[PART 1] Official BLF GT Group Buy thread. Group buy officially closed! Lights shipping.
Can someone providing me Tracking code, pls :frowning:
It’s btw in no way any criticism. Both light throw extremly well. Just slight difference in beam profile, but with so much variables its expected that there are some.
Thanks!
Very good explanation from Enderman…
seems not shipped atm
Received my unit in Salamanca (Spain). Registered mail. Batteries included. One box. No fees.
It’s awesome. The Led is perfectly centered. The reflector is very well mechanized. It’s an amazing flashlight.
Congratulations, GT Team, for this spectacular project. Thank you!
I’m going to measure throw of my GT and Nicolaas’ GT somewhere next week, it seems that you and/or your dad are also in or near Amsterdam?, we could make it a 4x GT session then if you are interested.
Too bad i don’t live near Amsterdam, otherwise i’d join :wink:
Both GT’s on moonlight about 3 meter distance. Right is mine, left my dads.
image uploader
I would be very intrerested to find out what exactly is causing the difference - and how big the difference is on Djozz’ light meter…….
Provided good whether we could go outside (we have a nice beamshot area at a 5 min drive) and compare our GT’s to some other lights,
like my TN42 and modded Nitecore TM36 Light (dedomed XP G2 S2 with 849Kcd).
Cheers
Nico
on 3m distance and lowest ramp (on - ramp up a bit - then ramp all the way down) i get a ~14cm spot
Does anyone know where to buy the exact same eye screw connector that is on the GT? I would like to use them on my Q8’s for a lanyard.
I think it’s the reflector. There’s a difference in reflection, my son has almost mirror finish (like it should be), while mine produces a blurry image of everything that reflects.
Am I the only one who received just 1 battery carrier with 4 batteries?
For now I’m using some bubble wrap to fill the empty space, so I can at least use the GT with just one carrier.
I understand they are a std size for cameras and tripods etc
In the (small) Netherlands is all near Amsterdam, isn’t it? :smiley:
Trafic in Netherland is not very fast and it is very strict, thats what I learned in one of my last hollydays.
To my eye it looks like the hotspot itself is about the same size, the difference appears to just be the corona, which is what the different reflector finish would do.
This should not have a very large effect on the actual real world throw of the light, as we have seen even the V1 reflectors can light up a water tower at 1.9 miles away. It mostly just causes the hotspot to be smoothed out.
I saw this with the V1 to V2 reflectors but the real world performance difference was only marginal in my case.
I would also venture to say that a focus issue could be at fault.
Maybe the centeirng ring somehow got on top od the screws and cause it to change the focus? Not likely but only thing I can really think of.
Wow, that’s a little further back from me, but a big difference in size. 8” to 5.5” or 20.5cm to 14cm
It almost makes me think the curvature of the reflector is slightly different. I doubt it’s the finish. My guess would be a different reflector height.
how about some pictures of the reflectors side by side?
Ah, so Bozlight29 is the dad of Polarweis. Now the above statements make sense. I was confused for a while. Lol
I think I figured it out. I can shrink my hot spot down from 8” to about 6” if I remove the black centering spacer and carefully move the reflector closer to the emitter.
I don’t know if this will have a positive or negative effect when measured further away. I assume it will improve the throw, but I’m not positive.
Polarweis and Bozlight29, do you have different black centering plates? One with big hole and one with small hole? Maybe they are different thicknesses.
