as all Clicky Tail cap lights it goes out when you turn the switch on
yeah if it turns off when you hit the rear clicky on an L6 then I’m in for at least 3.
I also have 4 LED boards for side switch on the L6, so always one switch is lit
L6 as e-switch light has limited current on the tail one as the bleeder resistor needs to to be pretty high (0.15-0.3mA)
Ill get in next days a L6 to mod then I can test the driver, the L2 driver has an odd behavior that you do not need a bleeder as the driver bleeds already to an LED Tail board
fabulistic!!!
Looks very nice Lexel! I have a hard enough time matching same color LEDs and experimenting with resistor values in my lighted tailcaps, let alone the complexity of what you have done. I admire your ingenuity. :+1:
I did today more testing with my Convoy L6 drivers and illuminated tail caps
Final result is that with the parts I use on the driver I can feed up to 1mA to the tail cap without using a bleeder resistor, so there is no standby drain from a bleeder at all when the light is switched on over the tail switch
This is likely due to the voltage regulator I use that is so friendly and bleeds for me to the tail cap
Does the stock driver work with the lighted tail cap? I'd also be very interested.
Tested this with stock driver it does the same
Very interested then. One color like purple is fine for me and maybe another one blue.
Edit: Maybe I misunderstood, but if the rainbow ones light up equally bright, then I would prefer those over one color for sure.
Very interesting!
The rainbow board is designed to light up equally bright even with the cell voltage dropping down to about 3-3.4V depending on brightness and Bleeder resistor values
On 2S lights I discovered an interesting behavior that makes side and tail switch glowing on my 3 Channel 2S TA drivers in an L6 for example
Interested
Very interested then for a few of them.
I’d be very interested in a lot tailcap for my Astrolux S1 if I could find one that would play nicely with the driver.
Interested
Bump? :innocent:
I’d be interested in a couple but with a different color scheme than rainbow.
Interested in a couple rainbow color scheme
Yes I know its late but I am super busy with some big projects with flashlight companies as well with the usual driver orders
2. generation with bugfix I got to here ready to be build, just need to work to make a proper sales topic
3. Generation with LVP and low battery warning I got the boards now here but unfortunately the ICs are backordered to 27. June
this LVP needs also some testing before I can hopefully sell v1 of the boards or may need to make a bugfixed board
Please PM me with what you want
