What is the flashlight host are you using?
Eagle eye X7.
Does the tail switch can be supported over 6V 3000mA current?
You can let me know what is the switch are you using?
I used regular omten switch. Spring was overheated so I changed hole tail internals with solid piece of brass. Still see blinks after host gets hot.
This flashlight driver has over-heat protection. It will blink. If the temperature is still not go down, it will shutdown the light.
Will you able to try not installing into the flashlight host and see it will over-heat or not?
Thank you
kiriba-ru, is the H1-A overheating at stock driving current?
Maybe you can craft and attach some small copper heatsink over the boost IC and the microcontroller if required.
I recently made a tiny heatsink out of copper sheet for my rotary tool's new speed controller triac, makes a nice deal of a difference even if small in size.
Cheers ^:)
Any plans for releasing a XHP70.2 version of the KDIY K5s or KDIY KF8?
Would be awesome!
Do you have any decently made red laser pointers?
I bought a handful from eBay to donate to my local animal shelter recently.
They were crap — switch wires had been placed through but not soldered onto the circuit board.
Those came loose and the pointers fell apart.
How is the stock of high voltage Samsung ICR18650-30B or Samsung ICR18650-32A cells?
Gonna overhaul a high end laptop pack, 6pcs.
Cheers ^:)
Ban, will you restock the CF FX 2AA driver “http://www.kaidomain.com/p/S025419.CF-FX-2AA-16mm-0_9V-3V-3-Mode-Boost-Driver-Circuit-Board” ?
I think I like your new tube-style 18650 host, at least I ordered one
http://kaidomain.com/p/S027536.DIY-LED-Flashlight-Host-120mm-x-24mm-SMO-version-Black
Thank you friends.
I will get all of you guys’ comments and advices.
I am sorry we just get back from the holiday, i will catch up all the things.
Thank you
Ban
I noticed that one as well, I really like the full body knurling and the SS bezel, but I’d prefer a smooth “foybezel” than crenelated.
Also curious if this will lego with any of the convoy/Jaxman or Astrolux shorty tubes. If you have a S2+, E2 or S1/A6 please let us know when you get it.
I have all the lego parts, will let you know
Great, thanks!
Im almost sure that threads have 1mm pitch and not compatible with brand lights.
Reminds me a lot of the old uf-2100
I see it does now, but I never had one. What I remember they were modded a lot.
The Astrolux S1/BLF A6 wires are not compatible with those of the Convoy S2+
Convoy S2 + and Jaxman U1 is fully compatible
I’d say it’s the same with different brands
The only difference is in the ornaments of the head
