Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
Triple 4040 for X6 triple would be great, in fact I’m going to put my next X6 triple project on hold now that I know it’s coming. I’m wondering if luxeon MZ is compatible with CUTE-3-SS? For sure it must work nicely with CUTE-3-W and CUTE-3-M.
I would also be in for a cute3 4040 board
Me too, the c8 triple its on hold, and now it will be Quad C8. The existence of CUTE-4 had gone unnoticed for me.
Right, I didn’t even think about the CUTE-4.
Now I’m thinking about the crazy amount of current a quad fet-driven Luxeon MZ will pull with the super low vf, we might be getting to the point were the small 1288s will finally start melting :smiling_imp: .
I have been thinking something similar. I have a Cryos m2 cooling bezel (p60 head with a lot of deep fins) which has never really stretched its legs. 30A sounds nice with a Samsung 30T :D.
I am constantly searching for a source of 30Ts on web but so far I haven’t found anything except one company located in India that is specialized for electric vehicles.
According to their website they stated having 30T in minimum oreder quantity of 100 cells. I haven’t contacted them and don’t know if some of us forum guys did. I was thinking on idea of group buy but I doubt this cell will be accepted buy people at current time due to absence of lights/ hosts that would accept them or ones that could be bored to accept them not counting 26650 lights. Maybe those vapers would jump in but I am not in that scene.
Edit: Seems like Voltaplex have them in stock with minimum quantity of 50. Hope? :heart_eyes:
M2 Cryos head with what battery tube/host? Most can’t be bored to 21+mm…… the threads on my 5Mega host at the tail cap measure 21.76mm. http://www.cryosillumination.com/
I don’t know yet, maybe a custom battery tube would need to be made. That would actually be a better solution anyhow because I could skip the p60 pill (bad for heatsinking) and integrate the heatsink into the battery tube.
Such a tripple might actually pull too much current though pushing the LEDs past their maximum brightness.
BTW: Samsung 35T are already listed here.
Can somebody post a link for the MZ 90CRI 3v 5700K from digikey? I can’t seem to find the correct one.
Digikey
Mouser
Those Luxeon MZs are definitely rather expensive for such small LEDs.
Since max power dissipation is 15W for the FET on the LED PCB, the max current should be much, much higher than 25A? Which FET are you using? What is the internal resistance when it is “on”?
Also, would it be possible that you offer a FET-based switch like this ? It makes a lot of sense for DD lights.
Thanks!
Just place an order for the Lux V. Thanks!
MZ leds are not small at all, at least not by total die size area,which is ~8mm2 - they are equivalent to non-existing XHP50(.2) HI.
On mosX boards mosfet can handle a lot of power, more than 25Amps is it works in DD mode, I use PSMN2R4 mosfets in lfpak33 package.I agree that 1288 switches are not enough these days.
They cost twice as much as the XHP50.2.
Thanks. So it has a typical resistance of 2.6mOhm (max 3.2).
I’m not sure how to read the datasheet regarding maximum current. 70A seems to require a high voltage?
MZ 3 years old LED, at that time 8mm^2 of die area for 7-8€ was ok price.
On mosX it can handle enough current for any flashlight application, other components are usually more challenging at 20+Amps.
By looking at the datasheets of both it should be reasonably compatible. Luxeon MZ light emitting area seems to be around 3x3mm, which would mean around 4.25mm diagonal. CUTE-3 bottom hole diameter is 4.4mm according to the datasheet, so it would work but for best efficiency the optics would probably have to sit lower than the default.
I haven’t checked if CUTE-4-SS bottom holes are the same but I would guess they are.
CUTE-3-M is basically the same optic as CUTE-3-SS but with a stronger honeycomb pattern.
CUTE-3-W seems to be shaped differently and have wider bottom holes, I guess it should provide the best compatibility but it will have basically no throw.
There are few versions of CUTE-3-SS and 4-SS, and they have different tir shapes, for ex. XR versions have bigger entrance holes and smaller tir area.
For those of us looking for e-switch drivers, do you still have LD2’s?
No, LD-2/3 are not available anymore.
