FWIW… A few months ago Amazon had that light available as a $5 add-on item. I tried to add one onto my order but it sold out. It was still popping up on their www site as recently as a month or so ago.
I am somehow attracted to zoomies, but I see some are missing from the list: Xtar WK007, Severe cold, Fenix FD41, Fenix FD40, Fenix FD45, Brinyte B168, Brinyte B158B, Fenix Fd65. I can’t yet decide whether I like the wide of the TIR lens more than the throw of the aspherics
BTW, has anybody been able to open Fenix FD40/41? I don’t quite like the 6500ish white, but I love the beam profiles.
Hi yasenf, the Xtar WK007, Fenix FD41, Brinyte B168, Brinyte B168B are all on the list, not sure why you’re not seeing them? (The list isn’t in any kind of order) Also the Odepro KL52 is on the list but now we can just get the 168B (same thing)
But yes those other 3 Fenix I didn’t list, thanks for pointing them out! I’ll add them as soon as possible.
The Severe Cold is showing “Sorry, this item is no longer available!” by the seller, but Argo bought one by asking, and I’ve contacted them and they said it’s available, (see posts above) However I’m waiting to see if they’re going to make the listing active again before I add it to the list so I can have a good link.
BTW, the photo you posted isn’t showing up for some reason.
Also you may have already seen this but I wanted to post this thread about the FD40 with a lot of photos and comparison to the Zeusray, Warsun X65 and Jax Z1. But I didn’t see anything mentioned about disassembly, I guess that one’s been around for a a while:
BTW the SevereCold reminded me slightly of this (P7.2) clone:
I didn’t add it to the list because it uses primary’s not Li-ion.
I think it has the same lens system as SevereCold?
The optics in the clones suck, they are far from as good as the real thing.
You can find a lot of tests and reviews on led lenser clones and none give the nice round spot with no spill and almost perfectly uniform wide-angle spill that the real TIR does.
Thanks for the heads up on the clones, do you know who else makes good “real” TIR zoomies? I’d like to try one. The MT10/MT14 do look interesting to me, although I bit pricey. I think those are the only Led Lenser zoomies that run on regular size Li-ion?
Are Coast flashlights still made by the same Mfg as Led Lenser? I have an older “Coast Led Lenser” (Non-zoomie)
I just received my first single emitter TIR zoomie, the Litesam E11Z (Re-branded FiTorch P30Z) it does have a nice round spot but the edges aren’t crisp like the square spots, also has a big dark donut hole at all in-between positions, which basically makes it a a two mode light, full flood or full throw.
The Coast TIRs, at least the one’s I’ve seen, make a combined spot+spill like a reflector light in the zoomed in position.
This is different from the spot-only led lenser TIR.
OK thanks didn’t know. Which Led Lenser model(s) do you have?
This MT18 looks interesting, I wonder if it’s really 3000lm. I’ve read they’re pretty much true to spec on their output ratings/claims.
I wonder what emitters they’re using in these MT series.
Thanks for the links, unfortunately no word for disassembly.
Fenix FD 45 and 65 are quite new models, in the FD series they also have 2 more: FD30 - tube light with 18650 battery - I had it, but was not impressed, as well as Fenix FD20 - XP-G2, 2xAA zoomie.
I’ve used a P7, T7, p5r.2, and some other small one.
I EDC the p5r.2
Not really a fan of the new design, but it’s nice that they’re switching to standard 18650 and other liion batteries now.
The list of zoomies here has grown quite a bit over the past month, now over 75 models listed! I changed the title of the thread to describe it better.
XR7 does not run on Li-ion battery, and XR8 still only 400Lm
While searching on line for those I did find something that was VERY exciting…for a minute (before I found out it’s discontinued :rage: )
The Tasco XR9r
This apparently was a pretty awesome flashlight from about a year ago! With so many great features I have no idea why it was discontinued.
800 Lumen!
Zooming focus
Lighted tail switch!
Magnetic Tail Cap!
Runs on 18650 Li-ion!
Built in USB charging
Hidden USB port under a knurled stainless ring!
USB Powerbank feature!
Stainless steel bezel ring
Round spot beam instead of square!
I guess these were selling for under $30 at Sams Club, but they were also on Amazon a while back (sold out now):
Amazon reviews were all 5 star, one reviewer commented:
“This light isnt being made anymore. I called Tasco (Bushnell) to ask where I could get another and they said it was a one time deal with that Big Box store. No plans to make them again. I don’t understand that but that’s what they said.”
After an extensive online search I was only able to find it showing available at one store……
But when I tried to buy it (just to check) it shows; “Our shopping cart is undergoing maintenance.” LOL http://www.tacticalsuppliesexpress.com/item/13837047/
Price was a little high anyway: $59.97 Sams Club did show it on their auctions site from a while back, they were probably a great deal in the auction.
Now all the zoomies at Sams are all low output and run on Alka-leaks, nothing nearly as nice as the XR9r was.
Interesting budget zoomie, looks like a TIR (flat front lens) but has a square hot spot.
I guess it could be an aspheric behind the flat front lens though. But I’ve not seen that before.
Or the beamshots in the listing could be generic / from a different light, I see that a lot on Aliexpress too.
The XR8 is longer than XR7 so you can use 18650 in barrel. The XR9R was good for its time. But the technology has surpassed with those form factors encompassed in XR9R.
Thanks for the info, usually that doesn’t work because the 3xAAA battery holders are around 5-10mm shorter than an 18650.
Can you please explain your point of view? To me it looks like the XR9r was way more technologically advanced than XR7 and XR8.
XR9r was only from 2016-2017 and has many features that even some new models are lacking, it’s not outdated by any means that I can see. It most likely was discontinued due low sales from being priced too high for a large discount chain store.
