Nice! This would be remarkable in a 17mm driver
“Driver is good for 20V output, so I’m expecting a ~14V close to 3A output for that configuration (working on this soon)”
I would like to see this (use this) in a 20, 26, 30mm driver size…
Sounds great!
Way more features than expected.
Can’t wait to learn more about efficiency at lower modes. And 12V.
ADDED:
Now it would be good to merge both MP3431 developments…
600kHz fixed-frequency
may dont like
4-layer stackup
Also
dev-board PCB
seems the reason why
the driver is not thermally limited per-se
In real life driver inside S2+ brass pill can overheat if loss power is above ~2W.
I would prefer to see usefull product, would it be 20mm or 17mm, 25W or 50W. Better have 20mm driver with 25W output that can work for hours than 17mm with 50W output restricted after 30-40sec by thermal protection.
H1-A overheats in 2 minutes inside eagle eye X7. I would like similar driver that can work 15+ minutes was available at the market so I could suggest it to use with my last project.
I am shocked how similar our top pcb layer looks like. But well done :+1: , I’m about to order my PCBs today or so.
And you need to correct something: I’m sure the driver won’t output 20V, 16V is pretty much the maximum.
@kiriba-ru: Why is this driver not useful? You can select your maximum power yourself with some resistors changed. Then you have less overheating problems.
And you can’t expect a driver to work at a ridiculously high efficiency, 90% is pretty good already. I would put more focus on the thermal path of the driver to the head/pill, and the heat sinks on the flashlight should be better. Just a ring around the driver is not enough to cool it. When you compare a flashlight “heatsink” with a proper CPU heatsink, it’s quite clear that the flashlight won’t be able to cool the LED and the driver combined.
That was an interesting read
Thank you, loneoceans, I’ll be following along as you work on it!
Good stuff! You plan on selling these?
Might be interesting to make a pill for my Brinyte B158 with XHP70.2 or 50 LED.
The XAL7070 increases the efficiency for 25-50W Output you should use it
The ripple comes from the inductance, DC losses and saturation on the XAL7070 is better
Also 1206 capacitors are better than 0805s especially when the driver gets hot
Would one 1210 cap be better than two 0805 caps?
one 10uF X7R 25V 1210 is definately better than 2 0805 X7R 10V 4.7uF
Only thing I do not see mentioned is being able to accommodate 1S or 2S input in the same configuration. Lights like the Convoy L2 that have an optional extension tube would really benefit from this.
I do not understand most of the thread otherwise but I cant wait to try out some of these new boost drivers
This I asked in Firmware topics and wrote PMs to Tom_E and Toykeeper
I got no real solution
It is no big deal if it gets integrated in Bistro and Narsil, but I am not capable of doing it
Welcome back Lone. I wrote you emails months ago and thought you’re already left us. But here you are with your crazy driver project. Great job Lone!
- Clemence
This looks awesome thanks for sharing the project with us.
When you solder the smaller components do you use a soldering iron or heat gun?
Answering comments:
So excited to see more development on this, many thanks for sharing. Maybe one day either of these drivers will be available as a kit or via Oshpark, I really like soldering and building drivers.
Thanks FPV. Yes once I finish the firmware and done some proper field operation and stress testing, I'll put everything online so you can order your own PCBs and put your own together! However do be warned that you do need some sort of proper setup to either reflow / hot air this or put this together under magnification. Meanwhile I'll start putting up my GXB172 page on my website as I go along.
As for sales, we'll see how it goes! I certainly wouldn't want to put something up for sale if the firmware is not up to scratch or if the driver has issues. Suppose all is sorted out, I might do a small run, or send for PCBA which would be much nicer, but it depends. Morever Schoki / Lexel are already working on driver and it seems they have more history of releasing drivers, so you can go with that route as well! I just had no idea it was already in development when I made the GXB172.
Nice! This would be remarkable in a 17mm driver p. “Driver is good for 20V (16V corrected) output, so I’m expecting a ~14V close to 3A output for that configuration (working on this soon)” p. I would like to see this (use this) in a 20, 26, 30mm driver size…
KawaiBoy1428, whoops I meant to say 16V, but yes it's good for driving LEDs like the XHP35 (12V+), and by extension, also good for 9V operation. I do hope to make a 20mm version with even better performance (better passives) in the future to replace my GXB20, but I'm not planning to make this design any larger. The reason being that any larger would allow me to use an external FET solution and it's really much easier then to make a 50W or even higher power driver - no need to constrain myself with this particular topology. That's the good thing about the 'dev-board', easy to do tests like this.
600kHz fixed-frequency may dont like 4-layer stackup Also dev-board PCB seems the reason why the driver is not thermally limited per-se In real life driver inside S2+ brass pill can overheat if loss power is above ~2W. I would prefer to see usefull product, would it be 20mm or 17mm, 25W or 50W. Better have 20mm driver with 25W output that can work for hours than 17mm with 50W output restricted after 30-40sec by thermal protection. H1-A overheats in 2 minutes inside eagle eye X7. I would like similar driver that can work 15+ minutes was available at the market so I could suggest it to use with my last project.
I am shocked how similar our top pcb layer looks like. But well done :+1: , I’m about to order my PCBs today or so. And you need to correct something: I’m sure the driver won’t output 20V, 16V is pretty much the maximum. @kiriba-ru: Why is this driver not useful? You can select your maximum power yourself with some resistors changed. Then you have less overheating problems. And you can’t expect a driver to work at a ridiculously high efficiency, 90% is pretty good already. I would put more focus on the thermal path of the driver to the head/pill, and the heat sinks on the flashlight should be better. Just a ring around the driver is not enough to cool it. When you compare a flashlight “heatsink” with a proper CPU heatsink, it’s quite clear that the flashlight won’t be able to cool the LED and the driver combined.
Kiriba-ru, you are absolutely right! The driver and LED setup for any flashlight that can accomodate a 17mm driver would definitely overheat at 20W, much less at 50W! Drawing this amount of power from a small cell is also ridiculous. However, that's the premise of the project - to make a ridiculous driver. As I've mentioned, it's fairly useless from a practical point of view, but practicality was not the main point of the GXB172, at least not in 50W output. I have no illusions that 50W is anywhere near a practical drive power for a 17mm-driver flashlight.
Regardless, the driver should still be in the upper 90s% for most of the range from ~100s of mA to 2-3A output (will measure soon) so it's still a fairly efficient driver at realistic drive power.
For example, the Emisar D4 has a 3000+ lumen direct drive mode, but this lasts for only 10s of seconds, before the light drops down steeply to some ~300 lumens or so by thermal regulation (based on here https://www.youtube.com/watch?v=GVj7NnAj_Ps). Again depending on what you set the thermal limit to be and what the external temperaturate is, my guess is that the Convoy S2 can probably only handle on the order of 3 to 5W of continuous run time (e.g. headlamp), and likely not much more than 10W (handheld light) for any reasonable temperature limit (taking into account the whole system including LED, driver and battery).
And as Schoki said, because the driver is in fact much more efficient at lower drive power, this makes it a pretty good driver for 20W operation I think. In fact, in real life, I'm going to set my everyday mode limit to be around 25W operation. This is very easy to set and the 1024 current limit steps make brightness control still fairly high resolution even at lower powers (or you can swap out some resistors to make this even better!). I'll be able to do some more detailed thermal analysis later, especially when I get it into form factor.
Also Schoki, thanks for your comments, and I see the renders of the driver Lexel posted! Is that the driver you two are working on together?
Yes I agree the top (inductor side) layout looks similar, but I guess come to think of it it really falls out into place just based on how the (few) power components and traces needed to be laid out, and what we can fit into the same round PCB. I did start layout based on the reference layout in the datasheet, and used a single 1210 capacitor for input and output rails, but I couldn't get it to fit in a reasonable way, so I split them into combinations of smaller caps instead and that's basically the only way I could lay it out. The rest of the compensation network and feedback then just slots in the leftover space. I also initially use through-holes for the LED outputs but I switched them to large pads instead just to make routing on the other side easier. Also good catch on the max voltage rating, I meant to say 16V!
Its all black magic to me but know its all real good stuff.
The XAL7070 increases the efficiency for 25-50W Output you should use it The ripple comes from the inductance, DC losses and saturation on the XAL7070 is better Also 1206 capacitors are better than 0805s especially when the driver gets hot!
As for the capacitors, yes definitely larger and higer voltage rating with better dielectric is more desirable. In fact I did change some of the pads to 1206 before I sent it off for fab last week. Since the inductor is so fat, it's also possible to stack MLCCs on top of each other. Currently I have 94uF on both the input and the output at 16V, though we could do something like a 138uF 10V on the input and 66u 25V on the output, and more with stacking. Finally, I also found some nice bronze springs from Kaidomain which have a ~5mm top and ~8mm bottom. The high drain cells all have fairly large flat tops so I'm planning to try to use those springs in reverse (since my spring pad is very small to save space), but I suppose it doesn't really matter since we'll need to bypass them anyway.
Only thing I do not see mentioned is being able to accommodate 1S or 2S input in the same configuration. Lights like the Convoy L2 that have an optional extension tube would really benefit from this. I do not understand most of the thread otherwise but I cant wait to try out some of these new boost drivers
This looks awesome thanks for sharing the project with us. When you solder the smaller components do you use a soldering iron or heat gun?
Thanks for your kind words! For soldering, it depends! Typically for stuff like this I use a stencil and reflow it in an oven, but for one-off small boards like these (at least for now), I typically use hot air for the stuff with pads underneath, or in this case, the big indutor too. The rest I either use hand-placed solderpaste with a needle and hot air it, or use a tiny tip soldering iron and needle tweezers. Typically I do this under magnification.
Thanks MRsDNF! I hope to get this inside a flashlight soon when the host and boards arrive, and when I finish whatever firmware I'm working on right now.
In which mode are you running the boost IC?
Wow, so much reading to catch up on this thread, hope I can find time to catch up at some point.
If you want to get my design files for private use only I have it in Diptrace the others seem to use Eagle for their drivers
Schoki, I tested both pulse frequency modulation / pulse skip mode as well as ultrasonic mode (USM) - one of the cool features of this IC. Once the output current (with a 6V LED) drops to about 75mA or less, the pulse group frequency drops to below 20kHz (with my set-up). As a result, running it in really low modes or moonlight will result in audible noise with PFM/PSM. For example, at 10mA output drive, the pulse frequency is well under 2kHz. So anything below ~60mA or so results in a (quiet) but definitely audible sound. This is absent in USM mode where the group frequency is kept above ~23kHz but at the expense of only slightly lower efficiency at those low values.
After some evaluation I decided to just go with USM mode since this allows us to float the mode pin (fewer components), and I'm pretty sure nobody wants a moonlight / nightlight flashlight beside your bed making this tiny high pitched sound, even if it has better battery life. For example, based on the datasheet with a 4.2V input 9V output and 1mA output, PSM vs USM is about 60% vs 40% efficiency. At 10mA, this becomes 93 vs 83% efficiency. It's a significant efficiency decrease, but I think it's worth the trade off, and still reasonable in practical run-time duration.
