[♛ FreemeGB] ASTROLUX MF06 CREE High Power Flashlight with Active Cooling - Not Quite there Yet
Interested
Completely agree.
Very curious what they will come up with.
Interested
As long as the threads do not glued
My MF01 came with the threads glued
I will not buy another Astrolux with the threads glued
Interested
Interested
Way interested! Especially if it rocks a tripod mount.
Interested!
Interested, depending on whether the pocket clip is for head-up or head-down carry. :stuck_out_tongue:
Lol
Given mf01 is already 12k lumens and mf02(gorgeous looks)/4 is already ultra throwers, mf05 must be a beast with 7x xhp70.2 using the same tube thats fits 2 similar battery carriers 4x18650 ,which needs massive heatsinky thus the active cooling fan built in. hopefully its a budget ~30k lumens class budget light with great quality and looks so it can be a keeper. m thinking this could be the budget rival to the legendary but ulgy dx80 which is out of budget for most………… for now……….
Are you guessing that the MF05 will be a fan cooled version of the MF03?
Maybe, but it seems a bit redundant.
(Btw, it’s 8x xhp70.2, not 7.)
i was wondering where mf03 went and i just checked it out and boy what a waste of reflector space and thus low light reflected efficiency. Yea i thought 7x big well spaced reflectors light like a typical skyrayking will make it repectable a semi thrower provided the head needs to be Massive…. like bigger than a mf04 to fit in big enough reflectors for the 7leds because xhp70 is big by itself. 4.5k lumens x7 can be great brute throwers if the individual reflectors are decent sized. this means the head needs to be 120cm at least.
Interested!!
JasonWW look at the first post.
Huh? What am I supposed to see?
“ASTROLUX MF05 CREE High Power Flashlight with Active Cooling”
I’ve known that since the thread started.
I still don’t understand the point you’re trying to make.
We must have some type of communication problem.
It is no need to quessing when it is written in first post.
The first post doesn’t tell us anything, really. A “high powered” flashlight literally could be anything. It could be 10,000, 20,000, 30,000, 40,000, maybe even 50,000 lumen. It might have a bunch of 70.2 or it might have a bunch of 50.2. You could even have a bunch of xhp35.
It does seem highly unlikely that Astrolux would make two different versions of the same light, one with active cooling and one without. They will rob each other of sales. Ideally, they should be different enough that people will want to buy both. Not just one.
