Nice slice!
Beer its just using good German bear to develop that technique
the final LED is not sliced
Yes that is the key I agree!
Beer in combination with right flat washer and dremmel polish tool
Lexel: AgentSteel:How did you do it? :+1:
doubleone44:Nice slice!
the final LED is not slived
I have a Dremel, but its not used for it
now I see the wilkinson razor blade in the picture! :person_facepalming:
Wow, nice job lexel!
It looks nice. But, how can it be as good as XPL?
I mean from the surface smoothness they are even better than XPL HIs
I can do this with all LEDs
one thing with bond wires is the fine tuning
Firts attempts look like this
Bond wired cut
Sliced and then sanded/polished down with 1500 or finer with a washer as a guide to maintain width/flatness.
The silicone surface needs to be cleaned thoroughly and little bit of debris, when the emitter heats up will burn the silicone.
Wow that looks pretty tidy.
As everyone else seems to be guessing the technique, I’m going guess microtome
and the winner is
KawiBoy1428
but yes those microscope slice machines might work as well, but are out of my budget
KawiBoy1428:Sliced and then sanded/polished down with 1500 or finer with a washer as a guide to maintain width/flatness.
and the winner is
KawiBoy1428but yes those microscope slice machines might work as well, but are out of my budget
:+1:
Sweet. Nice Lexel. :+1:
Looks great :+1:
So, when does sale start? :innocent:
I second this, “when does the sale start?”
Good tip Lexel, might try it myself sometime.
Do you think it will work on XPL2 HD? It should outperform XPL-hi in my opinion
Have to buy some razorblades first, always use my Philishave
Razor blade is the first step
I used a thicker washer for it as first step
Then a 2. 0.1mm thinner washer for the 1500grit paper
3. Washer 0.1mm thinner
start with 2500 grit
used 5000 then
last a very old used 5000 one
Looks great.
May I suggest XHP35 E4?
What’s the source of washers?
