Yes, exactly. Get liquid metal on any aluminium part and that part will be gone soon. The aluminium will simply fall into pieces
Also Copper + Copper might be a more eternal joint than you would hope, although there is no danger of the copper being corroded away by the liquid metal. If the copper is gold plated like on most boards, this won’t be a problem though.
Yes I have always known that liquid metal reacts with aluminum.
The MCPCB and block are both copper.
As I said before, there is no risk of any liquid metal coming out anyway, there is a fraction of a gram compressed between the two pieces of metal and not enough space for it to exit.
And again, as I said before, even if there is a drop, it forms a ball just like mercury that rolls off of a surface, it does not stick.
It would not cause any damage to the aluminum on the reflector unless it was rubbed onto the surface such that it broke the surface tension and made contact. This would also require a lot more liquid metal than is even applied in the light.
It’s honestly not as scary as people make it out to be.
You even get a ton of applications with the 1g syringe, like more than 10.
I have updated the table because more practical tests have shown that the Synios LEDs are not quite as good as we thought. The luminance of the CFT-90 is also not certain yet. Vinhnguyen54 got 1.58Mcd in a BLF GT and 900kcd in a TN-42 at sub-maximal current. I don’t know of any other values.
He said he got just 20 amps in GT. Frankly, it beats me why so low.
Maybe he posted it as a conservative number that any modded light will reach with much used batteries, but anyway he has a lot of headroom.
Maybe there are too many losses in the main springs.
It’s also a DD light. It’s difficult to base anything off of those kinds of measurements. Measuring high currents obviously needs to be done correctly, otherwise the measurement will reduce the actual current.
I have updated the values in the table to reflect koef3’s newest findings.
I didn’t anticipate having to change them so often… :D.
EDIT:
Since the luminance values of some LEDs are lower than anticipated, we need to also question those of the Luminus CFT-90.
vinhnguyen54 measured 3800otf Lumens and 900kcd with this TN42vn90.The reflector openings have 89mm and 28mm diameter (so 5605mm^2). Lets say that the lens transmission rate is 98% and the reflectivity of the reflector is 85. Lets also say that the reflector collects 75 of the emitted light.
I thus get 4390 led lumens and 193cd/mm^2. sma measured around 185cd/mm^2 at 4400 lumens, so it can be concluded that the values match.
I would be also interested in OSRAM OSTAR Projection Compact KW CSLNM1.TG. In many ways similar to Black HWQP, but newer.
djozz, when I search for Luxeon CX I see some COB…
You’re right, these seem to be even better than the black flat, assuming they can be overdriven just as much.
LUW HWQP: White 3.05 W 325 lm 108 cd 1000 mW 334 mW/sr 120°
KW CSLNM1.TG: White 3.00 W 325 lm 108 cd 1000 mW 334 mW/sr 120° KW CELNM1.TG: White 3.00 W 374 lm 124 cd 1150 mW 384 mW/sr 120°
All three have 1.03mm square die, but the CELNM1 is both brighter and more efficient than the other two.
Also, no notch at all for these new LEDs
There is also this larger version, closer to the Q8WP koef3 tested recently that got almost as high cd/mm^2 as the black flat.
LE UW Q8WP: White 4.20 W 533 lm 153 cd 1650 mW 473 mW/sr 130°
(die size 1.91mm^2)
KW CSLPM1.TG: White 4.20 W 515 lm 171 cd 1590 mW 529 mW/sr 120°
(die size: 1.99mm^2)
The main difference is that the KW has no side emission like the Q8WP did so possibly more of that light is going forward and could potentially give higher cd/mm^2 despite larger area and lower stock output.
Yeah, but CELNM1.TG has a tiny thermal pad. And it doesn’t make up for this with smaller thermal resistance inside the package - actually it’s a bit worse here too. So likely it won’t be possible to overdrive it so much.
This also has a much smaller thermal pad than the older LED.
Due to better efficiency I find it interesting, but I don’t expect it to beat Q8WP.
It’s interesting that now we’re discovering several years old emitters that are great for our application.
And sad how the later generations are often just inferior for what we do.
And what’s worse - we’re not a big enough market to even keep an old product alive, let have one developed for us.
Oh you’re right, I wonder why the CELNM1 has a higher stock output then, if it’s basically the same die.
The CELNM does have higher thermalresistance due to the smaller pad, but what’s cool is that the CSLNM actually has less thermal resistance than the black flat.
For the CSLPM1 even though it has a smaller thermal pad it is still the same size as the CSLNM1 and has the same thermal resistance as the Q8WP, so it might not be that difficult to cool well.
So in summary:
LUW HWQP: White 3.05 W 325 lm 108 cd 1000 mW 334 mW/sr 120° = reference
KW CSLNM1.TG: White 3.00 W 325 lm 108 cd 1000 mW 334 mW/sr 120° = same contact pad size, lower thermal resistance
KW CELNM1.TG: White 3.00 W 374 lm 124 cd 1150 mW 384 mW/sr 120° = small contact pad, higher thermal resistance, for some reason better performance at stock? will not work on any normal MCPCB
LE UW Q8WP: White 4.20 W 533 lm 153 cd 1650 mW 473 mW/sr 130° = large contact pad, lower thermal resistance than black flat
(die size 1.91mm^2)
KW CSLPM1.TG: White 4.20 W 515 lm 171 cd 1590 mW 529 mW/sr 120° = same contact pad size as black flat, same/slightly lower thermal resistance as Q8WP (much lower than black flat)
I just noticed something interesting about the Black Flat:
It only has one bond wire. In his test Köf3 noted that one of his Black Flats died at 5.4A because the bond wire melted. So we can conclude that it can tolerate up to ~5A. This also means that it gets warm at currents close to that. This might be one reason why the Vf of the Black Flat is so high at high currents, which of course makes it run hotter than it would otherwise.
The Cree XP-G2, XM-L2, XP-L (HI/HD) and Luminus SST-40 all have two bond wires. The latter goes up to 9.5A.
Now of course we don’t know if they use bond wires with different diameters 8Cree might have reduced the diameter of the XM-L2 bond wires at sme point because they now die at lower currents than in the past).
I do think it’s interesting though that the Osram Q8WP has not two, but four, very thick looking bond wires. They should not be heating up nearly as much as the single one in the Black Flat.
Here are the results Enderman posted back then. His voltage measurements seem incorrect though (way too high), there was probably some additional resistance involved.
The problem here is that he can't really prove why his LEDs performed better in that setup. You can only test it for yourself by emulating parts of the process (his specific thermal paste, active cooling, his way of soldering etc.).
