There is also a blink in the middle at highest regulation level (I think). So, yes, people that don’t know what it is think they have a malfunctioning light. I have seen a few complaints on FB groups.
No, this isn’t designed for muggles, but it might be given to them and/or eventually sold to the general public at which point Lumintop might get a flood of complaints for an actual feature thinking the light is a POS. I would hate to sour Lumintop’s experience with BLF. (Sure, they could turn that off for the public version, but would they?)
My 2¢
I stick by my A, D, and non-committal C vote.
I think this will be a great pocket edc. and am looking forward to the completed product.
How about making the blinks at 1x7135 and 8x7135 configurable? Maybe the default is no blinks. But have a hidden configuration option that would let the end-user turn on the blinks if desired.
That way you get the best of both worlds: Smooth interface for muggles, with the option to go to a more detailed interface for flashaholics.
I first got a few flashlights with xm-l2, xp-g2 and xp-l, and after I got my first 219C emitters I’m baffled at how someone wouldn’t like the tint and quality of the beam. I understand one not wanting to trade output for CRI, but not liking it? Preposterous!
Just out of curiosity, how difficult would it be to make it ramp down smoothly rather than distinct step downs when it starts to get too hot? Just a random thought that occurred to me, but I thought it might be one of those subtle differences that bumps up the impression of a high quality piece. I know its something that I would like to see on my D4 at least.
This may have been suggested or mentioned before; apologies if it has, Ive not yet had a chance to read through all the posts.
The modern firmware revisions that would be used in this light have seen some work, and will not only ramp down smoother (maybe not perfect; I don’t remember how it’d been going), but also ramp back up just as well if you cool it off by for instance going outside into colder air, or by putting water on it. Though this light won’t have much metal to absorb the heat, so it will not last very long before it has to step down, it should be much better at managing heat and brightness.
I own a bunch of 4000k to 5000k 219c and 219b flashlights. Although they have the highest CRI, their tint is nowhere near as beautiful as the perfect XP-L HI 4000k 5D tint, which contains no yellow/green at all. Just a beautiful neutral with a slight hint of rosiness.
But I think XPG3 R5/R6 bin would be more efficient because the XP-L HI 5D tint only goes up to V2 bin. So the XPG3 would still be the ideal emitter for this light.
The specific weight of silver is about 4 times the specific weight of aluminum. So, if you want your silver light to be as big as your aluminum light, you need 200 grams of it. Well, make that 150-160 gram. Because the reflector, lens, led-board, driver and switch are the same.
I’m sure she could elaborate, but the plan is it’s going to be a PID like job, which is a big step up from current lights. There’s a bunch of code you can read over if you want to dig around in here. I think it was closer to PD than PID when I last checked, but as to whether the code will step back up after a step down if the light cools off, it’s definitely going to be capable of that.
It is not the driver it’s in the software.
If throttled for thermal reasons and you put ice on a D4 it gets brighter. Same as FW3A.
If you flash Andúril on the Q8 it should also work. But you need to get the regulation right for every type of lamp.
