Thank you for responding. So is the brand Garberial not good? Again, newby question. thank you
I might have my info mixed up, but I was considering buying 3 lites and was looking at the pelican 7600 and was wondering if you or ANYONE on this thread, had any suggestions or a comprable light that might be even better than the 7600?
I wouldn’t trust any brand that claims their 18650 batteries have 6000mAh capacity (I think 3500mAh is still the maximum that’s possible), or who sell ‘Cree T6’ flashlights that allegedly put out 10,000 or 20,000 lumens. I doubt that the Cree XM-L T6 can be pushed much harder than about 1,000 lumens, and most of those cheap lights don’t even have genuine Cree LEDs, but inferior quality ones (‘LatticeBright’).
[quote=brenton)
I have some properties I manage with large yards that have little or no light.[/quote]
How big are the yards ?
What do your family members want to use the lights for ?
The 2 above questions will determine what lights you need.
It could be that a flooder like the BLF designed Q8 would be better for lighting up the yards & a simple Convoy S2+ might be ideal for the family use, it all depends what the use is ?
I vote that for any other blf group buy that you are purchasing a light in, we make dang sure you get one of the very first lights. Your analytical capabilities are fantastic (just wish I could understand it all)
I know the beam doesn’t converge when measuring at close distance, but for what it’s worth, I got 860kcd at 6.1 meters on the max ramp (6.1^2*23106 lx on the CRI measurement above). So even this close, it’d probably be around 1Mcd on turbo.
Yep, those numbers sounds about right from my own testing as well. It generally takes about 20m to get the peak throw numbers and turbo will make a difference in meter readings.
I have had both of my GT’s in momentary mode the last few weeks, it is fun to just blast them.
Part of it is the distance but yes, with low drain cells like that and the higher then expected Vf of the LED (we have planned on 1V lower when designing the driver) it will fall out of regulation much faster then planned.
For best results try some high drain cells and put in 8 cells if you can and see if the readings improve.
With only 4 laptop cells (about the same quality as the ones you are using), I noticed I could not hit full 2.5A to the LED in my light.
With GA cells it worked fine though and 30Q worked even better for regulated runtimes.
