Djozz , it is the first time when I saw a " downgraded " light , made by you !!! From 350 Lm to 265 Lm , almost 30%...There is a new trend I don't know about ?
I was joking , I'm sure that you had your reason , maybe the tint or the CRI..! . On my Maverick M10 , I'd just dedomed the XM-L2 , in order to make it a little more throwy , thinking that the SMO reflector will help , added a bit of quality thermal paste , a small but strong magnet on the clip ( with shrinking tube ) . May I call that an " upgrade" ..? Hardly.., but , except the tint shift ( just a little bit on the yellow side) it seems that worked ! The beam is narrower and more brighter , overall it looks like is better than before ( my wife has an M10 also , and now she is trying to make a trade with mine... ) Should I go for it ?...
It is not the first light that I downgraded in favor of CRI but it always hurts to loose lumens! The throw has increased quite some btw.
I downgraded the M10 a bit further today :innocent: , made it a lot less ‘tactical’ : foybezeledtm the front end and swapped the long forward switch for a small Omten 1288 reverse clicky, and a flatter switch cover.
Nothing fancy, but today I completed my first mods.
I put Texas Avenger Bistro OTSM drivers into a Convoy L2 (XM-L2 T6 4C) and a silver Convoy C8 (XP-L HI U6 4B), plus Convoy lighted tail switches with spring bypasses.
I used 18 AWG wire for everything and it was a pain to work with. I’m wondering whether it’s overkill.
It wasn’t all good. I put a BLF X5/X6 driver in my Convoy M2 and I think I fried the emitter, and I overheated the switch in my BLF A6 when I fixed its broken leg so its a bit sensitive.
Replacement parts have been ordered and I’m looking forward to my next mod!
Changed batteries in an 9 Year old Batterypack. Its an Ferm Premium Power 18V Batterie with 2P5S 18650.
I used Samsung 30q. It doubled the Capacity. Old Cells had former 1500mAh, I measured around 1000mAh with a High Resistance between 200 and 300 Ohms.
I got the battery-connections off with only little damage. Than pre-tinned the batteries and after cooling the batteries I soldered the connections to the new batteries.
Did my first Syniosbuild today. I build one in a small 14500 zoomie and unfortunately it underperformed. In this same zoomie I got a dedomed XP-G2 S3 3D perform up to 54kcd, so I hoped for at least 80kcd with the Synios led. Instead it was just 48kcd, and an uglier hotspot. Of course I can think of a few reasons for the underperformance, of which the heat barrier from ledboard to pill is the main one, keeping the ledboard temperature too high (the board was glued onto the edge of the hollow pill with Arctic Alumina Adhesive, making it electrically insulated from the pill). But I had to re-heat the board an extra time for creating a solder connection between ledboard-core and minus-pad (could have thought of that while reflowing the led ), that extra cycle at 210 degC on the heatblock could have affected the led performance as well.
Oh well, I made pictures so I may as well report the mod:
-flattended a 16mm Noctigon well on the underside and slightly sanded the side as well to avoid anything sticking out that could short the board to the pill when later glued in.
-reflowed the Synios led on the Noctigon
-scratched an opening to the core of the board next to the minuspad and reheated the board once more to create a connection from core to minuspad with a tiny bit of wire.
-build up a simple 6x7135 MCU-less driver by stacking chips.
-soldered two pieces of copper wires around the edge of the driver board to create a press-fit connection between driver and pill.
-soldered two tiny ledwires to the ledboard and glued the ledboard into the hollow pill while my led-tester (at 10mA) was connected to led+ and pill. This way an unwanted short from ledboard to pill makes the led light up, so I could re-position the board while the glue was not hardened still.
-made a spring bypass at the driver side.
-assembled the light and tested the current. It was a nice 2A precise (should be 2.1A but those 7135 chips are not that precise).
-tested throw at 7 meter with the Mobilux luxmeter: 48kcd
gchart, little late reaction but I was thinking about that too, since I don’t have a 3D printer I didn’t do anything with the idea till yesterday.
I needed a 3D print for my soldering microscope and I had to make a 3D drawing for it and found a shop in my area who could print for me, meanwhile I also make 3D model for the button, shop didn’t have clear filament so asked him to print in any color to test.
I don’t know if this is category mods, but here it goes.
I picked up today and print was not really successful the thin part where the gasket comes was a mess, it is a small object after all.
I did trim the print and it works in my S2+
The guy who printed for me asked if I could add some pillars to it so it makes the print sturdy while printing, thus I added some side supports for inner side, if it is printed I will cut those supports.
Since it is only 12 minutes print, he will wait till he has something else to print and print this afterwards.
Here is the new model:
