[Sale] Buck drivers 20, 21, 22, 24, 30mm L6, MF01, MF02/04(S), TN40S/42, BLF GT, Acebeam X45/65
sure reflowing on a used star is no problem
Those are an option, but only if you convert them to 12v by cutting and adding a jumper wire.
Does the 26mm fit the MF02? I remember there was one light that it was too big for, but I cant remember which one. Lol
I fitted the MF02 a no name DTP 25mm XHP70 star modded to 12V
XPL/XHP35 footprint is always 12V there are no 6V ones
I wish XHP would be sold as 6/12V would make so much more options
That’s right, I was thinking of the people swapping in 12v xhp70, like into the GT and this light with a driver swap. The xhp35 is wired internally for 12v only.
Any news on modified PCB’s for the battery carrier? I would be interested in that for a more “OEM” solution.
…and the blinking strobe frequency goes to 18Hz as the Q8?
About the TN42 now.Is it difficult to open up this something like the GT?
Hi Lexel.
What about the TN40S?Is it possible to upgrade this as well,and what will be the benefit?
Quick question Lexel.
On the BlF GT driver for the MF02 there is one pad for the led on the driver for the switch but there are 2 leds on the switch… So do I put both on the same pad or just pick the color I want to use and go with that one?? Thanks in advance.
I sold one 8A Buck driver for the TN40 that got modded with XHP35s
So the TN40S can be modded as well to 12V Emitters
I guess the carrier needs to be modified to 4S did not find information about it
I have let made 4S boards with last PCB order
You can choose 1 color on the board without modification
Green and red have different LED voltages so only red will light up if you add both
I made new 2x2 LED Boards
you can have 2 LEDs one on Power and one from MCU
Thank you Lexel keep up the great work my friend!
Lexel i am interesting for the whole package for MF 02 with stock emmiter (NW)
I want driver for 2.5 amp, cutted battery pcbs (any posibility to send me the battery pcbs with buttons and good quality springs ???) and two color switch correctly wired to the driver)
thanks
The MF02 carrier MCPCB and springs are pretty good quality
It is easy to mod those 2 in less than 5 Minutes
I measured on another Manufactor for the carrier rods diameter for the MCPCB holes and those do not fit the MF02 without drilling holes, but this is reducing the 4 main viases making electrical connection less good
I already have a MK35 and was wondering if you had a driver for that light?
Lexel do you have TA driver PCB for MF02? I want to put in an XHP70.2 in 6V setup with TA driver and Andúril firmware.
I have Buck driver for it on 8.4 or 16.8V Battery configuration
I strongly recommend 12V LED configuration for 6-7A equal 12-14A on 6V
I modded one with 12V here also LED on 12V configuration
I want one too
Sure it is easier on the springs and wires with lower current. OK
I never had a MK35 light so hard to say if it would fit without getting the driver out and take measurements
technically it is possible to get the brass ring and button on a 46mm MT07S board, but if te inductor and other stuff fits in the head idnk
reviews do not open driver section
Hey Lexel, just got around to putting the MF02 driver in, that lame MF02, kicks some ass now, very nice work on this great upgrade of a driver! Makes me want to possibly keep it……
Maybe……
