lostheplot
(lostheplot)
February 16, 2018, 8:32am
78
yes square thread pp ground my own tool slow and steady
next bit is a little boring
ended up with this
spun it around just want to shape the head a little,not sure how yet,
next week,.
and yes mrs dnf all pics are from the s5 as it is easy to upload with the app,
kiriba-ru
(kiriba-ru)
February 16, 2018, 8:52am
79
lostheplot
Do you have a mill?
lostheplot
(lostheplot)
February 16, 2018, 9:34am
80
I have this Chinese mill drill
MRsDNF
(MRsDNF)
February 17, 2018, 1:20am
81
The threads look real good LTP.
lostheplot
(lostheplot)
February 17, 2018, 2:13am
82
I was happy enough for my first attempt
V threads are better.
lostheplot
(lostheplot)
February 22, 2018, 2:47am
83
Realized I needed a bezel
skimmed bit of flat
turned it to suit
trimmed the back of the head a little
its a sizable thing
now to get time to finish and source some orings
ARsee
(ARsee)
February 22, 2018, 5:26am
84
Nice re-purpose of a cylinder shaft LTP. :+1:
MRsDNF
(MRsDNF)
February 22, 2018, 9:45am
85
Its coming along nicely LTP. Not hard to tell your new camera pictures. :+1:
lostheplot
(lostheplot)
February 22, 2018, 9:50am
86
Sorry to dissapoint. But i just wiped the crud off the phone lens
Its finally done.
Beamshot .
Beside Acebeam K40m
Opened up
Recap 4 x 21700 Xhp70.2+L6 smooth reflector+ Lexel ta Driver with Bistro
Thanks 4 watching
djozz
(djozz)
June 16, 2019, 9:59am
89
Very nice build! That will take some time to warm up, even with a 70.2. Is the led on a 20mm board? Any idea what current it draws?
The beam looks impressive!
20mm board from kd. no idea of current I was hoping 7 or 8 amps,
I don’t think heat should be a problem,
Must be a good light for camping. Solid chunk of ali with good battery life. Nice.
ok charged the batts 11.3 amps when fresh,so should be good for roughly 7000 lumens may try some heavier wires to the led and see if I gain any thing
I have all ways wanted to do a lightbar, so thought I would knock up a prototype using
xhp50.2 12v 5000k
C8 reflectors
Lexan lens
3amp drivers was going to run 2 x 3a but dropped back to only 1. from Russia …
https://www.ebay.com.au/itm/LED-driver-LD-3A-3A-12V-DC-5V-27V-for-CREE-XHP50-XP-L-XM-L-L2/113691430333?ssPageName=STRK%3AMEBIDX%3AIT&\_trksid=p2057872.m2749.l2649
roughing out the alloy
not quite enough hardware for all the holes,
radiusing the corners
pocket for driver
assembled light
cheap ebay heatsink for the driver on back
not dark yet
relatively happy with spread / light output
nearly 3a with the car running 14v
so guessing 5000 odd lumens .
wondering if I should run the leds at this level or at 3a each,
now to make one with 10 reflectors that may take a while
MRsDNF
(MRsDNF)
August 3, 2019, 11:30am
97
You could run 3 amps each if it was cooling satisfactorily. Looks good by the way. Have your flat here still. Not sure how your going to get it.
Cheap as well. Will only cost you two of these lights.
