Is even their automated system on vacation this week? Ordered something and got 0 response . Could not create account and no emails . The only thing I received was a PayPal email . This normal for them this week?
Yes, that is normal this week and next week and maybe part of the week after. It is called Chinese New Year.
Same procedure as every year.
Others at least acknowledge the order and explain that things will ship after the holiday. I’m guessing a computer does it , they on holiday too ?
Yes. Chinese computers go home to see their families too. Not that soulless capitalistic working machines as in the West.
That’s (correct) Hilarious!!!
Question:
Order number 1712220019 from 23-12-17
Two months passed, nothing was heard about the parcel
Hi johnkey68
Your package had shipped out by regular airmail on 30 Dec 2017.
We will help to track where is your package.
Please consider to choose to registered airmail on next time.
Thank you
Ban
Hi friend
I will send a PM to you.
Thank you
Ban
Is it normal that H1-A driver starts blinking after 2 min in high mod?
Please let me know what is the battery are you using?
Also, you can try on the medium to see the same situation happened or not.
Thank you
Samsung 30Q
Does the problem occur on the medium mode?
No.
Do you have other high drain battery to make a try?
If you get a digital meter, you can see the current will drop when the light is blinking.
It may be the battery has problem.
Does the Samsung 30Q is a fresh new battery?
Same with 20R and 25R.
What is the flashlight host are you using?
Eagle eye X7.
Does the tail switch can be supported over 6V 3000mA current?
You can let me know what is the switch are you using?
I used regular omten switch. Spring was overheated so I changed hole tail internals with solid piece of brass. Still see blinks after host gets hot.
This flashlight driver has over-heat protection. It will blink. If the temperature is still not go down, it will shutdown the light.
Will you able to try not installing into the flashlight host and see it will over-heat or not?
Thank you
