DIY 207 - 222 nm UV source for biologic death ray
Forgive me if I digress. Mold in such things as basements we have fought with ozone generators; not good for you if you are in the airspace you are treating, but you said the room is sealed and you might take the precaution of airing out your living space. Also, there are strong UV sources that are used to disinfect water as it passes through a pipe, and also some to disinfect surgical rooms - I don’t know much. Lastly, one of the thoughts that crossed my mind as I read (and that is probably totally off the track) is the question of whether a fecal transplant might help to reestablish your own intestinal flora to enable you to fight off the nasties. When I had spinal surgery they had me disinfect my skin for five days straight pre-op; I think it might have helped. Good luck.
Wouldn’t you need to keep the 207nm light away from the open abdominal cavity, because your skin wouldn’t be there to prevent the light hitting the cells of your internal organs?
Although having said that, I now find myself wondering whether some sort of visually transparent, sterile, spray-on UV-blocking liquid might be a solution…
Colloidal silver. Despite naysayers, I know it worked/works for me, everything from heading off colds/flus, knocking ’em back if they’d already gotten a foothold, treating burns and preventing blistering after a nasty sunburn, you name it.
99%+ pure Ag ingots/wire, a ~30V DC source, distilled water, you’re done.
I don’t believe the 207 nm energy penetrates enough to affect non-skin areas. From what I gather it does not penetrate but the two frequencies hit a sweet stop in bug killing.
I am hoping some people familiar/interested in these wavelengths will see this thread and contribute some knowledge.
Here is a link to a paper about this whole thing. Far-UVC light: A new tool to control the spread of airborne-mediated microbial diseases | Scientific Reports
Quote from linked Nature article: “… due to its strong absorbance in biological materials, far-UVC light does not have sufficient range to penetrate through even the outer layer (stratum corneum) on the surface of human skin, nor the outer tear layer on the outer surface of the eye, neither of which contain living cells; however, because bacteria and viruses are typically of micron or smaller dimensions, far-UVC light can still efficiently traverse and inactivate them. ”
So it’s the layer of dead cells which is key.
Please don’t espouse quack medicine, especially where someone with life-threatening bowel problems is concerned. There is no empirical evidence to suggest that colloidal silver is any more effective than a placebo. Even its mild topical antibiotic properties are no match for actual antibiotics. Using colloidal silver for illness will at best waste small amounts of silver, and at worst make your skin gray.
If a placebo could knock back a cold or flu overnight, hey, send me some. All I know is what I’ve experienced.
And you’d have to chug a gallon or more per day over the course of years (like Smurf Guy) to turn gray.
I wouldn’t trust store-bought, because who knows what’s being sold (who tests it, anyway?), which is why I make my own.
When it comes to colloidal silver, I trust the Mayo Clinic, WebMD, and the National Center for Complementary and Integrative Health (NCCIH).
https://www.mayoclinic.org/healthy-lifestyle/consumer-health/expert-answers/colloidal-silver/faq-20058061
https://www.webmd.com/vitamins-supplements/ingredientmono-779-colloidal%20silver.aspx
https://nccih.nih.gov/health/silver
They say that colloidal silver doesn't help, and in fact harms, the human body.
Well, look at the “studies” of echinacea. Take the parts of the plant that have the lowest amounts of active ingredients (ie, almost none), find minimal gain vs placebo, and declare categorically that it doesn’t work. You might as well be testing tea-leaves…
“Follow the money”.
Like seriously, why people get their panties all in a bunch about things they haven’t tried and in fact won’t try, and defend their position almost with a religious fervor, is beyond me. Do your own research, from both sides (ie, those sites promoting it, and those poopooing it), and come to your own conclusions.
Jesus…
It’s funny that you mention religion. Religious people claim that something is real without rigorous evidence. That might not have been the best analogy.
If I tried colloidal silver and it appeared to make me better-endowed and 30 IQ points higher, that evidence would be anecdotal and therefore meaningless. The only way you can draw conclusions about the efficacy of a substance is with a rigorous study. This may come as a surprise to you, but unsubstantiated writings on colloidal silver promotion websites are not scientific evidence. There is a concept in logic called the burden of proof. If you make an assertion, it needs empirical evidence to support it. Your assertion is that colloidal silver cures ailments. Please show us the accompanying evidence.
Y’know what? If you don’t want to believe it works, don’t even want to try it, then don’t use it. It’s that simple.
Anything I could put forth how it worked for me you’d just dismiss as “anecdotal”, so I’m not even going to bother.
There’s no Colloidal Silver Lobby that buys funds their “research” and cherrypicks “studies” to show it works. Can you say the same about those who want to show that it doesn’t work? (Hint: Phig Barma.)
Ferchrissakes, how many decades have there been studies which “proves” that secondhand smoke is harmless?
Like I said, follow the money.
Or not. I’ll use it when needed, and you don’t have to. I was just putting it out there in case anyone’s actually open-minded enough to go have a look.
Guess that was a mistake…
(Hint: Phig Barma.) Ha Ha Love it ! Empirical evidence? Oh you mean statistics? I have had MS for quite a number of years now and when first diagnosed there was no real treatment so you just suck it up buttercup. Now there are several ” disease modifying therapies” available. These have been shown to have a “statistically significant ” effect on the disease. If you run the numbers really though this was what allowed FDA approval and insurance reimbursement. I know many MSer’s who are on now or who have been on any of a number of these therapies and none of them can point to a real effect these treatments have brought about. I get that our experience is anecdotal. Know of a man who sold everything and went to China for a stem cell therapy and the main difference he observed was a lack of a place to live when he came back. Follow the money is THE best advice given in all aspects of life. David
You’re right, there is no colloidal silver lobby. There are, however, many quacks trying to sell their supplements on the Internet. I imagine they are invested in keeping people convinced of its efficacy. This obviously extends to a conspiracy involving big pharma, because, as we know, big pharma profits vastly off common colds and sunburn.
Did you know that the human body has no biological use for silver? Given knowledge of this, does it seem likely that drinking silver does anything? If tangible, non-placebo benefits arose from drinking silver, does it not seem likely that more people would do it? As it stands, the only ones trying it are alternative medicine types, all of whom soundly reject logic. “Big pharma” is not omnipotent; if colloidal silver was both easy to make and effective, we would expect to see grassroots use throughout the world. Doctors in impoverished communities would love it.
And that’s the problem with quackery, that they sell hope to the hopeless. Emphasis on sell.
What bugs me about the whole colloidal silver thing is that all the naysayers wrap themselves in white lab-coats, parrot the same establishment sources touting pricey meds vs something that can be made for cheap (1 gallon of distilled water and pennies worth of silver make a whole gallon of c-Ag), yet never even bothered to just try the damned stuff.
Silver is used extensively in burn wards. Silver was even added to Band-Aids to help healing. Gauze infused with silver is used to treat diabetic ulcers which don’t heal otherwise. Silver’s being added to clothing to make your sweat-stank that much less. Silver silver silver. And these aren’t “silver nuts” touting it, but commercial interests.
Here’s what I tell them, but which falls on deaf ears. Snap together 3 or 4 9V batteries (27V-36V) and run current through silver wires immersed in distilled water. Instructions abound all over the web for details. Shine a laser through it. It’ll start out crystal clear, and you’ll be able to see the beam more and more as more colloid forms. When it’s done, use it.
Everyone knows the just-inhaled-a-cottonball feeling right before you come down with a cold. Chug some c-Ag. What I’ve done is make 16oz or so for a massive dose. Chug the first third to get it into your system. Sip the second third over the course of the day. At night or the next morning, chug the last third.
It should taste like plain water, but have a metallic aftertaste to it. That’s the Good Stuff.
If it doesn’t work, by the next morning you’ll have a just-inhaled-a-Brillo-pad feeling instead, as if you did nothing special. If it does work, you’ll feel way way better, and ultimately not come down with the cold. I speak from experience on this, and I kinda doubt any placebo could knock back a cold overnight. (And the rich irony is that Ag is poopooed, yet Zn lozenges are universally recommended!)
If you wait too long and give the cold a chance to get a foothold, you’ll still end up feeling sick, as the damage has already been done, but you’ll also heal that much faster.
So no, you don’t have to spend 40bux a bottle on who-knows-what that’s labelled colloidal silver. Make yer own, cheaply, and fairly easily (Hell, people who mod lights for fun can’t string together some Ag wires in DW??). There really is no excuse. And anyone who does take me up on testing it, if you’re intellectually honest about it, you’ll give it a fair shake, vs torpedoing the effort just to be able to declare it doesn’t work.
It seems to me that people put way more effort in trying to trash colloidal silver than just do some cheap’n’easy testing of their own. And even so, there’s no proof that’s acceptable or even possible. Personal anecdotes are instantly and summarily dismissed. Like someone dressed in a labcoat and stroking his beard is the only one who can pronounce judgment on it. Hell, for some time, “scientists” declared that it was aerodynamically impossible for the bumblebee to fly. Someone should’ve told that to the bumblebee…
Now you know my frustration trying to discuss the issue. “Hello, wall!”
Some info I just grabbed in about 30sec…
Podiatry Today: https://www.podiatrytoday.com/article/3156
Advanced Tissue: https://www.advancedtissue.com/4-types-of-impregnated-wound-dressings/
Silverlon: Silver Antimicrobial Wound Dressings | Silverlon
Silvercel: http://www.acelity.com/products/silvercel-dressing
whups, sorry, it was Curad, not Band-Aid: Antibacterial silver products finally begin to emerge after years of FDA oppression
Ummm, have you walked into a CVS or Walgreen’s lately?
Probably not. But it’s what it does to the little bugs infesting your system that matters.
Silver interferes with a virus’s ability to replicate. It effectively turns off the mechanism which knows where to slice RNA. Kinda like taking a printer with fanfold paper, and screwing up the linefeed count so that each “page” straddles 2-3 pages instead. No (correct) RNA replication, no more virus.
Bacteria, I think it interferes with its metabolism, ’though I don’t recall details offhand.
Hell, for a long time, no one thought there was any use for Se (selenium) in anyone’s body, yet a Se deficiency can be rather nasty. It’s needed in the thyroid, albeit in only trace amounts. A few Brazil nuts could fix it, and then some.
Then again, too much Se can mimic radiation poisoning!
Likely because “doctors” were so ingrained to believe what the mainstream believes, that Ag is quackery.
It’d be nice if there were some open-minded enough to give it a shot. Just have them talk to some doctors in burn-wards…
Thanks for those links about silver dressings. Although you may be tempted to believe that they work because they exist, there is actually mounting evidence that these dressings have no effect on wound healing or infection rates. Here’s a review:
http://onlinelibrary.wiley.com/doi/10.1002/14651858.CD006478.pub2/abstract
Not to dispute silver’s antimicrobial properties, of course.
I’m a biologist, so I can verify that this is supported by research. However, these experiments are performed in vitro. A test tube environment is not a proxy for testing in vivo effects—living bodies are too complex.
This was discovered in 1957. Suffice to say, science has caught up.
Actually, if someone wanted to perform a blind trial with a sufficient sample size and statistical testing, it would be wonderful. Science can be done by anyone (although the experiment should be ethical). Personal anecdotes are dismissed because they’re just that—anecdotes. They don’t control for confounding factors.
Zinc is an essential element for humans to stay alive, unlike silver. Even so, the evidence on whether zinc lozenges actually do anything is mixed.
Actually, a while back, I had some stitches split open (don’t ask) only 15min after getting sewed up. Didn’t realise it at the time, as cauterisation before and a pressure-dressing after kept me from leaking all over my car-seat. Still, by the time I went to get (what was left of) the stitches taken out, I had a rather deep gaping hole that had to heal from the inside out. To restitch, a plastic surgeon would’ve had to cut even more to make a fresh cut to be able to restitch it, and still there’d be no guarantee they’d hold.
So, a whopping 2mos (8wks) went by, and I still had a gaping hole that I had to dress daily with bandages, and only a month into it was written a scrip for DuoDerm patches. The wise-ass I went to laffed when I was frustrated enough to ask if it’d be another 2mos ’til it closed up, saying it’d be longer. F that!
After taking off the 2nd DuoDerm (about 1wk a pop), I made a batch of c-Ag, and the black ick on one of the electrodes, whether AgO, Ag2O, AgH, nano-Ag, whatever, I slathered into the hole and onto the DuoDerm, and slapped it on.
After 1wk, the hole that was the size of a quarter was now almost a pinhole. Another patch, 2-3 more days, it was completely closed up. Had a black “tattoo” in that area of skin for a few years, but that’s it.
No one is going to tell me that Ag doesn’t promote healing. And that wasn’t just The Power Of My Mind, either (though that’d be pretty kewl…).
Thankfully. Else they’d still be drilling holes in peoples’ heads to let the evil spirits out, or bleeding people to “release the heat from their veins”.
Yaaaay, science!
I know, but was just illustrating a point. Okay, so early cars were feared, “because at speeds more than 30mph, people wouldn’t be able to breathe”.
Yet some people swear by them, and they do seem to work. Me, I never even tried any. I’d rather go for Ag right off.
But if you take Zn supplements, balance them with Cu, and v/v.
I suspect Zn is a “poor man’s Ag” when it comes to colds, etc. Might not kill the little bugs, but makes them quite uncomfortable. Never looked into the purported function of Zn in that regard.
Your wound healing anecdote is appreciated, although it doesn’t contribute to our debate.
And that’s the difference between us. My opinion is easily changed by new evidence.
Guys - why do you believe you need to do this.
I am trying to accomplish something that is important to me.
And all there is is assorted flavors of rant and BS about something completely irrelevant. I am on one side of that discussion (the rational one), but you are destroying the thread. And if one of you should meet the others on the street and one is a light bluish green, you will have your answer.
And Silver does have a recognized use as an external antibacterial agent. I just remembered. I believe Silver was pumped up urethras to combat STDs. Sort of internal. I believe it was unpleasant.
Phlogisten and gravelmonkey -
You need to be careful with the terms far UV or far UVC. Mostly people talking about far UV for these things are actually thinking about 254 nm and above. The effect I am talking about I believe needs to get down into the 207 range to work properly. There is a particularly good absorption window at 207 that optimizes the killing effect. My original post said 207 - 254. I have learned more since then. Some earlier work was done up at 220 - 254, but 207 turned out to be a sweet spot for deadly absorption.
Aside from not hurting eyes and skin, the light should not even be visible to most people. It is outside the visual spectral range of our eyes. Some insects and animals can see it (e.g., bees). So it should not be distracting to anyone working in a area lighted with 207 nm. Like a surgeon looking for just the right place to cut; or having to suddenly find the right place to stick a thumb while yelling for a nurse.
