You know that actually makes sense. Although I do believe that the lowest setting will still be sufficiently visible during day time. It’s a pretty light and well made. Definitely not the “Made in China” from two decades ago. Good stuff! :+1:
Astrolux C8 XP-L HI 1300Lumens 7/4modes A6 Driver Tactical EDC LED Flashlight 18650
It’s now in flash sale for $19.99
Offer is valid for 4 days and 7 hours.
This is tried design based on prevalent C8 host with XP-L HI LED (1A and 3A tints available) and BLF A6 FET + 1xAMC driver.
This means this light will offer best throw from any C8 host as in turbo mode it’s essentially direct driven - so use high drain battery like Samsung 30Q above for maximum light output (stated 1300lm, spring bypass may be needed).
And of course same great UI as BLF A6 :+1:
XANES DL13 1800LM 2*XM-L2 4400mAh Rechargeable Battery Indicator Headlight
New front light from Xanes is now in promotion sale for $16.99 (regular price was $35.88)
Offer is valid until February 27th.
- 2x Cree XM-L2 LEDs
- max 1800lm
- 4400 built in battery (possibly 2x2200mAh 18650 cells, so modding potential here )
- 3 constant modes + 2 blinkies (strobe + SOS)
- USB rechargeable
- LED power indicator
- aluminium body construction
I am VIP4 on banggood but not seeing 21,69$ price for the TINI. The only way to lower it if I had enough points?
Klarus Mi1C XP-L HI V3 600Lumens Mini-might Brightness EDC LED Flashlight
Coupon code with nice discount is available but it’s not public.
» Request via PM here«
Flashlight has side button and magnetic tailcap, it’s only 54.5mm (~2.1”) long and is capable of delivering 600lm according too manufacturer.
Price includes micro USB rechargeable battery, flashlight, stainless clip and spare oring.
Sorry - unfortunately this offer already expired. VIP deals last for ~5-7 days only… (expiration date is not precisely advertised).
Oh. No problem. I have a TIP and TIP CRI. They will be good for me till the time when the TINI will be available for 15$
BLF Q8 4x XP-L 5000LM Professional Multiple Operation Procedure Super Bright LED Flashlight
Use coupon code PTRQ8 to lower the price $48.50 (-$31.45)
Astrolux S2 XPL-HI 1400LM EDC LED Flashlight 18650
Use coupon code PAXS2 to lower the price to $24.99 (-$10.01)
This is exactly BLF X6 but with different logo (same BLF conceived FET+1x AMC driver with bistro software).
1A, 3A, 3B tint options available and all in stock.
Klarus Mi1C Ti/Cu XP-L HI V3 600Lumens Compact Mini EDC LED Flashlight
New coupon code with even better discount available! (It’s not public.)
Nitecore NU10 160LM Wide Angle USB Rechargeable Work LED Headlamp
LUMINTOP Tool AA XP-L HD 550LM 3Modes Portable Magnet Mini LED Flashlight AA/14500
Solarstorm DX4S 4 x XM-L2 U2 3200LM Diving LED Flashlight 60M
Coupon code with discount is available but it’s not public.
BLF X6 X5/Astrolux S2 S3 SS SC Flashlight Bistro Driver
Use coupon code PLFDR to lower the price to $6.99 (-$2.00)
2LED 17mm DIY Lighting Switch Set For Astrolux SS/SC/S2/S3/BLF X5 X6 LED Flashlight
Use coupon code PLGSH to lower the price to $2.99 (–25%)
Astrolux S42S Stainless Steel 4xNichia 219C/XP-G3 2023LM Rechargeable Mini LED Flashlight
Use coupon code FLSTNE to lower the price to $36.76 (-$9.19 / –25%)
To get maximum light output and runtime from this light you should use high drain 18650 battery with additional tube available here:
Astrolux S41S/S42S Flashlight 18650 Extension Tube Body Tube for $9.00 or with using BG points for:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$7.65 |
$7.56 |
$7.47 |
$7.38 |
$7.20 |
Nitecore NU30 XP-G2 S3 400LM Multi-purposes USB Rechargeable LED Headlamp
Convoy C8 Xp-l Hi 7135*6 Integrated Head Long Range LED Flashlight
Use coupon code PCOY8 for 18% discount. Price drops to $15.54
Nitecore HC33 XHP35 HD 1800Lumens High Performance L-Shaped LED Headlamp Flashlight
Coupon code and price are not public.
LUMINTOP Geek XPL HD 350Lumens Multifunction USB Rechargeable Portable Mini Keychain EDC Flashlight
