I would suggest printing in transparent colored filament.
Normal transparent looks kind of white when printed and doesn’t match my sand S2+
No, I printed V1. Sorry for not being clear.
I just selected “supports” in Cura to make them. I prefer slicer making supports.
You can use my photos if needed to show for now.
Thanks XXX-Man, I think best filament would be smoked transparant for the black buttons.
To make me feel better after a disappointing mod this morning, I refurbished an old abandoned 16340 EDC. It looks pretty worn but what is appealing is how small it is, virtually the same size as a EagleTac D25C.
It had a dedomed 219B 4000K and a 8x7135 AK-101 driver so it was nice already.
I changed the led for a 219B V1 4000K R9080, the driver for a BLF-A6 driver (added a 750 Ohm bleeder resistor), and I added a lighted tail with blue and red leds and a light blue cover. I had to decrease the diameter of both the switchboard and lighted ring to make it fit.
It does 500 lumen at startup, 400 at 30 seconds, so it has considerable heatsag. The 40 seconds fixed stepdown of the BLF-A6 driver is about appropriate. The tint and beam: :heart_eyes: of course.
cool!
Cute! Looks kinda like a shrunk-down S5.
It really looks beautiful with this worn ano and blue blue switch. It reminds me on my beloved 602c triple 219a. It was my favourite light to this date!
I would love to get one of this host for a new build but can’t find one anywhere. Especially blank like yours.
I know the feeling of failure/dissatisfaction/disappointment of mod or build. It really hurts :cry:
Looking great djozz :sunglasses:
Not sure if there is one.
I’m still new to 3D printing, I only have printer for 2 weeks.
This light is similar but quite a bit smaller even than the 602C. It was for sale for 8 dollar at Fasttech for some time and then disappeared. I modded one for myself and gave one away. Of course it can not soak up a lot of heat before overheating, but with some hand-sinking it can maintain 300 lumen.
Hmm you are right, there is not much, here one store: https://shop.3dfilaprint.com/filaprint-pet-g-black-transparent-175mm-3d-printer-filament-10939-p.asp but the example does not look transparent.
I installed the $5-ish BLF driver from banggood in my Ultrafire C8. I put a smear of eBay thermal schmoo on the pill and so far, so good. I have been going lightly with the Turbo mode since I already burned up a LED in a zoomie that way, but the LED board wasn’t seated well and no thermal paste. I also sliced the dome, but the finish was VERY poor. This is the first mod that has made me giggle after testing it out. Moonlight, long-press in to Turbo, very nice! It is really not much, but it is mine, etc…
That sounds like great result!
There is only a short list of things to take care of to make a flashlight with great output (right led, DTP copper board, good thermal connection to the host, low resistances in the electrical path, high drain battery). Unfortunately (or fortunately :sunglasses: ) chinese budget manufacturers usually fail in in one or many items in the list, which gives us things to do and be awesome
Thanks djozz, I was a little discouraged after burning up the previous LED, and the answers I received in the “No Stupid Questions” thread, but I bought a helping hand cheap at a model train show on the weekend, and this was a project in need of soldering. I really should order a nicer copper PCB and LED before I burn this one up, hmmm…
^ So your sliced XM-L2 is not sitting on a copper DTP-board? It is very probable then that the led will burn up at some point. Copper DTP-boards make all the difference in the world in heatsinking, and are cheap nowadays. It requires the skill to reflow the leds yourself but to learn to do that is not really hard, especially with all the information about it floating around on BLF.
If anyone has a 3D printer and want to print Convoy S2+ black metal button copy, here is the file: Convoy S2+ metal button replacement for lighted tail cap. by Sp4wN - Thingiverse
Had to wait 24 hours after registering.
Thank you, I might try it
A friend asked me to rebuild a wurth cordless drill battery pack for him. After disassembling the battery pack (5S2P configuration) I found out that all batteries were 0.01V and there is a very simple charging module managing that pack. No balancing wires, just positive and negative contacts with small double black wire stuck between battery cells (maybe some kind of sensor wire).
This doesn’t look like a safe way to charge a 5S2P battery pack. Please advise, I’m having second thoughts about proceeding with this rebuild.
This scheme works in many makita battery packs for years. I like it much more than other brand packs (like aeg or fein) that have various balancing wires and extra lvp which usually causes cells disbalancing.
Just use brand cells (Im using 20R or 25R) and original charger.
P.S. I suppose pcb is aftermarket and was copied from the 5S1P original board, but I dont think this is a problem.
Besides the + and - contact there seems to be a temp-sensor.
For my last Battery-Pack mod: I use the original charger, but it has 2,2A charging current and a time limitation. That means it charges only one hour or little above. That means I have to charge my new Battery-Pack with Samsung 30Q two times to charge it to 20,6-20,8V Charging Limit. That equals 4,12V - 4,16V for each single cell Thats perfect.
For the battery-pack of your friend, you have to try afterwards, if you have to charge it two times, or if the charger carges to a definitive stop voltage.
What cells do you found in this battery-pack and how old is it?
