I must say that the tint and beam with these LEDs and triple TIR are not the best on close range and white walls. But, at a distance and with other non-whit environments, it has a nice beam and even being CW emitters, they look nice!
Great review, thanks for posting plus all the tips and mods, I really learned a lot from this, I especially like how the convoy 350 tube fits. Iām planning to order one of these.
In the beam shots above it appears the tint is more neutral with the TIR, (at least it doesnāt appear to have the bluish tint shift in the spill anymore) Are you seeing that improvement in reality or is it just the camera playing tricks?
Also what is the degrees of TIR you used and where did you get it? Please post a link if possible. Thanks.
Thanks for reading beam0!!
Yup, with that lens the tint indeed tended to more NW, there wasnāt āgreenishā tint shift and it didnāt look, indeed, so CW.
The camera picked it but in reality was even better! The cellphone tends to distort the reality a little bit!
Unfortunately I am not able to post a link for that lens because it was from another flashlight I have, so I borrowed it! About the degrees, I can only say that it was a bit narrow (making the hotspot more dense), despite the spill was pretty nice and with a good amount of light!! Iām not sure if Iāve seen those for sale, but Iāll check it and let you know if I find it
OMG you are right! I just took a look at their Aliexpress webpage and realize itās supposed to have a button in the tail cap. The one they sent me didnāt have a tail cap button. No wonder I canāt turn it off! I bought mine from Amazon.com
It is a Stainless Steel (3xAAA / 18650) light, and I modded it with a brass pill, biscotti driver and a Convoy S2+ reflector and lens. I had to dismantle it later but will put it to work again soon!
My SP32A didnāt have any green but was too cool white for me. It had a tiny bit of blue. However, having the super efficient XP-L2 V6 bin emitter is impressive for a low cost light and it is very bright. It also has the best one button UI besides the Emisar D4 that I have used. I think the only thing missing from the D4 is the hold from off to go to moon light. If they have a more neutral/warm tint option, I will buy another one.
Edit: I contacted Sofirn through Amazon and they let me know that I accidentally swapped the the SP31 tailcap with the button onto the SP32A. Oops my bad =( ā¦ā¦ But it actually worked great on the SP32A, which already had one of the best single button UI. The SP31 with the right tail cap is actually an extremely user friendly two switch flashlight. Sofirn was also very nice to ship me a replacement tail cap eventhough it was my mistake.
Yes this really helps, thanks for the link to the TIR thread, thatās an interesting thread, that optic from the SS light measures like the ones for S2+, guess Iāll have to just try some different ones too.
And thanks for the link to the SS light,Yupard has a lot of interesting budget lights.
Hi. MascaratumB,
I have now modded mine with a TIR under the glass and an extra O-Ring.
Did a Great Job of blending the awful colours, and diffusing the Hot Spot.
Thanks for the Hints and Tips, we all learn something new from each other on BLF.
Ordered 2 more as on special at Ali Xp.
Cheers,
S-L
Hi Splott-Light
Glad these experiences helped you on your mod as well Indeed, the stock ābeamā is kind of :confounded: but the TIR allows it to get better! If I didnāt have the idea of the triple mod, I would have stayed with the TIR instead of the reflector.
It was too much āgreenishā!!
If I may ask, what TIR did you use? I used one from another light and it fit perfectly (without the gasket). Did you use TIR + gasket?
If you can tell or show what you used that would be great as other members may benefit from that as well
I would also like to know this. The reflector height is 15mm, the TIRās I have are around 11.7mm-12.6mm so theyāre too short. Couldnāt find any the right size that were made for XP-L2
Hi Splott-Light! Thanks for posting the links for the TIRs!
Hum, those seem to be like the Convoy S2+ TIRs, with the white gasket! Funny, I didnāt experimented those before I tried the one I used for a whileā¦ :person_facepalming:
Well, but if they fit well (even with the mods youāve done) thatās nice
I guess that someday I will try to open the SP32 (not the SP32A) and stick a TIR there as well, to smoothen the beam
Thanks for taking the time to write
And if you are Madā¦welcome to the club :smiling_imp: :face_with_monocle: :sunglasses:
Received my SP32A earlier this week and really liked it. :+1:
I have the same optics from Fasttech, in 10, 15, 30 and 60 degrees, also from a few years ago.
So I tried to put a 15 degree in and accidentally dedomed the LED :person_facepalming:
The centering gasket was stuck (glued?) to the bottom of the reflector and I didnāt put any in, I was trying to measure how thick of an o-ring I needed and the sharp legs of the optic dedomed it. It took away some phosphorus so now I have a sick purple beam that looks something like UV.
So soon I will order an XP-L2 V5 4000k to replace it. The 5350-5700K was a bit too cool for me anyhow. Iāve read the XP-L2 5000K is a bit cold compared to others and the 4000k has less tint shift.
A few thing differ from the review:
1. Ramping time: about 3 seconds from lowest to highest (and visa-versa) :+1:
2. MCPCB has a smaller silver screw instead of the black one, and the head is smaller than the opening in the board, so the screw wasnāt doing anything! Also the threaded shaft of the screw is too thin so itās loose in itās hole!
I may not use a screw with the new MCPCB if the reflector holds it down, otherwise Iāll need to drill a hole in the new board for it and get a larger screw.
