BLF GT (preliminary) modding thread
I have opened my flashlight by 2 people (my son and I) using non-skid rubber gloves.
With the stock Led obtained 925.000Cd. I have replaced it with a boiling thinner dedomed XHP35 HD and now I achieve 1.186.000Cd.
The Led I used was removed from a Haikelite MT02.
The measurements are at 10 meters. At 15 meters I get 1.118.000Cd
Nice! :+1:
Will you do any engraving or modification to the anodization?
I recently saw your Utorch… :heart_eyes:
I am waiting for a single carrier “shorty” tube. I carry the GT right at the switch area so balance is not a problem. A little less weight and smaller overall size would be nice in my opinion.
How many lumens does the light produce?
No integrating sphere. I’m sorry.
Visibly more lumens than stock.
Neither of those two distances is far enough to get an accurate reading.
Thank you, goshdogit.
Emiter swap is so little mod than I don’t plan to engrave nothing.
You might be right, but with a second measure (15m) smaller than the first one (10m), I have interpreted that the beam was already collimated at that distance.
In any case, my luxmeter is very cheap and crappy. I want to think that the actual results are better.
if the further measurement is lower your beam is either not focused to infinity but rather to something under 15m or your measuring method is off
I emailed them about them and they asked what were they for, I answered honestly and they just ignored me afterwards… :rage:
How did you convince them? Got a spare you could sell? :money_mouth_face: :wink:
I am working on a CFT-90 driver for GT
TN42 design finished
Ancient Chinese Secret…been dealing with Lumintop for years, I did a SD75 XHP35HI and needed Smooth reflectors, they made them for me. I sent pics and written details of the builds, the rep at that time was Will, he thought it was very Cool. I guess I’m on their Cool list? A shout out to Convoy, Thrunite, and Phoenix they are great to deal with also, at least on my end. :wink:
@ Lexcel
which input voltage?
carrier mod necessary?
I would like to mod my GT with an XHP70.2, someone can kindly tell me which resistor to replace on the original driver, and possibly which value to use?
Thanks.
I have posted this information before somewhere.
You need to replace the 2512 3W resistor with either a .050ohm or .040ohm. The .040 is not officially recommended but it has been working fine in my light for months now.
The biggest issue is the xhp70.2 mcpcb, they are hard to find.
I am trying to talk lumintop into making a batch of them and I think they might do it. Although time will tell for sure.
Tomorrow evening Djozz and I will measure our BLF GT’s in the basement floor of my appartmentblock: we have an indoor beamshot location of up to 45 meters……….
should give us some decent throw numbers indication.
Me or Djozz will post the results.
Cheers
Nico
I purchased a R047 from here
Now I noticed that TA said 3W power the link is for 1W power, would that still work? or do I risk effing something up?
That resistor while technically ok is only rated for 1W. The resistor needs to be rated for 3W for long term reliability.
I have yet to find a reasonably priced 3w .047ohm resistor myself, so I just recommend the .050 and .040 now.
Thanks for the clarification TA, I just noticed it! The cheapest I found was $20 for 100 pieces… Will this one work?
https://www.ebay.com/itm/100PCS-X-Bourns-3W-2512-0-047R-47MR-0-047-OHM-1-RES-Metal-Film-Chip-Resistor/332133259856?epid=574292028&hash=item4d54af5a50:g:YTsAAOSw32lYq0X3
Yes, that would work but please don’t spend that much on a resistor. Better to just get an 050 or 040 for less then $1.
Or for that kind of money wait until my TA drivers are finished and buy one of those. It will give you a lot more performance from the xhp70.2.
