Very nice Robo! Nice presentation of the light and a thorough job draining cells!
Thanks Dale.
One of these days I might try some time lapse of the run times and all , but for now the single test I did adds enough time to get the review finished as it is.
Great review, love this flashlight.
Glad to have gotten one before the name change, not hip on the new name but it’s their business.
Crazy bright for an out of the box tube light.
Only wish is for a lower low or moonlight.
For the money the build quality is stunning.
Thanks
Later,
Keith
Thanks Muto
Yea I kind of like the Atactical name better than the new name of WOWTAC myself but as you said………
I agree this is a great light for the price also.
Thanks Malleshadmissionq , welcome to the forum.
glad to do the reviews.
I just got an A1S. The tail end button is pretty stiff, stiffer than a couple other such flashlights I’ve had. Is that stiffness normal? I ask because, if that’s typical, I’ll have to learn how to work with it given the osteoarthritis in my right thumb.
Stiff is a relative term . Mine feels about the same as my Convoys.
Maybe you should send that back if your thumb can’t be bent without pain or use two hands . Something like this Sofirn SP32A has a side switch only .
Yeah, stiff is relative. I was trying to get a sense if the feel of that one is pretty much the same across the board. It in’t for my Coast, but maybe it is for most.
Thanks for the suggestion of the Sofirn. That was on my list, but I read that step down from turbo is 2 minutes and from high is 3 minutes. And someone else said that 2 minutes is too long for the turbo step down, that 40 seconds is enough. If turbo is 1550 lumens, high is 900, and medium is 160, that means that the only usable level for me is 160 lumens (I rarely have a need to just go up briefly to those higher settings). If medium were 400 or 500, a level that wouldn’t have to step down, I may have gone with it.
The thumb thing is arthritis in the CMC joint, down at the base. The joint has worn enough that the bones move with any significant pressure and then it gets inflamed. The angle for pressing the flashlight switch is just right for pushing it out. So assuming for the time being that the stiffness of the switch is typical, I’ll work on flipping it around to use my index finger on the tail switch. I’m looking forward to getting it outside tonight and seeing what it will do.
Sofirn SP10B?
AA/14500 light, side-clicky, simple doubleclick-to-turbo even from off. Li cell yields >500lm, but dunno if there’s any explicit stepdown. Alkaleak/LFP/NiMH are about half the 14500 values.
Physical lockout (tailcap), plus electronic lockout (4-clicks).
I liked the A well enough, but when I heard the diffs between the A and B, I got a bunch of Bs.
Liking the Bs quite a bit, and I was an 18650-only dewd for a loooooooooong time.
Else you can use the SP32A in ramping mode. Don’t recall its stepdown policy, if any, that it has in ramping mode.
Are you after the hostess with the mostess or are you happy with moderate lumens and long run times? The convoy S9 or BD06 are side switch lights and coupons floating around .
Sorry. I was talking about the Sofirn SP32a. I’ll look at the SP10B. I should note that I’m just an average user; I don’t have the kind of uses in mind to spend big bucks on these things.
Moderate lumens would be great, if that means maybe 400-500 available. I was happy with my Coleman 75 lumens light until it started acting up and I found my way to this forum and learned that there are only about a half gazillion options out there. Thanks for the suggestions of the other Convoys.
I’m only going to return the A1S if I find its equal with a side switch. I just returned a couple of UltraFire SK68s to carry in my bag because of one little annoyance and then got a J5 V1 Pro (only to find that it was no better and cost more for one than the UltraFires cost for two). I’m not enough of an aficionado to do this much buying and trying.
Thanks again for the suggestions.
Let us know how the A1S works out for you . My thumbs hurt too . I usually use 2 hands .One to hold the light and the other to push the button . Not tacticool but oh well.
Right now I’m not enthusiastic about it, but I don’t want to make a hasty decision. I can flip it over and press the switch with my index finger and then flip it back, but it’s a hassle. The light itself, though, is fine. I’m going to look closer at the Convoy S9. I can’t get it from Amazon, though, so it might be one of those wait-a-month-to-get-it-from-China things, and I’m impatient to get this settled.
If you have a flashlight the same size as the A1S, try holding it (the opposite way from the tactical way), grab it in the middle between thumb and middle finger and flip it over to tap the tail switch with index finger. Then flip it back. And decide if you can live with it.
Be careful , it gets addictive . My wife thinks it is a little nuts . I justify it by putting them in various places in the cars and house . With my ageing eyes , I need extra light even in the day time . The one nice thing about the A1S is it has momentary on . Most don’t . I have mine mounted on a home defense shotgun but it can be removed quickly for hand held use . I see a S9 in my future though .
It’s probably good that my budget won’t permit it to become an addiction. On the other hand, that means I have to get it right the first time (or buy from someone with an easy return policy). My problem (well, one of them) is that this is a new world for me. As I’ve said elsewhere, I used to walk into a hardware store and pick out a light in my budget that looked good. Now I have to decide if I want a 7135x4 or x6, or a smooth reflector, or a T6-3B or 4C, or a side switch that gets a long press to turn off instead of long presses (or continuous press) to go through the modes, etc., etc. I never expected there would be a problem simply with the stiffness of the switch.
Are there such things as flashlight shows? I think that’s what I need.
A P.S. here about the A1S. For me, I don’t see the practicality of having a tail switch to turn the light on and side switch for everything else. Even if I could use my thumb comfortably on it, there are still two motions involved (if I don’t want it at the level where I turned it off): reach back to turn it on, then shift it to get my thumb on the side switch. Maybe in tactical use there’s another way to do it, but for my ordinary use, it’s an unnecessary complication. I’ve asked elsewhere about the rubber cover over the charging port on the Convoy S9, whether it is easy to open accidentally in normal use and whether it holds up over time. I’m waiting to hear about that from someone who’s been using one for awhile.
The fact that you know all that is not a good sign or that you are even here . If you have patience , the China route won’t eat up a lot of money . I got a tan S2+ for $10 last month . The batteries can get expensive but should last a long time . I started moving up to the C8 class. I think that will be my limit .
A general question here. Why are tail switches so common? I won’t be using my flashlight in tactical mode while holding a pistol (probably like most users). Why are so many made that way?
Rick
Try leaving the tail switch in the on position and just giving the tailcap a very slight twist to break the circuit. Just makes it a twisty switch
Just tried it on my A1S and it is a very small rotation.
This way you will not have to press in at all with your thumb.
Hope this works for you.
Later,
Keith
Thanks for the suggestion. I have to slide it forward in my hand a bit to get a grip on the knurled part and then twist with my last two fingers against my palm. That’s a little cumbersome, but it might be workable. It took so long to settle on this light that I hate to go back into the search for another. It’s also good to know that it can be locked out that way and not drain any battery when not in use.
I found last night that there are buying and selling lists in this forum, so I’ll keep an eye out for anyone selling a side switch light in my budget range that I can experiment with without spending much.
Because someone else in the forum was talking about having a thumb problem too, I’ll send him your suggestion.
