to be of higher quality material and probably gives a slight bump in output when using direct drive current.
Lumintop was nice enough to let me buy the TI tail cap by its self.
awesome!
I was wondering if they would be kind enough to sell me a copper ETail
it does take the ETail about 30 minutes to charge up the capacitor in the switch that enables the modes above medium, glad its working for you…
you are the first person I know to have tested the ESwitch with LiIon for ongoing use… great to hear your driver works multi mode with the Eswitch, the stock driver does not, so one more plus for the VN driver… nice kit
@DIPSTIX Awesome flashlight, I would like to have a Tool VN too but its a little bit expensive
Here is my favorite Tool, a copper with a E-Switch and a Nichia LED and………it is low-med-high :+1:
Love it and I really like the custom titan button!
I`ve just ordered me a copper with the e-switch from Massdrop, I am very curious how the 219c is doing
And hello Jon, long time no see! I had some health problems in the last months but now everything is fine again.
Greetings!
so glad youre back, I was concerned when you were absent
I look forward to your impressions of the 219c in the ETool.
Can you post link to copper with e-switch? I can’t find it on massdrop.
Mike
thx
fwiw, the Massdrop ETool is also LMH, the low is 3 lumens
Would have loved to have done this switch mod when mine arrives, sadly Lumintop won’t sell me one :cry:
Now in aluminium with eswitch, 5 colours
https://www.massdrop.com/buy/massdrop-aluminum-aaa-flashlight?mode=guest_open
Here is an option for a fully captive clip
https://www.ebay.com/itm/Foursevens-New-Preon-Pocket-Clip/282822811096?item=282822811096
The clip looks great, unfortunately this clip is not available in Germany and the ebay seller does not ship to Germany
the Preon clip is a very cool looking addition .BUT the ebay seller thinks 9$ to ship a clip makes sense .
I just paid 14$ for another reg. copper tool (using points at gearbust)…$14 for the clip is just wrong
I want one …just not that bad
The olive one is sweet
I hope Lumintop makes the Tool AA also available with e-switch…and ramping UI :smiling_imp:
