Oh. No problem. I have a TIP and TIP CRI. They will be good for me till the time when the TINI will be available for 15$
BLF Q8 4x XP-L 5000LM Professional Multiple Operation Procedure Super Bright LED Flashlight
Use coupon code PTRQ8 to lower the price $48.50 (-$31.45)
Astrolux S2 XPL-HI 1400LM EDC LED Flashlight 18650
Use coupon code PAXS2 to lower the price to $24.99 (-$10.01)
This is exactly BLF X6 but with different logo (same BLF conceived FET+1x AMC driver with bistro software).
1A, 3A, 3B tint options available and all in stock.
Klarus Mi1C Ti/Cu XP-L HI V3 600Lumens Compact Mini EDC LED Flashlight
New coupon code with even better discount available! (It’s not public.)
» Request via PM here«
Nitecore NU10 160LM Wide Angle USB Rechargeable Work LED Headlamp
Coupon code with nice discount is available but it’s not public.
LUMINTOP Tool AA XP-L HD 550LM 3Modes Portable Magnet Mini LED Flashlight AA/14500
Solarstorm DX4S 4 x XM-L2 U2 3200LM Diving LED Flashlight 60M
Coupon code with discount is available but it’s not public.
BLF X6 X5/Astrolux S2 S3 SS SC Flashlight Bistro Driver
Use coupon code PLFDR to lower the price to $6.99 (-$2.00)
2LED 17mm DIY Lighting Switch Set For Astrolux SS/SC/S2/S3/BLF X5 X6 LED Flashlight
Use coupon code PLGSH to lower the price to $2.99 (–25%)
Astrolux S42S Stainless Steel 4xNichia 219C/XP-G3 2023LM Rechargeable Mini LED Flashlight
Use coupon code FLSTNE to lower the price to $36.76 (-$9.19 / –25%)
To get maximum light output and runtime from this light you should use high drain 18650 battery with additional tube available here:
Astrolux S41S/S42S Flashlight 18650 Extension Tube Body Tube for $9.00 or with using BG points for:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$7.65 |
$7.56 |
$7.47 |
$7.38 |
$7.20 |
Nitecore NU30 XP-G2 S3 400LM Multi-purposes USB Rechargeable LED Headlamp
Convoy C8 Xp-l Hi 7135*6 Integrated Head Long Range LED Flashlight
Use coupon code PCOY8 for 18% discount. Price drops to $15.54
Nitecore HC33 XHP35 HD 1800Lumens High Performance L-Shaped LED Headlamp Flashlight
Coupon code and price are not public.
LUMINTOP Geek XPL HD 350Lumens Multifunction USB Rechargeable Portable Mini Keychain EDC Flashlight
IMALENT HR70 XHP70.2 3000LM Brightness Magnetic Charging LED Flashlight Hiking Headlamp Torch
Coupon code with nice discount is available but it is not public.
- Cree XHP70.2 LED
- max 3000 lm (turbo timer: 1.5 min, then steps down to 1000lm)
- high mode: 1500lm (3min timer, then steps down to 1000lm)
- max continuous(no step down) mode: 1000lm
- max runtime: 50h
- direct access/shortcut to low mode
- hiden strobe with direct access/shortcut
- magnetic charging (can be used during charging so it’s possible to use any powerbank as uninterrupted runtime extension)
- magnetic tailcap to affix to any ferromagnetic surface like car hood
- low voltage LED indicator in head
- 3000mAh high drain battery included
SKILHUNT H03F XM-L2 U4 1200LM Adjustable LED Flashlight Headlamp
Xiaomi Mi6 Mi 6 5.15-inch 6GB RAM 64GB ROM Snapdragon 835 Octa Core 4G Smartphone
Use coupon code 3BGMI664GB to save $19.75 - price drops to $375.24
Xiaomi Mi A1 MiA1 Global Version 5.5 inch 4GB RAM 64GB Snapdragon 625 Octa core 4G Smartphone
Use coupon code 3BGXA164G to save $22 - price drops to $193.89
Nubia M2 Global Rom 5.5 inch 4GB RAM 64GB ROM Qualcomm Snapdragon 625 Octa Core 4G Smartphone
Use coupon code BG6M26 to save $20 - price drops to $149.98
This is a very popular budget model with well balanced hardware. Even has AMOLED Full HD display, global LTE bands(TDD-LTE B38/39/40/41, FDD-LTE B1/B3/B5/B7/B8/B2) and 14nm power efficient processor.
Original Xiaomi Power Bank 2 10000mAh Quick Charge 2.0 Portable Charger with Micro USB Input
Use coupon code MIPOWER for 21% discount - price drops from $21.99 to $17.37 (-$4.62)
