The name of the seller is easy to remember, since somebody once pointed out that it sounds like ‘Garbage’.
(there is no such thing as an 18650 battery with 6000mAh capacity - or any lights running on a Cree XM-L T6 emitter that put out thousands of lumens)
Sorry if I can’t be of more help, but maybe you could start a new thread asking for suggestions? There are many knowledgeable people on here who will be sure to help you.
Thank you for responding. So is the brand Garberial not good? Again, newby question. thank you
I might have my info mixed up, but I was considering buying 3 lites and was looking at the pelican 7600 and was wondering if you or ANYONE on this thread, had any suggestions or a comprable light that might be even better than the 7600?
I wouldn’t trust any brand that claims their 18650 batteries have 6000mAh capacity (I think 3500mAh is still the maximum that’s possible), or who sell ‘Cree T6’ flashlights that allegedly put out 10,000 or 20,000 lumens. I doubt that the Cree XM-L T6 can be pushed much harder than about 1,000 lumens, and most of those cheap lights don’t even have genuine Cree LEDs, but inferior quality ones (‘LatticeBright’).
[quote=brenton)
I have some properties I manage with large yards that have little or no light.[/quote]
How big are the yards ?
What do your family members want to use the lights for ?
The 2 above questions will determine what lights you need.
It could be that a flooder like the BLF designed Q8 would be better for lighting up the yards & a simple Convoy S2+ might be ideal for the family use, it all depends what the use is ?
I vote that for any other blf group buy that you are purchasing a light in, we make dang sure you get one of the very first lights. Your analytical capabilities are fantastic (just wish I could understand it all)
I know the beam doesn’t converge when measuring at close distance, but for what it’s worth, I got 860kcd at 6.1 meters on the max ramp (6.1^2*23106 lx on the CRI measurement above). So even this close, it’d probably be around 1Mcd on turbo.
Yep, those numbers sounds about right from my own testing as well. It generally takes about 20m to get the peak throw numbers and turbo will make a difference in meter readings.
I have had both of my GT’s in momentary mode the last few weeks, it is fun to just blast them.
