I haven’t done any lux readings but experienced a similar thing myself in the build I am working on.
A small spot (the die projection) surrounded by a lot of extra light, coming from the white area around the LED.
It did not look any more intense (when in the light) than a black flat, although I haven’t had the chance to compare them side by side.
Please redo the test with the white area blacked out, using some electrical tape or paint (or even better, some blackout paper)
I covered the white areas with aluminium foil (I tested black paper and tape but that melting away directly on the die). I checked very carefully if the foil covers precisely the white area and not the die itself.
I placed the luxmeter 1 m away from the LED, like my earlier tests. For the so modified SYNIOS I got 216.7 cd/mm² at 2,500 mA (101.4 cd/mm² at 700 mA). Much less than I measured in the test, but still not bad for such a low current and therefore battery drain.
Enderman, thanks a lot for this very important hint and for everyone who did some real-life tests with this LED to explain what I may have wrong in this test. I always learning a bit more, especially in doing such LED reviews. :)
This LEDs are on sale at least for over two and a half years (begin mass prod. Apr 15). I don't know if these emitters were already mentioned in flashlight forums.
Maybe it is better that other members doing these luminance measurements. In most cases my values seems to be wrong. I am not sure to take newly this risk for updating the luminance values because they could also be wrong for any reason.
Both me and koef made the same mistake when measuring the synios.
I only found out that we had a flaw in our testing method after three people used synios LEDs and got bad results in their flashlights.
Fortunately this is just for the synios LEDs, all other LEDs are fine and the results are still correct
Actually many LEDs will have a problem with this method of calculating luminance. Any light that you see not coming from the die itself will inflate the calculated luminance. To name a few: XPG3, XPL2, luxeon V, nichia 219C, XHP50.2, XHP70.2.
That being said I find koef3’s detailed pictures and measurements to be very useful. But for the luminance measurement I think a careful in-flashlight test will give a more accurate result.
Final word about the certain led should be given in practical use. It can have all numbers in a world but when I “throw it” to light meter that is truly real state of matter.
Yes, I measured the bare die luminance of the 219C and observed the in-flashlight results were much less. This was before I discovered this stray light effect in my investigation of the XPG3, so I didn’t understand the discrepancy then. But if you look at the dedomed 219C the white area around the die is significantly lit.
In my led surgeries it appeared that the 219C is different from the old Cree leds like XP-G2 in that the phosfor is not a compact rigid layer right on top of the light emitting surface, but a layer of phosfor mixed silicone that is inside a white-coloured shallow square cup surrounding the die. On top of that I assume that it is a flip chip design so the light does not enter the phosfor containing layer directly, but passes the die base first.
Thanks, I used your numbers to determine the luminance of the 219C D240 (R9050) shaved at 2A: 41.8cd/mm^2. With 12 of these and
UCLp lens the Meteor should do 34kcd. Thats not too bad. The 219Bs do 20kcd with dome and are probably similar without. I really like the beam profile and throw, but higher efficiency would be really nice (especially less heat!).
Using your calculations I get peak 154 cd/lm for D320.
Assuming current-handling of 219D is the same (yes, I know how good this assumption is), it should do 210 cd/lm 195 cd/lm in D340 bin. This number may be way off, but I believe 219D is worth testing.
Is that taking into account the clear aperture of the lens?
Lenses usually have 95% CA, or even less for cheaper quality ones.
The outside circumference is not very aspherical and therefore may not contribute to the lux in the spot.
The best way of being sure is putting a circle of paper or metal in front of the lens which has a smaller diameter than the lens, in order to ensure you’re only calculating lux and area for the clear aperture.
