[PART 1] Official BLF GT Group Buy thread. Group buy officially closed! Lights shipping.
How the two pieces of the GT were declared for the Customs please?
Lumintop already went to work, you said to remind you about the incorrect track number.
Flashlight was sent and received in the US, not in Kazakhstan
My GT arrived on thursday, and it truly is awesome. Both packages were quite moistured and the lamp itself also had some moisture on outer surfaces and inside the tube, but otherwise in good condition. Also got the batteries with the lamp, and thats really great, because ordering batteries to Finland has been impossible for the past few months.
Great work from the BLF GT crew and all the people that were making this possible
Thanks!
Man, it sucks they got wet. It’s like they got left out in the rain or something.
Lumintop needs to get their registered mail boxes sorted, as well. Some extra padding around the head is definitely needed.
Anyway, here are a couple of pics of the head taken apart for those interested. I added these to post #3.
Btw, this is my light. It’s got a different switch cover. Stock is black.
/\\\ Good pictures Jason!! Thank you……. :+1:
After seeing these, it finally hit me what KB has been saying about the LED centering spacer “floating” on/around the two MCPCB retaining screw heads. :wink:
Was it difficult to take this apart?
Is there a new era of throwers? Is the GT overcome? WHITE LASER WL20 THROW 2000M. The maximum distance of up to 5000 meters. :open_mouth:
It’s 2000m, and yes there are laser-phosphor flashlights coming in 2018 that will give a lot more throw and less lumens.
It’s not an LED flashlight though, and won’t get anywhere near the same amount of lumens.
Hows about swapping reflectors? That would show if it’s the reflector that’s causing that issue or not!
Initially, yes. I suspect Lumintop tightens the big bezel before tightening the upper head to the lower “light engine”. This way they don’t have to turn the bezel against the massive friction of the huge o-ring against the glass.
So I would recommend everyone to loosen the upper head first so you take all the tension off of the reflector, glass and bezel and then it should be a lot easier to turn. Using this new technique I can take my GT apart and put it back together with my bare hands.
Here is my older post on taking it apart:
I would try and find a pair of cheap rubber strap wrenches. After loosening the bezel on mine, I hand tightened it so I would be able to remove it by hand later. Nope, it’s too tight again. I had to use the strap wrenches once more. That o-ring against the lens is a real friction freak.
The head was hard to loosen, but it’s no big deal to tighten and loosen again. No tools needed after the first loosening.
I got a 2 pack of rubber strap wrenches at my local Northern Tool store for $5. Check your local stores bargain bins where the cheap tools are.
I made the battery carrier to take Flat Top cells. Check out what I did here : BLF GT review
No reverse polarity protection this way. Btw review is not completely finished yet.
What good is it with 500 lumen and a tiny pencil beam? I’m sure a few people would find it useful, but not the majority.
It reminds me of that little bitty LED that was smaller than the oslon black flat and it only had about 400 or so lumen. What was it called?
No messages sent yet for the third group,stay tight, You will receive it by the end of the month (supposely next week)
We can’t say for sure. It’s up to TA to decide when.
The description was copied from Acebeam. They have already fixed it. Also it was strange for me.
:+1: :+1: :+1: :+1:
Hi all,
Have looked through the threats but cannot fin it (answers).
Can someone please advise when the next production run is, and the cost of the light?
Thanks for reminding me. Anyone else with outstanding issues that I asked to wait until after the CNY, now would be the time to start reminding me about them.
You can also try sending messages to Neal directly but please, only message him if you truly have an issue that needs to be addressed, he is overloaded as it is.
I will put together a list of issues that need to be resolved and we will try to get them sorted before the next batch of PM’s.
The next batch will go out when the last 50 orders have been shipped. I hope this will happen in the next week or 2, it depends on how fast China comes back online.
I will know more next week once we see how things start coming along.
The group buy is closed, public lights will be available after the GB is finished.
Figure an average of ~100-125 lights a week with the V2 reflector tolerances and we have ~650 more lights for the GB and a reasonable guess is around 8+ weeks for the GB lights to be finished figuring at least one delay will pop up along the way.
After that it is only a matter of time for them to show up for sale in other places.
Those in the next batch, please keep in mind that it will most likely take ~8 weeks or more for the all lights to be shipped.
